Текущее время: Пт сен 18, 2026 08:07
 Заголовок сообщения: dir-320 A2 fullflash
СообщениеДобавлено: Сб июл 03, 2010 11:08
хелло!
беда случилась! запоролся dir-320 A2 (bcm5354 & 29lv320dtti)
при заливании прошивок роутер стопориться на загрузке CFE
CFE version 1.0.37 for BCM947XX (32bit,SP,LE)
Build Date: Thu Jul 19 10:53:24 CST 2007 (root@redhat9)
Copyright (C) 2000,2001,2002,2003 Broadcom Corporation.
Initializing Arena
Initializing Devices.
Boot partition size = 262144(0x40000)
et0: Broadcom BCM47xx 10/100 Mbps Ethernet Controller 4.150.3.0
CPU type 0x29029: 240MHz
Total memory: 32768 KBytes
Total memory used by CFE:  0x80300000 - 0x803C0720 (788256)
Initialized Data:          0x80337730 - 0x8033AE50 (14112)
BSS Area:                  0x8033AE50 - 0x8033C720 (6352)
Local Heap:                0x8033C720 - 0x803A0720 (409600)
Stack Area:                0x803A0720 - 0x803C0720 (131072)
Text (code) segment:       0x80300000 - 0x80337730 (227120)
Boot area (physical):      0x003C1000 - 0x00401000
Relocation Factor:         I:00000000 - D:00000000
alpha bootcode ver 0.1.2
cmd = ifconfig eth0 -addr=192.168.0.1 -mask=255.255.255.0
We disable the arp for self.
Device eth0:  hwaddr 00-90-4C-C0-00-01, ipaddr 192.168.0.1, mask 255.255.255.0
        gateway not set, nameserver not set
cmd = go;
cmd = load -raw -addr=0x803c0720 -max=0x3a0000 :
Loader:raw Filesys:tftp Dev:eth0 File:: Options:(null)
Loading: Failed.
Could not load :: Timeout occured
Dest=80001000, source =803c0720, filename=flash1.trx
cmd = boot -raw -z -addr=0x80001000 -max=0x3a0000 flash0.os:
Loader:raw Filesys:raw Dev:flash0.os File: Options:(null)
Loading: entry point=80001000
. 0 bytes read
Failed.
Could not load flash0.os:: Error
Web Server Staring...
CFE> web info: Waiting for connection on socket 0.
но дальше через терминал ввожу следующие комманды - загрузка продолжается.
CFE> nvram set noset_try_flag=1
CFE> nvram commit
CFE> go
cmd =
cmd = go
Loading: Failed.
.. 3856 bytes read
Entry at 0x80001000
Closing network.
Starting program at 0x80001000
CPU ProcId is: 0x00029029, options: 0x0000004d
Linux version 2.4.37 (eko@dd-wrt) (gcc version 3.4.6 (OpenWrt-2.0)) #4564 Wed Jun 9 19:43:22 CEST 2010
ставил и openwrt, и dd-wrt, и родную прошивку (c wimax и без) результат один и тот-же.
Где можно взять fullflash для данной модели и залить ее через JTAG (порт распаян и работает) или CFE?
зарание благодарен.
Сейчас этот форум просматривают: Google [Bot] и гости: 11
