Текущее время: Пт сен 18, 2026 16:48
СообщениеДобавлено: Сб дек 26, 2009 20:09
Здравствуйте.
имею такую странность с dir-615 c2 (прошивка пока заводская 3.02RU). Постоянно скачет Bit Rate соединения.
Например (под openSUSE 11.2):
sergey@opensuse:~> while [ true ]; do /usr/sbin/iwconfig wlan0 | grep -e "Bit Rate" -e "Quality"; sleep 2; done
          Bit Rate=54 Mb/s   Tx-Power=15 dBm
          Link Quality=59/70  Signal level=-51 dBm  Noise level=-86 dBm
          Bit Rate=48 Mb/s   Tx-Power=15 dBm
          Link Quality=61/70  Signal level=-49 dBm  Noise level=-88 dBm
          Link Quality=59/70  Signal level=-51 dBm  Noise level=-83 dBm
          Link Quality=63/70  Signal level=-47 dBm  Noise level=-88 dBm
          Link Quality=68/70  Signal level=-42 dBm  Noise level=-89 dBm
          Link Quality=70/70  Signal level=-21 dBm  Noise level=-88 dBm
          Link Quality=70/70  Signal level=-34 dBm  Noise level=-87 dBm
          Link Quality=70/70  Signal level=-33 dBm  Noise level=-87 dBm
          Link Quality=70/70  Signal level=-30 dBm  Noise level=-86 dBm
          Link Quality=70/70  Signal level=-26 dBm  Noise level=-88 dBm
          Link Quality=70/70  Signal level=-27 dBm  Noise level=-85 dBm
          Link Quality=70/70  Signal level=-30 dBm  Noise level=-87 dBm
          Link Quality=70/70  Signal level=-28 dBm  Noise level=-86 dBm
          Link Quality=70/70  Signal level=-28 dBm  Noise level=-89 dBm
          Link Quality=70/70  Signal level=-31 dBm  Noise level=-89 dBm
          Link Quality=70/70  Signal level=-31 dBm  Noise level=-87 dBm
          Link Quality=70/70  Signal level=-28 dBm  Noise level=-87 dBm
          Link Quality=70/70  Signal level=-28 dBm  Noise level=-85 dBm
          Link Quality=70/70  Signal level=-28 dBm  Noise level=-84 dBm
          Link Quality=70/70  Signal level=-30 dBm  Noise level=-85 dBm
          Link Quality=70/70  Signal level=-27 dBm  Noise level=-87 dBm
          Link Quality=70/70  Signal level=-31 dBm  Noise level=-85 dBm
          Link Quality=70/70  Signal level=-31 dBm  Noise level=-88 dBm
          Link Quality=70/70  Signal level=-29 dBm  Noise level=-88 dBm
          Link Quality=70/70  Signal level=-26 dBm  Noise level=-87 dBm
          Link Quality=70/70  Signal level=-30 dBm  Noise level=-89 dBm
          Link Quality=70/70  Signal level=-30 dBm  Noise level=-88 dBm
          Link Quality=70/70  Signal level=-25 dBm  Noise level=-83 dBm
          Link Quality=70/70  Signal level=-23 dBm  Noise level=-84 dBm
          Link Quality=70/70  Signal level=-25 dBm  Noise level=-86 dBm
^C
Под виндами - то же самое, просто в линухе проще показать. По этой (я думаю) причине, пинг до самого маршрутизатора скачет иногда до 30-40ms.
В качестве клиента выступает ноут HP 6830s с Intel 5100ABG. Для эксперимента переносил ноут в комнату, где стоит маршрутизатор (это видно в листинге - Link Quality стало максимальным).
Как-нть можно забороть?
