Текущее время: Пт окт 16, 2026 03:57
 Заголовок сообщения: DIR-615 ошибки по Wi-fi
СообщениеДобавлено: Сб сен 05, 2009 15:37
Прошивка DIR615B2_FW227RUB07Beta06
Wireless Statistics
Sent :
835197
TX Packets Dropped :
3
Received :
65117
RX Packets Dropped :
0
Errors :
1072
Log Details
Priority Time Message
[INFO] Sat Jan 31 11:55:25 2004 Log viewed by IP address 192.168.0.30
[INFO] Sat Jan 31 11:55:10 2004 Above message repeated 2 times
[INFO] Sat Jan 31 11:52:30 2004 Allowed configuration authentication by IP address 192.168.0.30
[INFO] Sat Jan 31 11:51:57 2004 Administrator logout
[INFO] Sat Jan 31 11:46:28 2004 Allowed configuration authentication by IP address 192.168.0.30
[INFO] Sat Jan 31 11:36:58 2004 Administrator logout
[INFO] Sat Jan 31 11:30:36 2004 Allowed configuration authentication by IP address 192.168.0.30
[INFO] Sat Jan 31 11:30:28 2004 Administrator logout
[INFO] Sat Jan 31 11:22:30 2004 dlink: Wireless system with MAC address 001B9E66CC1B associated
[INFO] Sat Jan 31 11:22:30 2004 Above message repeated 1 times
[INFO] Sat Jan 31 11:20:46 2004 Allowed configuration authentication by IP address 192.168.0.30
[INFO] Sat Jan 31 11:16:27 2004 dlink: Wireless system with MAC address 001B11C634D5 disconnected for reason: Received Deauthentication
[INFO] Sat Jan 31 11:13:48 2004 dlink: Wireless system with MAC address 001B11C634D5 associated
[INFO] Sat Jan 31 11:13:48 2004 Above message repeated 1 times
[INFO] Sat Jan 31 11:13:37 2004 Wireless link is up
[INFO] Sat Jan 31 11:13:25 2004 LAN interface is up
[INFO] Sat Jan 31 11:13:25 2004 LAN Ethernet Carrier Detected
[INFO] Sat Jan 31 11:13:24 2004 Device initialized
[WARN] Sat Jan 31 11:13:24 2004 Wireless schedule init
[INFO] Sat Jan 31 11:13:24 2004 primary: Unlock AP setup
[INFO] Sat Jan 31 11:13:24 2004 No Internet access policy is in effect. Unrestricted Internet access allowed to everyone
Wireless LAN
Wireless Radio :
Enabled
802.11 Mode :
Mixed 802.11n, 802.11g and 802.11b
Channel Width :
40MHz
Channel :
1
Secondary Channel :
5
Wi-Fi Protected Setup :
Enabled/Configured
СообщениеДобавлено: Сб сен 05, 2009 23:29
И что? Где вопрос (нейм темы не катит - какие именно ошибки)?
Для начала - выставьте защиту на WPA Personal - WPA only/TKIP и заново введите Pass на роутере и компе. Плюс проверьте уровень сигнала. Плюс выставьте режим 802.11g only (если, конечно, ваши карты не n-Draft - тогда g/n mix).
СообщениеДобавлено: Вс сен 06, 2009 09:33
всё это делалось не помогает
ошибки по WI-FI в первом логе
Errors : 1072
из за них и скорость не больше 2000 kb /s по WI-FI
Вопрос почему они идут? аппаратный или программный сбой?
пробовали на четырёх разных каратах
СообщениеДобавлено: Пн сен 07, 2009 09:03
Я не очень разбираюсь в этих логах :oops: , но мне кажется, что наши проблемы одного характера (6-й ответ сверху): viewtopic.php?p=553594#553594
DSL-2500U/BRU/D -> DSL-2540U/BRU/D -> DSL-2640U/BRU/C -> D-600g (Asus) -> DSL-2650U/BRU/D -> DIR-615
СообщениеДобавлено: Пн сен 07, 2009 14:03
А адаптеры какие?Если стандарта 802.11g,то ждать больше 2-3мбайт\с не стоит.
И ни слова о топологии,видимости,и т.д......
А ошибки... может рабочий канал перегружен
СообщениеДобавлено: Вт сен 08, 2009 09:15
адаптеры 802.11g, макс. скорость на другой точке 3,5 мбайт\с (D-link DSL-2640 U) стабильно, а на dir -615 она плавает от 350 кб\с до 2000 кб\с, соответственно и ошибки сыплются больше когда скорость ниже.
всё тестится рядом с точкой, сигнал 100%, рядом нет других сетей WI-FI, каналы менялись.
СообщениеДобавлено: Вт сен 08, 2009 15:29
Настраивали и прошивали через какой браузер? После перепрошивки скидывали до заводских настроек?
СообщениеДобавлено: Ср сен 09, 2009 20:13
Ну, во первых это может и не так много.
Sent : 835197 -> Errors :1072
Во вторых, это устройство нужно правильно настроить. Если выбирать 802.11 Mode : Mixed, да еще и канал в 40MHz, то как будет нормально работать адаптеры 802.11g ?
Обновите роутер по правилу: СОСНА (Сброс, Обновление, Сброс НАстройка) используя IE
Выставьте 802.11 Mode: Only g
По поводу скорости, это смотря как мерить. По стандарту 2,5 -3 мегабайт/c это просто шикарно
СообщениеДобавлено: Ср сен 09, 2009 21:56
Да нормально работают g-адаптеры на полосе в 40 МГц - это же расширение диапазона 2х20 - один - основной, где и g висит, второй - для n-Draft. И g/n mix работает даже лучше, чем Only g или Only n.
Последний раз редактировалось AndreTM Пт сен 11, 2009 06:32, всего редактировалось 1 раз.
СообщениеДобавлено: Чт сен 10, 2009 07:50
Вообще то, g-адаптеры физически не могут работать на полосе в 40МГц.
А вот по правилу 2*20МГц могут, а человек не указал, что там именно 2*20. :)
СообщениеДобавлено: Пт сен 11, 2009 10:55
всё так и делал, ошибки всё равно идут, заметил, что если смотреть IP-TV через WI-FI то всё нормально, ошибок нет
вот файл в 2 Гб. прокачал
Wireless Statistics
Sent : 1552566
TX Packets Dropped : 0
Received : 810988
RX Packets Dropped : 0
Errors : 7106
Сейчас этот форум просматривают: Baidu [Spider] и гости: 49
