Текущее время: Ср сен 16, 2026 02:04
СообщениеДобавлено: Пт май 13, 2005 14:40
Две одинаковые точки.
Режим WDS сотня метров, прямая видимость.
Имеем такую статистику на одном конце:
WLAN 802.11G Traffic Statistics
Throughput
Transmit Success Rate 48 %
Transmit Retry Rate 0 %
Receive Success Rate 18 %
Receive Duplicate Rate 21 %
RTS Success Count 0
RTS Failure Count 12522
Transmitted Frame Count
Transmitted Frame Count 10873
Multicast Transmitted Frame Count 5
Transmitted Error Count 12098
Transmitted Total Retry Count 0
Transmitted Multiple Retry Count 0
Received Frame Count
Received Frame Count 2713
Multicast Received Frame Count 0
Received Frame FCS Error Count 12522
Received Frame Duplicate Count 755
Ack Rcv failure Count 8634
Wep Frame Error Count
WEP Excluded Frame Count 0
WEP ICV Error Count 0
И такую на другом:
Throughput
Transmit Success Rate 97 %
Receive Success Rate 79 %
Receive Duplicate Rate 16 %
RTS Success Count 0
RTS Failure Count 75
Transmitted Frame Count 1046
Multicast Transmitted Frame Count 1
Transmitted Error Count 38
Received Frame Count 275
Received Frame FCS Error Count 75
Received Frame Duplicate Count 56
Ack Rcv failure Count 164
В чем может быть проблема?
СообщениеДобавлено: Сб май 14, 2005 08:45
Сейчас такую статистику показывает...
Throughput
Transmit Success Rate 80 %
Receive Success Rate 1 %
Receive Duplicate Rate 69 %
RTS Success Count 0
RTS Failure Count 66986
Transmitted Frame Count 16072
Transmitted Error Count 4182
Received Frame Count 314
Received Frame FCS Error Count 66986
Received Frame Duplicate Count 716
Ack Rcv failure Count 5523
СообщениеДобавлено: Вс май 15, 2005 14:10
Статистика ничто ЖАЖДА всё! Вобщем опишите сипмптомы. Чтов действительности наблюдаете?
D-Link User: DGS-3612G, DES-3350SR, DES-3526, DES-3028, DES-3010G, DES-1210-28, DES-2110, DWL-900AP+, DWL-1000AP+, DWL-1040AP+, DWL-2100AP, DI-634M, DWL-G520M, DWL-G650M, DWL-G650, DAS-3248, DSL-300T, DSL-500T, DSL-504T, DMC-920, DCS-2101, DCS-910.
СообщениеДобавлено: Вс май 15, 2005 14:14
Наблюдаю хреновую работу вплоть до пропадания связи. Наблюдаю нестабильный пинг, доходящий до секунды. Да и статистика сама по себе нехорошенькая...
СообщениеДобавлено: Вс май 15, 2005 18:43
какой конфиг точек?
СообщениеДобавлено: Пн май 16, 2005 07:40
Mode WDS
SSID default
SSID broadcast enable
Authentification Open system
Encription enabled
Key size 152 bits
IP static
Data rate auto
Beacon Interval 100
DTIM 1
Fragment Length 2346
RTS Length 2346
Transmit Power full
Super G Mode disabled
802.11g Only enabled
Radio Wave on
DHCP server disabled
Multi SSID нет
Firmware 2.10eu
СообщениеДобавлено: Пн май 16, 2005 08:13
А растояние то какое?
СообщениеДобавлено: Пн май 16, 2005 08:25
150-200 м. прямая видимость.
СообщениеДобавлено: Пн май 16, 2005 10:00
Mode WDS
SSID default
Encription enabled
Key size 152 bits
IP static
Data rate auto
Beacon Interval 100
DTIM 1
RTS Length 2346
Transmit Power full
Radio Wave on
Multi SSID нет
Firmware 2.10eu
WEP включен?
СообщениеДобавлено: Пн май 16, 2005 11:21
Encription enabled
Key size 152 bits
WEP включен?
Вроде, написано... Или это не о том?
СообщениеДобавлено: Пн май 16, 2005 14:26
Encription enabled
Key size 152 bits
WEP включен?
отключи WEP
СообщениеДобавлено: Пн май 16, 2005 14:41
отключи WEP
Так это каждый, кто захочет, сможет подсоединиться... Не секьюрно как-то...
СообщениеДобавлено: Пн май 16, 2005 14:43
И вообще, с чего бы это из-за шифрования пакеты дублировались...
СообщениеДобавлено: Вт май 17, 2005 06:32
Сделай сборос на дефаулт, зайди в телнет и сделай как описанно в http://forum.networks.kz/viewtopic.php?t=9 софт только желательно обновить до последнего.
