Текущее время: Чт сен 17, 2026 06:31
 Заголовок сообщения: Теряет соединение d-link dir-615
СообщениеДобавлено: Пт апр 15, 2011 10:22
Провайдер Белтелеком в Минске. Настроен на 2 pppoe соединения маршрутизатор. Теряет соединение раз в минуту - три. Вот лог роутера :
[INFO] Fri Apr 15 10:20:24 2011 Log viewed by IP address 192.168.0.199
[INFO] Fri Apr 15 10:20:20 2011 Allowed configuration authentication by IP address 192.168.0.199
[INFO] Fri Apr 15 10:20:17 2011 UPnP renew entry 255.255.255.255 <-> 192.168.1.2:64971 <-> 178.120.24.204:64971 UDP timeout:0 'Teredo'
[INFO] Fri Apr 15 10:17:50 2011 Above message repeated 4 times
[INFO] Fri Apr 15 10:17:26 2011 Bringing up WAN using Static IP Address
[INFO] Fri Apr 15 10:17:26 2011 WAN interface cable has been connected
[INFO] Fri Apr 15 10:17:25 2011 WAN interface cable has been disconnected
[INFO] Fri Apr 15 10:17:16 2011 UPnP renew entry 255.255.255.255 <-> 192.168.1.2:64971 <-> 178.120.24.204:64971 UDP timeout:0 'Teredo'
[INFO] Fri Apr 15 10:04:15 2011 Above message repeated 23 times
[INFO] Fri Apr 15 10:04:15 2011 Bringing up WAN using Static IP Address
[INFO] Fri Apr 15 10:04:15 2011 WAN interface cable has been connected
[INFO] Fri Apr 15 10:04:13 2011 WAN interface cable has been disconnected
[INFO] Fri Apr 15 10:03:33 2011 UPnP renew entry 255.255.255.255 <-> 192.168.1.2:64971 <-> 178.120.24.204:64971 UDP timeout:0 'Teredo'
[INFO] Fri Apr 15 09:55:11 2011 Above message repeated 13 times
[INFO] Fri Apr 15 09:55:08 2011 Bringing up WAN using Static IP Address
[INFO] Fri Apr 15 09:55:08 2011 WAN interface cable has been connected
[INFO] Fri Apr 15 09:55:06 2011 WAN interface cable has been disconnected
[INFO] Fri Apr 15 09:55:05 2011 UPnP renew entry 255.255.255.255 <-> 192.168.1.2:64971 <-> 178.120.24.204:64971 UDP timeout:0 'Teredo'
[INFO] Fri Apr 15 09:55:04 2011 Above message repeated 1 times
[INFO] Fri Apr 15 09:55:03 2011 Bringing up WAN using Static IP Address
[INFO] Fri Apr 15 09:55:03 2011 WAN interface cable has been connected
[INFO] Fri Apr 15 09:55:02 2011 WAN interface cable has been disconnected
[INFO] Fri Apr 15 09:54:22 2011 UPnP renew entry 255.255.255.255 <-> 192.168.1.2:64971 <-> 178.120.24.204:64971 UDP timeout:0 'Teredo'
[INFO] Fri Apr 15 09:47:38 2011 Above message repeated 11 times
[INFO] Fri Apr 15 09:47:18 2011 Administrator logout
[INFO] Fri Apr 15 09:47:04 2011 UPnP renew entry 255.255.255.255 <-> 192.168.1.2:64971 <-> 178.120.24.204:64971 UDP timeout:0 'Teredo'
[INFO] Fri Apr 15 09:45:51 2011 Above message repeated 2 times
[INFO] Fri Apr 15 09:45:42 2011 Bringing up WAN using Static IP Address
[INFO] Fri Apr 15 09:45:42 2011 WAN interface cable has been connected
[INFO] Fri Apr 15 09:45:40 2011 WAN interface cable has been disconnected
[INFO] Fri Apr 15 09:45:11 2011 UPnP renew entry 255.255.255.255 <-> 192.168.1.2:64971 <-> 178.120.24.204:64971 UDP timeout:0 'Teredo'
[INFO] Fri Apr 15 09:44:40 2011 Bringing up WAN using Static IP Address
[INFO] Fri Apr 15 09:44:40 2011 WAN interface cable has been connected
[INFO] Fri Apr 15 09:44:39 2011 WAN interface cable has been disconnected
[INFO] Fri Apr 15 09:43:55 2011 UPnP renew entry 255.255.255.255 <-> 192.168.1.2:64971 <-> 178.120.24.204:64971 UDP timeout:0 'Teredo'
[INFO] Fri Apr 15 09:43:43 2011 Bringing up WAN using Static IP Address
[INFO] Fri Apr 15 09:43:43 2011 WAN interface cable has been connected
[INFO] Fri Apr 15 09:43:41 2011 WAN interface cable has been disconnected
[INFO] Fri Apr 15 09:43:32 2011 Bringing up WAN using Static IP Address
[INFO] Fri Apr 15 09:43:32 2011 WAN interface cable has been connected
[INFO] Fri Apr 15 09:43:30 2011 WAN interface cable has been disconnected
[INFO] Fri Apr 15 09:43:19 2011 UPnP renew entry 255.255.255.255 <-> 192.168.1.2:64971 <-> 178.120.24.204:64971 UDP timeout:0 'Teredo'
[INFO] Fri Apr 15 09:42:46 2011 Bringing up WAN using Static IP Address
[INFO] Fri Apr 15 09:42:46 2011 WAN interface cable has been connected
[INFO] Fri Apr 15 09:42:45 2011 WAN interface cable has been disconnected
[INFO] Fri Apr 15 09:42:44 2011 UPnP renew entry 255.255.255.255 <-> 192.168.1.2:64971 <-> 178.120.24.204:64971 UDP timeout:0 'Teredo'
[INFO] Fri Apr 15 09:42:12 2011 Bringing up WAN using Static IP Address
[INFO] Fri Apr 15 09:42:12 2011 WAN interface cable has been connected
[INFO] Fri Apr 15 09:42:11 2011 WAN interface cable has been disconnected
[INFO] Fri Apr 15 09:42:07 2011 Log viewed by IP address 192.168.0.199
[INFO] Fri Apr 15 09:42:07 2011 UPnP renew entry 255.255.255.255 <-> 192.168.1.2:64971 <-> 178.120.24.204:64971 UDP timeout:0 'Teredo'
[INFO] Fri Apr 15 09:42:04 2011 Above message repeated 2 times
[INFO] Fri Apr 15 09:42:03 2011 Allowed configuration authentication by IP address 192.168.0.199
[INFO] Fri Apr 15 09:42:03 2011 Bringing up WAN using Static IP Address
[INFO] Fri Apr 15 09:42:03 2011 WAN interface cable has been connected
[INFO] Fri Apr 15 09:42:01 2011 WAN interface cable has been disconnected
[INFO] Fri Apr 15 09:41:39 2011 Bringing up WAN using Static IP Address
[INFO] Fri Apr 15 09:41:39 2011 WAN interface cable has been connected
[INFO] Fri Apr 15 09:41:37 2011 WAN interface cable has been disconnected
[INFO] Fri Apr 15 09:41:23 2011 UPnP renew entry 255.255.255.255 <-> 192.168.1.2:64971 <-> 178.120.24.204:64971 UDP timeout:0 'Teredo'
[INFO] Fri Apr 15 09:40:06 2011 Above message repeated 2 times
[INFO] Fri Apr 15 09:39:42 2011 Stored configuration to non-volatile memory
[INFO] Sat Jan 31 11:38:04 2004 UPnP renew entry 255.255.255.255 <-> 192.168.1.2:64971 <-> 178.120.24.204:64971 UDP timeout:0 'Teredo'
[INFO] Sat Jan 31 11:37:56 2004 Allowed configuration authentication by IP address 192.168.0.199
[INFO] Sat Jan 31 11:37:31 2004 UPnP renew entry 255.255.255.255 <-> 192.168.1.2:64971 <-> 178.120.24.204:64971 UDP timeout:0 'Teredo'
[INFO] Sat Jan 31 11:33:13 2004 Above message repeated 7 times
[INFO] Sat Jan 31 11:32:41 2004 Bringing up WAN using Static IP Address
[INFO] Sat Jan 31 11:32:41 2004 WAN interface cable has been connected
[INFO] Sat Jan 31 11:32:40 2004 WAN interface cable has been disconnected
[INFO] Sat Jan 31 11:32:07 2004 UPnP renew entry 255.255.255.255 <-> 192.168.1.2:64971 <-> 178.120.24.204:64971 UDP timeout:0 'Teredo'
[INFO] Sat Jan 31 11:30:58 2004 Above message repeated 3 times
[INFO] Sat Jan 31 11:30:56 2004 Bringing up WAN using Static IP Address
[INFO] Sat Jan 31 11:30:56 2004 WAN interface cable has been connected
[INFO] Sat Jan 31 11:30:55 2004 WAN interface cable has been disconnected
[INFO] Sat Jan 31 11:30:25 2004 UPnP renew entry 255.255.255.255 <-> 192.168.1.2:64971 <-> 178.120.24.204:64971 UDP timeout:0 'Teredo'
[INFO] Sat Jan 31 11:16:42 2004 Above message repeated 19 times
[INFO] Sat Jan 31 11:16:41 2004 Bringing up WAN using Static IP Address
[INFO] Sat Jan 31 11:16:41 2004 WAN interface cable has been connected
[INFO] Sat Jan 31 11:16:40 2004 WAN interface cable has been disconnected
[INFO] Sat Jan 31 11:16:07 2004 UPnP renew entry 255.255.255.255 <-> 192.168.1.2:64971 <-> 178.120.24.204:64971 UDP timeout:0 'Teredo'
[INFO] Sat Jan 31 11:16:04 2004 Above message repeated 2 times
[INFO] Sat Jan 31 11:16:03 2004 Bringing up WAN using Static IP Address
[INFO] Sat Jan 31 11:16:03 2004 WAN interface cable has been connected
[INFO] Sat Jan 31 11:16:02 2004 WAN interface cable has been disconnected
[INFO] Sat Jan 31 11:15:48 2004 Bringing up WAN using Static IP Address
[INFO] Sat Jan 31 11:15:48 2004 WAN interface cable has been connected
[INFO] Sat Jan 31 11:15:47 2004 WAN interface cable has been disconnected
[INFO] Sat Jan 31 11:15:32 2004 UPnP renew entry 255.255.255.255 <-> 192.168.1.2:64971 <-> 178.120.24.204:64971 UDP timeout:0 'Teredo'
[INFO] Sat Jan 31 11:15:21 2004 Bringing up WAN using Static IP Address
[INFO] Sat Jan 31 11:15:21 2004 WAN interface cable has been connected
[INFO] Sat Jan 31 11:15:19 2004 WAN interface cable has been disconnected
[INFO] Sat Jan 31 11:14:23 2004 Bringing up WAN using Static IP Address
[INFO] Sat Jan 31 11:14:23 2004 WAN interface cable has been connected
[INFO] Sat Jan 31 11:14:21 2004 WAN interface cable has been disconnected
[INFO] Sat Jan 31 11:14:18 2004 UPnP renew entry 255.255.255.255 <-> 192.168.1.2:64971 <-> 178.120.24.204:64971 UDP timeout:0 'Teredo'
[INFO] Sat Jan 31 11:13:39 2004 Bringing up WAN using Static IP Address
[INFO] Sat Jan 31 11:13:39 2004 WAN interface cable has been connected
[INFO] Sat Jan 31 11:13:38 2004 WAN interface cable has been disconnected
[INFO] Sat Jan 31 11:13:00 2004 UPnP renew entry 255.255.255.255 <-> 192.168.1.2:64971 <-> 178.120.24.204:64971 UDP timeout:0 'Teredo'
[INFO] Sat Jan 31 11:11:45 2004 Above message repeated 2 times
[INFO] Sat Jan 31 11:11:32 2004 Bringing up WAN using Static IP Address
[INFO] Sat Jan 31 11:11:32 2004 WAN interface cable has been connected
[INFO] Sat Jan 31 11:11:31 2004 WAN interface cable has been disconnected
[INFO] Sat Jan 31 11:11:05 2004 UPnP renew entry 255.255.255.255 <-> 192.168.1.2:64971 <-> 178.120.24.204:64971 UDP timeout:0 'Teredo'
[INFO] Sat Jan 31 11:10:30 2004 Above message repeated 1 times
[INFO] Sat Jan 31 11:10:15 2004 Bringing up WAN using Static IP Address
[INFO] Sat Jan 31 11:10:15 2004 WAN interface cable has been connected
[INFO] Sat Jan 31 11:10:13 2004 WAN interface cable has been disconnected
[INFO] Sat Jan 31 11:09:54 2004 UPnP renew entry 255.255.255.255 <-> 192.168.1.2:64971 <-> 178.120.24.204:64971 UDP timeout:0 'Teredo'
[INFO] Sat Jan 31 11:08:34 2004 Above message repeated 2 times
[INFO] Sat Jan 31 11:08:29 2004 Bringing up WAN using Static IP Address
[INFO] Sat Jan 31 11:08:29 2004 WAN interface cable has been connected
[INFO] Sat Jan 31 11:08:27 2004 WAN interface cable has been disconnected
[INFO] Sat Jan 31 11:08:04 2004 Bringing up WAN using Static IP Address
[INFO] Sat Jan 31 11:08:04 2004 WAN interface cable has been connected
[INFO] Sat Jan 31 11:08:02 2004 WAN interface cable has been disconnected
[INFO] Sat Jan 31 11:07:58 2004 UPnP renew entry 255.255.255.255 <-> 192.168.1.2:64971 <-> 178.120.24.204:64971 UDP timeout:0 'Teredo'
[INFO] Sat Jan 31 11:01:04 2004 Above message repeated 4 times
[INFO] Sat Jan 31 10:57:46 2004 Bringing up WAN using Static IP Address
[INFO] Sat Jan 31 10:57:46 2004 WAN interface cable has been connected
[INFO] Sat Jan 31 10:57:45 2004 WAN interface cable has been disconnected
[INFO] Sat Jan 31 10:57:40 2004 Bringing up WAN using Static IP Address
[INFO] Sat Jan 31 10:57:40 2004 WAN interface cable has been connected
[INFO] Sat Jan 31 10:57:38 2004 WAN interface cable has been disconnected
[INFO] Sat Jan 31 10:57:06 2004 UPnP deleted entry 255.255.255.255 <-> 192.168.1.2:57474 UDP
[INFO] Sat Jan 31 10:57:06 2004 UPnP deleted entry 255.255.255.255 <-> 192.168.1.2:57474 TCP
[INFO] Sat Jan 31 10:55:17 2004 UPnP renew entry 255.255.255.255 <-> 192.168.1.2:64971 <-> 178.120.24.204:64971 UDP timeout:0 'Teredo'
[INFO] Sat Jan 31 10:52:10 2004 Above message repeated 1 times
[INFO] Sat Jan 31 10:48:30 2004 Administrator logout
[INFO] Sat Jan 31 10:47:40 2004 UPnP added entry 255.255.255.255 <-> 192.168.1.2:57474 <-> 178.120.24.204:57474 UDP timeout:0 'uTorrent (UDP)'
[INFO] Sat Jan 31 10:47:40 2004 UPnP added entry 255.255.255.255 <-> 192.168.1.2:57474 <-> 178.120.24.204:57474 TCP timeout:0 'uTorrent (TCP)'
[INFO] Sat Jan 31 10:47:12 2004 Bringing up WAN using Static IP Address
[INFO] Sat Jan 31 10:47:12 2004 WAN interface cable has been connected
[INFO] Sat Jan 31 10:47:11 2004 WAN interface cable has been disconnected
[INFO] Sat Jan 31 10:46:52 2004 Bringing up WAN using Static IP Address
[INFO] Sat Jan 31 10:46:52 2004 WAN interface cable has been connected
[INFO] Sat Jan 31 10:46:50 2004 WAN interface cable has been disconnected
[INFO] Sat Jan 31 10:46:40 2004 UPnP renew entry 255.255.255.255 <-> 192.168.1.2:64971 <-> 178.120.24.204:64971 UDP timeout:0 'Teredo'
[INFO] Sat Jan 31 10:46:29 2004 Bringing up WAN using Static IP Address
[INFO] Sat Jan 31 10:46:29 2004 WAN interface cable has been connected
[INFO] Sat Jan 31 10:46:27 2004 WAN interface cable has been disconnected
[INFO] Sat Jan 31 10:46:18 2004 Bringing up WAN using Static IP Address
[INFO] Sat Jan 31 10:46:18 2004 WAN interface cable has been connected
[INFO] Sat Jan 31 10:46:16 2004 WAN interface cable has been disconnected
[INFO] Sat Jan 31 10:46:06 2004 Bringing up WAN using Static IP Address
[INFO] Sat Jan 31 10:46:06 2004 WAN interface cable has been connected
[INFO] Sat Jan 31 10:46:04 2004 WAN interface cable has been disconnected
[INFO] Sat Jan 31 10:45:35 2004 UPnP renew entry 255.255.255.255 <-> 192.168.1.2:64971 <-> 178.120.24.204:64971 UDP timeout:0 'Teredo'
[INFO] Sat Jan 31 10:45:34 2004 Above message repeated 1 times
[INFO] Sat Jan 31 10:44:26 2004 Bringing up WAN using Static IP Address
[INFO] Sat Jan 31 10:44:26 2004 WAN interface cable has been connected
[INFO] Sat Jan 31 10:44:24 2004 WAN interface cable has been disconnected
[INFO] Sat Jan 31 10:44:23 2004 Bringing up WAN using Static IP Address
[INFO] Sat Jan 31 10:44:23 2004 WAN interface cable has been connected
[INFO] Sat Jan 31 10:44:21 2004 WAN interface cable has been disconnected
[INFO] Sat Jan 31 10:44:08 2004 Bringing up WAN using Static IP Address
[INFO] Sat Jan 31 10:44:08 2004 WAN interface cable has been connected
[INFO] Sat Jan 31 10:44:07 2004 WAN interface cable has been disconnected
[INFO] Sat Jan 31 10:44:00 2004 Bringing up WAN using Static IP Address
[INFO] Sat Jan 31 10:44:00 2004 WAN interface cable has been connected
[INFO] Sat Jan 31 10:43:58 2004 WAN interface cable has been disconnected
[INFO] Sat Jan 31 10:43:44 2004 Bringing up WAN using Static IP Address
[INFO] Sat Jan 31 10:43:44 2004 WAN interface cable has been connected
[INFO] Sat Jan 31 10:43:42 2004 WAN interface cable has been disconnected
[INFO] Sat Jan 31 10:43:30 2004 Bringing up WAN using Static IP Address
[INFO] Sat Jan 31 10:43:30 2004 WAN interface cable has been connected
[INFO] Sat Jan 31 10:43:28 2004 WAN interface cable has been disconnected
[INFO] Sat Jan 31 10:43:27 2004 Bringing up WAN using Static IP Address
[INFO] Sat Jan 31 10:43:27 2004 WAN interface cable has been connected
[INFO] Sat Jan 31 10:43:25 2004 WAN interface cable has been disconnected
[INFO] Sat Jan 31 10:43:24 2004 Bringing up WAN using Static IP Address
[INFO] Sat Jan 31 10:43:24 2004 WAN interface cable has been connected
[INFO] Sat Jan 31 10:43:23 2004 WAN interface cable has been disconnected
[INFO] Sat Jan 31 10:42:33 2004 Bringing up WAN using Static IP Address
[INFO] Sat Jan 31 10:42:33 2004 WAN interface cable has been connected
[INFO] Sat Jan 31 10:42:31 2004 WAN interface cable has been disconnected
[INFO] Sat Jan 31 10:41:18 2004 Allowed configuration authentication by IP address 192.168.0.199
[INFO] Sat Jan 31 10:40:30 2004 Bringing up WAN using Static IP Address
[INFO] Sat Jan 31 10:40:30 2004 WAN interface cable has been connected
[INFO] Sat Jan 31 10:40:28 2004 WAN interface cable has been disconnected
[INFO] Sat Jan 31 10:40:27 2004 Bringing up WAN using Static IP Address
[INFO] Sat Jan 31 10:40:27 2004 WAN interface cable has been connected
[INFO] Sat Jan 31 10:40:25 2004 WAN interface cable has been disconnected
[INFO] Sat Jan 31 10:39:57 2004 UPnP added entry 255.255.255.255 <-> 192.168.1.2:64971 <-> 178.120.24.204:64971 UDP timeout:0 'Teredo'
[INFO] Sat Jan 31 10:39:35 2004 Bringing up WAN using Static IP Address
[INFO] Sat Jan 31 10:39:35 2004 WAN interface cable has been connected
[INFO] Sat Jan 31 10:39:34 2004 WAN interface cable has been disconnected
[WARN] Sat Jan 31 10:39:32 2004 A network computer () was assigned the IP address of 192.168.0.199.
[INFO] Sat Jan 31 10:39:29 2004 Wireless link is up
[INFO] Sat Jan 31 10:39:27 2004 Unable to find DNS record for firmware upgrade server wrpd.dlink.com.tw
[INFO] Sat Jan 31 10:39:26 2004 Starting DHCP server
[INFO] Sat Jan 31 10:39:18 2004 Bringing up WAN using Static IP Address
[INFO] Sat Jan 31 10:39:18 2004 WAN interface cable has been connected
[INFO] Sat Jan 31 10:39:17 2004 LAN interface is up
[INFO] Sat Jan 31 10:39:17 2004 LAN Ethernet Carrier Detected
[INFO] Sat Jan 31 10:39:16 2004 Device initialized
[WARN] Sat Jan 31 10:39:16 2004 Wireless schedule init
[INFO] Sat Jan 31 10:39:16 2004 No Internet access policy is in effect. Unrestricted Internet access allowed to everyone
Hardware Version: B2 Firmware Version: 2.27RU
 Заголовок сообщения: Re: Теряет соединение d-link dir-615
СообщениеДобавлено: Сб апр 16, 2011 11:08
Может быть, вы являетесь абонентом byfly, а не Белтелекома, всё же.
Опишите конкретней настройки роутера, включая и настройки ADSL-модема. Что там у вас за модель – Промсвязь?
В моделях DIR нет возможности реализовать 2 PPPoE соединения, пишите правильно, гостевое соединение - модем, основное - роутер, или как там у вас настроено?
Я бы вам советовал перенастроить модем в режим бридж, а в роутере уже настраивать PPPoE соединение. Либо роутер использовать как точку доступа, а модем перенастроить в режим "ROUTER".
http://ftp.byfly.by/byfly/Byfly_by.rar
СообщениеДобавлено: Пн апр 18, 2011 00:18
Byfly = Белтелеком. Настройки роутера кину ниже. ADSL- модем настроен в режиме роутера на гостевое соединение. Марка модема "Промсвязь" DIR поддерживает 2 PPPoE соединения. Проверено.
Делал... всё равно теряет соединение как на Логе выше.
Настройки: Изображение
192.168.1.1 - IP модема
СообщениеДобавлено: Пн апр 18, 2011 01:40
Маршрутизаторы DIR не умеют устанавливать одновременно два PPPoE соединения. Вы путаете с технологией Dual Access, а это совершенно разные вещи.
Поменяйте в модеме гостевое на основное, а роутер DIR 615 используйте просто в качестве точки доступа. Будет работать всё стабильно.
СообщениеДобавлено: Пн апр 18, 2011 07:20
интернет есть на роутере только тогда, когда стоят настройки как на скрине или просто Static ip. но в обоих случаях он ведёт себя одинакого т.е. разъединяет соединение.
СообщениеДобавлено: Пн апр 18, 2011 08:16
Зачем два раза NATите соединение? Кабель от модема подключите в любой Lan порт роутера, ничего не нужно подключать к порту Internet (WAN) на маршрутизаторе D-Link. Отключите DHCP в роутере, UPnP также отключите, измените IP-адрес LAN на доступный адрес сети. На компьютерах сетевые карточки настраиваем привычным для вас способом – ручками.
Не повезло вам, так как уже в новых моделях DIR 615 реализована возможность переключения в режим Bridge, в вашей модели такой возможности нет.
СообщениеДобавлено: Пн апр 18, 2011 15:26
Т.е. прошивкой это не меняется, насколько я понял. Только в версиях D и E?
можно поподробнее?
