Текущее время: Ср окт 14, 2026 20:09
 Заголовок сообщения: DIR-300NRU терят связь по WiFi
СообщениеДобавлено: Пн мар 08, 2010 13:43
такая проблема, теряется связь с интервалом 2 - 10 минут
раздача ip автоматически
HV B1
SV 2.01
лог:
"Mar 8 13:29:16 ","Xmas port scan attack from WAN (ip:195.218.170.156) detected."
"Mar 8 13:28:58 ","Xmas port scan attack from WAN (ip:62.122.208.68) detected."
"Mar 8 13:28:47 ","Xmas port scan attack from WAN (ip:195.218.170.156) detected."
"Mar 8 13:28:47 ","DHCP: Server sending ACK to 192.168.0.103. (Lease time = 86400)"
"Mar 8 13:28:47 ","DHCP: Server receive REQUEST from 00:1d:d9:0c:bb:52."
"Mar 8 13:28:33 ","Xmas port scan attack from WAN (ip:195.218.170.156) detected."
"Mar 8 13:28:25 ","Xmas port scan attack from WAN (ip:195.218.170.156) detected."
"Mar 8 13:28:20 ","Xmas port scan attack from WAN (ip:195.218.170.156) detected."
"Mar 8 13:28:18 ","Xmas port scan attack from WAN (ip:195.218.170.156) detected."
"Mar 8 13:28:16 ","Xmas port scan attack from WAN (ip:195.218.170.156) detected."
"Mar 8 13:27:13 ","Xmas port scan attack from WAN (ip:94.100.181.58) detected."
"Mar 8 13:26:57 ","Xmas port scan attack from WAN (ip:62.122.208.68) detected."
"Mar 8 13:26:25 ","Xmas port scan attack from WAN (ip:94.100.181.58) detected."
"Mar 8 13:26:20 ","Xmas port scan attack from WAN (ip:10.33.223.223) detected."
"Mar 8 13:26:09 ","Xmas port scan attack from WAN (ip:10.33.223.223) detected."
"Mar 8 13:26:04 ","Xmas port scan attack from WAN (ip:10.33.223.223) detected."
"Mar 8 13:25:59 ","Xmas port scan attack from WAN (ip:10.33.223.223) detected."
"Mar 8 13:25:49 ","Xmas port scan attack from WAN (ip:94.100.181.58) detected."
"Mar 8 13:25:40 ","Xmas port scan attack from WAN (ip:94.100.181.58) detected."
"Mar 8 13:25:38 ","Xmas port scan attack from WAN (ip:94.100.181.58) detected."
"Mar 8 13:25:37 ","Xmas port scan attack from WAN (ip:94.100.181.58) detected."
"Mar 8 13:25:28 ","Xmas port scan attack from WAN (ip:84.72.92.143) detected."
"Mar 8 13:25:27 ","DHCP: Server sending ACK to 192.168.0.103. (Lease time = 86400)"
"Mar 8 13:25:27 ","DHCP: Server receive REQUEST from 00:1d:d9:0c:bb:52."
"Mar 8 13:25:20 ","Xmas port scan attack from WAN (ip:84.72.92.143) detected."
"Mar 8 13:25:16 ","Xmas port scan attack from WAN (ip:84.72.92.143) detected."
"Mar 8 13:25:14 ","Xmas port scan attack from WAN (ip:84.72.92.143) detected."
"Mar 8 13:25:13 ","Xmas port scan attack from WAN (ip:84.72.92.143) detected."
"Mar 8 13:24:57 ","Xmas port scan attack from WAN (ip:62.122.208.68) detected."
"Mar 8 13:24:00 ","Xmas port scan attack from WAN (ip:195.218.170.156) detected."
"Mar 8 13:23:15 ","Xmas port scan attack from WAN (ip:62.122.208.68) detected."
"Mar 8 13:22:56 ","Xmas port scan attack from WAN (ip:195.218.170.156) detected."
"Mar 8 13:22:24 ","Xmas port scan attack from WAN (ip:62.122.208.68) detected."
"Mar 8 13:22:07 ","DHCP: Server sending ACK to 192.168.0.103. (Lease time = 86400)"
"Mar 8 13:22:07 ","DHCP: Server receive REQUEST from 00:1d:d9:0c:bb:52."
"Mar 8 13:21:58 ","Xmas port scan attack from WAN (ip:62.122.208.68) detected."
"Mar 8 13:21:52 ","Xmas port scan attack from WAN (ip:195.218.170.156) detected."
"Mar 8 13:21:45 ","Xmas port scan attack from WAN (ip:62.122.208.68) detected."
"Mar 8 13:21:39 ","Xmas port scan attack from WAN (ip:62.122.208.68) detected."
"Mar 8 13:21:33 ","Xmas port scan attack from WAN (ip:62.122.208.68) detected."
"Mar 8 13:21:20 ","Xmas port scan attack from WAN (ip:10.33.223.223) detected."
"Mar 8 13:21:10 ","Xmas port scan attack from WAN (ip:10.33.223.223) detected."
"Mar 8 13:21:04 ","Xmas port scan attack from WAN (ip:10.33.223.223) detected."
"Mar 8 13:21:03 ","Xmas port scan attack from WAN (ip:10.33.223.223) detected."
"Mar 8 13:21:02 ","Xmas port scan attack from WAN (ip:10.33.223.223) detected."
"Mar 8 13:20:48 ","Xmas port scan attack from WAN (ip:195.218.170.156) detected."
"Mar 8 13:19:50 ","Xmas port scan attack from WAN (ip:195.218.170.156) detected."
"Mar 8 13:19:20 ","Xmas port scan attack from WAN (ip:195.218.170.156) detected."
"Mar 8 13:19:05 ","Xmas port scan attack from WAN (ip:195.218.170.156) detected."
"Mar 8 13:18:57 ","Xmas port scan attack from WAN (ip:195.218.170.156) detected."
"Mar 8 13:18:52 ","DHCP: Server sending ACK to 192.168.0.103. (Lease time = 86400)"
"Mar 8 13:18:51 ","Xmas port scan attack from WAN (ip:195.218.170.156) detected."
"Mar 8 13:18:48 ","Xmas port scan attack from WAN (ip:195.218.170.156) detected."
"Mar 8 13:18:46 ","Xmas port scan attack from WAN (ip:195.218.170.156) detected."
"Mar 8 13:18:45 ","Xmas port scan attack from WAN (ip:195.218.170.156) detected."
"Mar 8 13:18:44 ","Xmas port scan attack from WAN (ip:195.218.170.156) detected."
"Mar 8 13:17:44 ","Xmas port scan attack from WAN (ip:62.122.208.68) detected."
"Mar 8 13:17:43 ","Xmas port scan attack from WAN (ip:62.122.208.68) detected."
"Mar 8 13:17:42 ","Xmas port scan attack from WAN (ip:195.218.170.156) detected."
"Mar 8 13:17:17 ","Xmas port scan attack from WAN (ip:62.122.208.68) detected."
"Mar 8 13:17:05 ","Xmas port scan attack from WAN (ip:195.218.170.156) detected."
"Mar 8 13:17:04 ","Xmas port scan attack from WAN (ip:62.122.208.68) detected."
"Mar 8 13:16:54 ","Xmas port scan attack from WAN (ip:62.122.208.68) detected."
"Mar 8 13:16:47 ","Xmas port scan attack from WAN (ip:195.218.170.156) detected."
"Mar 8 13:16:41 ","Xmas port scan attack from WAN (ip:10.33.223.223) detected."
"Mar 8 13:16:37 ","Xmas port scan attack from WAN (ip:195.218.170.156) detected."
"Mar 8 13:16:35 ","VPN (L2TP) Pass-Through enabled."
"Mar 8 13:16:35 ","VPN (IPSec) Pass-Through enabled."
"Mar 8 13:16:35 ","VPN (PPTP) Pass-Through enabled."
"Mar 8 13:16:35 ","Remote management is disabled."
"Mar 8 13:16:35 ","Block WAN PING is enabled."
"Mar 8 13:16:35 ","MAC filter disabled."
"Mar 8 13:16:34 ","DMZ disabled."
"Mar 8 13:16:34 ","Domain blocking disabled."
"Mar 8 13:16:34 ","URL blocking disabled."
"Mar 8 13:16:30 ","Xmas port scan attack from WAN (ip:195.218.170.156) detected."
"Mar 8 13:16:23 ","Xmas port scan attack from WAN (ip:195.218.170.156) detected."
Стационарный комп подключен через роутер работает стабильно без дисконнектов на нем постоянно крутится DC++
помогите!
СообщениеДобавлено: Пн мар 08, 2010 16:32
уже обсуждалось в ветке коммутаторы и файрволлы
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 67
