Текущее время: Ср ноя 11, 2026 19:18
 Заголовок сообщения: Re: Помогите настроить D-link 2100 ap
СообщениеДобавлено: Ср мар 02, 2011 14:28
Прошил вот конфиг
что подправить в нем
get 11gonly
11g Only Allowed: Enabled
D-Link Access Point wlan1 -> get config
wlan1 revisions: mac 5.8 phy 4.4 analog 4.6
PCI Vendor ID: 0x168c, Device ID: 0x13
Sub Vendor ID: 0x168c, Sub Device ID: 0x13
chip is AR2312
Country Code: US
Operation Mode: Access Point
Wlan State: Enabled
Radio Frequency: 2427 MHz (IEEE 4)
Wireless LAN Mode: 802.11g
Auto Channel Select: Disabled
Extended Channel Mode: Enabled
Data Rate: best
Antenna: best
Login Username: admin
RADIUS address:
Name server IP address:
Name server domain suffix:
SSID: app service net
SSID Suppress Mode: Disabled
System Name: D-Link Access Point
Beacon Interval: 100
DTIM: 1
Fragmentation Threshold: 2346
RTS/CTS Threshold: 2346
Short Preamble: Enabled
CTS Mode: AUTO
CTS Rate: 11 Mbps
CTS Type: CTS-ONLY
11g Overlapping BSS Protection: Disabled
11g Beacon Rate: 1 Mbps
11g Draft 5.0 compatibility: Disabled
Short Slot Time: Enabled
Basic 11g Rate Set: (1, 2, 5.5, 11, 6, 12, 24)
11g Optimization Level: 1
Burst Time: 2
Burst Sequence Threshold: 3
IP Address: 192.168.0.50
IP Mask: 255.255.255.0
Host IP Address: 0.0.0.0
Gateway IP Address: 0.0.0.0
SNTP/NTP Server IP Address:
Time Zone: 27
HW Transmit Retry Limit: 4
SW Transmit Retry Limit: 3
TransmitPower: full
Current Transmit Output Power 20.0 dBm
SuperG :Disabled
Encryption: Enabled
Cipher selection: WEP
Authentication Type: Open-System
Default transmit key: 1
Shared Key 1, size 40, 3465581421
Access Check: Disabled
Key Entry Method: hexadecimal
Group Key Update Interval: 1800 seconds
Key Source: flash
Aging Interval: 300 seconds
Telnet Access: Enabled
Telnet Timeout: 180 seconds
Minimum rate: 1 Mbps
XR Poll interval: 100 msec
XR Frame Limit: 25
XR Poll Rate String is 0.25 1 1 3 3 6 6 20
XR Fragmentation Threshold: 540
СообщениеДобавлено: Ср мар 02, 2011 14:34
а если прошить в DWL-3200AP_FWv255-rc515.tfp а не в 2.50
СообщениеДобавлено: Ср мар 02, 2011 15:40
Прошивал, но почему-то отказался. Непомню почему. Берите 2,50
DWL-2100AP, DIR-300 (ddwrt), DSL-504T, DIR-100, DSL-2500, DP-301U, DES-1024D/E, DWA-510, ANT-0700
СообщениеДобавлено: Ср мар 02, 2011 18:16
Прошил 2.50 конфиг приведен выше что нить изменить нужно в нем 8)
СообщениеДобавлено: Ср мар 02, 2011 19:10
включено 11ж онли, а надо ли? Мб всетаки потести 11б онли?
Antenna: best надо в теленете set antenna 1
Пока больше ничего не вижу
СообщениеДобавлено: Пт мар 04, 2011 09:22
Как у нас дела?
СообщениеДобавлено: Пт мар 04, 2011 09:25
могу вам еще предложить точнее антенны юстировать с помощью программы APM by Acowa, в ней это можно сделать очень удобно и качественно по уровням rx, tx
СообщениеДобавлено: Чт мар 24, 2011 09:51
чей то я пытался прошить 2100 в 3200, ну никаком не шьется...
Remote File-> apimg1
Local File-> apimg1
download or upload-> download
Waiting for cfg file to finish writing...Getting anonymous@192.168.0.:apimg1 -> apimg1
ftp connection failed
через FTP Programmer родные прошивки от 2100 льются норм...
в чем может быть загвоздка?...
cron
