Текущее время: Вс авг 30, 2026 09:32
 Заголовок сообщения: Разрыв WiFi-соеденения DIR-615
СообщениеДобавлено: Вс ноя 08, 2009 01:37
Подскажите пожалуйста в чем может быть проблема. Периодически рвется WiFi-соединение с нетбуком EeePC 901, причем периоды как я понял произвольные - бывает 1-2 раза в сутки, а бывает каждые 5-10 минут, пока не перезагрузиш роутер (уровень сигнала одинаковый). В логах как я понял ничего не пишется, вот куски логов во время разрывов:
[INFO] Sat Nov 07 23:49:58 2009 002: Wireless system with MAC address 002332F63019 disconnected for reason: Received Deauthentication
[WARN] Sat Nov 07 23:49:55 2009 A network computer (iPhone) was assigned the IP address of 192.168.0.198.
[INFO] Sat Nov 07 23:49:54 2009 002: Wireless system with MAC address 002332F63019 secured and linked
[INFO] Sat Nov 07 23:49:54 2009 002: Wireless system with MAC address 002332F63019 associated
[INFO] Sat Nov 07 23:49:54 2009 Above message repeated 1 times
[INFO] Sat Nov 07 23:49:16 2009 Log viewed by IP address 192.168.0.199
[INFO] Sat Nov 07 23:48:54 2009 Above message repeated 2 times
[WARN] Sat Nov 07 23:48:43 2009 A network computer (EeePC) was assigned the IP address of 192.168.0.199.
[INFO] Sat Nov 07 23:48:42 2009 002: Wireless system with MAC address 0015AFEF4AE4 secured and linked
[INFO] Sat Nov 07 23:48:42 2009 002: Wireless system with MAC address 0015AFEF4AE4 associated
[INFO] Sat Nov 07 23:48:42 2009 Above message repeated 1 times
[INFO] Sat Nov 07 23:48:09 2009 Blocked incoming UDP packet from 76.253.73.5:65534 to 95.182.104.248:65534
[INFO] Sat Nov 07 23:48:02 2009 Log viewed by IP address 192.168.0.199
[INFO] Sat Nov 07 23:48:01 2009 Stored configuration to non-volatile memory
[INFO] Sat Nov 07 23:48:00 2009 primary: Unlock AP setup
[INFO] Sun Nov 08 00:18:31 2009 Blocked incoming UDP packet from 76.253.73.5:65534 to 95.182.104.248:65534
[INFO] Sun Nov 08 00:18:07 2009 Blocked incoming UDP packet from 24.40.123.194:23575 to 95.182.104.248:55102
[INFO] Sun Nov 08 00:18:04 2009 Log viewed by IP address 192.168.0.199
[INFO] Sun Nov 08 00:17:56 2009 Allowed configuration authentication by IP address 192.168.0.199
[INFO] Sun Nov 08 00:17:54 2009 Blocked incoming UDP packet from 76.253.73.5:65534 to 95.182.104.248:65534
[WARN] Sun Nov 08 00:17:53 2009 Failed configuration authentication attempt by IP address 192.168.0.199
[INFO] Sun Nov 08 00:17:52 2009 Blocked incoming TCP connection request from 114.39.78.37:35587 to 95.182.104.248:14271
[INFO] Sun Nov 08 00:17:46 2009 Above message repeated 1 times
[INFO] Sun Nov 08 00:17:44 2009 Blocked incoming TCP connection request from 95.180.46.31:1336 to 95.182.104.248:445
[WARN] Sun Nov 08 00:17:41 2009 A network computer (EeePC) was assigned the IP address of 192.168.0.199.
[INFO] Sun Nov 08 00:17:40 2009 002: Wireless system with MAC address 0015AFEF4AE4 secured and linked
[INFO] Sun Nov 08 00:17:40 2009 Blocked incoming UDP packet from 77.222.147.222:32610 to 95.182.104.248:55102
[INFO] Sun Nov 08 00:17:40 2009 002: Wireless system with MAC address 0015AFEF4AE4 associated
[INFO] Sun Nov 08 00:17:40 2009 Above message repeated 1 times
[INFO] Sun Nov 08 00:17:38 2009 Blocked incoming TCP connection request from 95.180.46.31:1336 to 95.182.104.248:445
[INFO] Sun Nov 08 00:16:25 2009 Blocked incoming TCP connection request from 77.20.77.6:45352 to 95.182.104.248:15195
[INFO] Sun Nov 08 00:16:16 2009 Above message repeated 2 times
Скрин с настройками wifi тут
СообщениеДобавлено: Вс ноя 08, 2009 09:17
кормите его прошивочкой ))
СообщениеДобавлено: Вс ноя 08, 2009 11:49
Да забыл сказать, только вчера поставил последнюю 2.27RU, потом сбросил на заводские настройки, отключил QoS и Traffic Shaping, затем настроил. А WiFi как рвавля так и рвётся. В чем может быть проблема?
СообщениеДобавлено: Вс ноя 08, 2009 13:58
попробуйте эту DIR615B2_FW226RUB06.bin
СообщениеДобавлено: Вс ноя 08, 2009 18:24
Так она у меня до 2.27 стояла и точно такая же ситуация с разрывами. Хотя когда я перешивал с 2.25 на 2.26 не сбросил настройки в заводские, сейчас попробую откатиться на 2.26...
СообщениеДобавлено: Вт ноя 10, 2009 16:26
Какой адаптер стоит на EeePC 901 и какие под него драйвера?
