Текущее время: Пт сен 18, 2026 13:57
 Заголовок сообщения: 524 постоянные дисконекты WiFi
СообщениеДобавлено: Ср янв 16, 2008 01:23
вообщем мучают дисконекты на ноуте.... вот логи ...прошивка 2.06RU
после дисконекта очень друдно пробиться..
System Logs
Wed Jan 16 00:07:46 2008 Associated: 00-1C-BF-19-9F-E3 st=0
Wed Jan 16 00:07:48 2008 Syn time: Wed Jan 16 00:07:48 2008
Wed Jan 16 00:36:27 2008 Reassociated: 00-1C-BF-19-9F-E3 st=0
Wed Jan 16 00:36:32 2008 Disassociated: 00-1C-BF-19-9F-E3 because RX deauth req
Wed Jan 16 00:39:58 2008 Associated: 00-1C-BF-19-9F-E3 st=0
Wed Jan 16 00:40:09 2008 Disassociated: 00-1C-BF-19-9F-E3 because RX deauth req
Wed Jan 16 00:40:10 2008 Associated: 00-1C-BF-19-9F-E3 st=0
Wed Jan 16 00:40:16 2008 Disassociated: 00-1C-BF-19-9F-E3 because RX deauth req
Wed Jan 16 00:40:19 2008 Associated: 00-1C-BF-19-9F-E3 st=0
Wed Jan 16 00:40:22 2008 Disassociated: 00-1C-BF-19-9F-E3 because WPA retey failed
Wed Jan 16 00:41:17 2008 Associated: 00-1C-BF-19-9F-E3 st=0
Wed Jan 16 00:41:24 2008 Disassociated: 00-1C-BF-19-9F-E3 because RX deauth req
Wed Jan 16 00:41:24 2008 Associated: 00-1C-BF-19-9F-E3 st=0
Wed Jan 16 00:41:28 2008 Disassociated: 00-1C-BF-19-9F-E3 because WPA retey failed
Wed Jan 16 00:41:28 2008 Associated: 00-1C-BF-19-9F-E3 st=0
Wed Jan 16 00:41:32 2008 Disassociated: 00-1C-BF-19-9F-E3 because WPA retey failed
Wed Jan 16 00:42:27 2008 Associated: 00-1C-BF-19-9F-E3 st=0
Wed Jan 16 00:42:41 2008 Disassociated: 00-1C-BF-19-9F-E3 because RX deauth req
Wed Jan 16 00:42:42 2008 Associated: 00-1C-BF-19-9F-E3 st=0
Wed Jan 16 00:42:54 2008 Disassociated: 00-1C-BF-19-9F-E3 because RX deauth req
Wed Jan 16 00:42:55 2008 Associated: 00-1C-BF-19-9F-E3 st=0
Wed Jan 16 00:42:59 2008 Disassociated: 00-1C-BF-19-9F-E3 because WPA retey failed
Wed Jan 16 00:46:05 2008 Associated: 00-1C-BF-19-9F-E3 st=0
Wed Jan 16 00:46:05 2008 Disassociated: 00-1C-BF-19-9F-E3 because RX deauth req
Wed Jan 16 00:46:15 2008 Associated: 00-1C-BF-19-9F-E3 st=0
Wed Jan 16 00:46:22 2008 Disassociated: 00-1C-BF-19-9F-E3 because RX deauth req
Wed Jan 16 00:46:24 2008 Associated: 00-1C-BF-19-9F-E3 st=0
Wed Jan 16 00:46:27 2008 Disassociated: 00-1C-BF-19-9F-E3 because WPA retey failed
Wed Jan 16 00:46:44 2008 Associated: 00-1C-BF-19-9F-E3 st=0
Wed Jan 16 00:46:57 2008 Disassociated: 00-1C-BF-19-9F-E3 because RX deauth req
Wed Jan 16 00:46:59 2008 Associated: 00-1C-BF-19-9F-E3 st=0
Wed Jan 16 00:47:02 2008 Disassociated: 00-1C-BF-19-9F-E3 because WPA retey failed
Wed Jan 16 00:47:02 2008 Associated: 00-1C-BF-19-9F-E3 st=0
Wed Jan 16 00:47:06 2008 Disassociated: 00-1C-BF-19-9F-E3 because WPA retey failed
Wed Jan 16 00:47:07 2008 Associated: 00-1C-BF-19-9F-E3 st=0
Wed Jan 16 00:47:11 2008 Disassociated: 00-1C-BF-19-9F-E3 because WPA retey failed
Wed Jan 16 00:47:51 2008 Associated: 00-1C-BF-19-9F-E3 st=0
Wed Jan 16 00:47:57 2008 Disassociated: 00-1C-BF-19-9F-E3 because RX deauth req
Wed Jan 16 00:47:59 2008 Associated: 00-1C-BF-19-9F-E3 st=0
Wed Jan 16 00:48:11 2008 Disassociated: 00-1C-BF-19-9F-E3 because RX deauth req
Wed Jan 16 00:48:11 2008 Associated: 00-1C-BF-19-9F-E3 st=0
Wed Jan 16 00:48:15 2008 Disassociated: 00-1C-BF-19-9F-E3 because WPA retey failed
Wed Jan 16 00:49:18 2008 Associated: 00-1C-BF-19-9F-E3 st=0
Wed Jan 16 00:49:24 2008 Disassociated: 00-1C-BF-19-9F-E3 because RX deauth req
Wed Jan 16 00:49:27 2008 Associated: 00-1C-BF-19-9F-E3 st=0
Wed Jan 16 00:49:30 2008 Disassociated: 00-1C-BF-19-9F-E3 because WPA retey failed
Wed Jan 16 00:52:35 2008 Associated: 00-1C-BF-19-9F-E3 st=0
Wed Jan 16 00:54:44 2008 Disassociated: 00-1C-BF-19-9F-E3 because RX deauth req
Wed Jan 16 00:56:40 2008 Associated: 00-1C-BF-19-9F-E3 st=0
Wed Jan 16 01:16:43 2008 Associated: 00-1C-BF-19-9F-E3 st=0
Wed Jan 16 01:16:47 2008 Disassociated: 00-1C-BF-19-9F-E3 because WPA retey failed
Wed Jan 16 01:17:24 2008 Associated: 00-1C-BF-19-9F-E3 st=0
Wed Jan 16 01:17:30 2008 Disassociated: 00-1C-BF-19-9F-E3 because RX deauth req
Wed Jan 16 01:17:30 2008 Associated: 00-1C-BF-19-9F-E3 st=0
Wed Jan 16 01:17:48 2008 Disassociated: 00-1C-BF-19-9F-E3 because RX deauth req
Wed Jan 16 01:17:48 2008 Associated: 00-1C-BF-19-9F-E3 st=0
Wed Jan 16 01:17:52 2008 Disassociated: 00-1C-BF-19-9F-E3 because WPA retey failed
Wed Jan 16 01:18:31 2008 Associated: 00-1C-BF-19-9F-E3 st=0
Wed Jan 16 01:18:35 2008 Disassociated: 00-1C-BF-19-9F-E3 because RX deauth req
Wed Jan 16 01:18:35 2008 Associated: 00-1C-BF-19-9F-E3 st=0
Wed Jan 16 01:18:39 2008 Disassociated: 00-1C-BF-19-9F-E3 because WPA retey failed
Wed Jan 16 01:18:56 2008 Associated: 00-1C-BF-19-9F-E3 st=0
Wed Jan 16 01:19:19 2008 Disassociated: 00-1C-BF-19-9F-E3 because RX deauth req
Wed Jan 16 01:19:20 2008 Associated: 00-1C-BF-19-9F-E3 st=0
Wed Jan 16 01:19:24 2008 Disassociated: 00-1C-BF-19-9F-E3 because WPA retey failed
Wed Jan 16 01:19:25 2008 Associated: 00-1C-BF-19-9F-E3 st=0
Wed Jan 16 01:19:47 2008 Disassociated: 00-1C-BF-19-9F-E3 because RX deauth req
Wed Jan 16 01:19:48 2008 Associated: 00-1C-BF-19-9F-E3 st=0
Wed Jan 16 01:19:51 2008 Disassociated: 00-1C-BF-19-9F-E3 because RX deauth req
Wed Jan 16 01:19:52 2008 Associated: 00-1C-BF-19-9F-E3 st=0
Wed Jan 16 01:20:18 2008 Disassociated: 00-1C-BF-19-9F-E3 because RX deauth req
Wed Jan 16 01:20:20 2008 Associated: 00-1C-BF-19-9F-E3 st=0
Wed Jan 16 01:20:23 2008 Disassociated: 00-1C-BF-19-9F-E3 because WPA retey failed
Wed Jan 16 01:20:25 2008 Associated: 00-1C-BF-19-9F-E3 st=0
Wed Jan 16 01:20:29 2008 Disassociated: 00-1C-BF-19-9F-E3 because WPA retey failed
Wed Jan 16 01:22:27 2008 Associated: 00-1C-BF-19-9F-E3 st=0
Wed Jan 16 01:23:48 2008 Restarted by 192.168.0.188
Wed Jan 16 01:29:48 2008 Restarted by 192.168.0.192
Wed Jan 16 01:29:48 2008 Associated: 00-1C-BF-19-9F-E3 st=0
Wed Jan 16 01:29:49 2008 Disassociated: 00-1C-BF-19-9F-E3 because RX deauth req
Wed Jan 16 01:30:20 2008 Associated: 00-1C-BF-19-9F-E3 st=0
СообщениеДобавлено: Чт янв 17, 2008 18:33
Адаптер какой,какая операционка?Видимость прямая до роутера?
СообщениеДобавлено: Вс мар 16, 2008 00:15
У меня аналогичная проблема с карточкой Intel 4965AG и DI-524.
Не вяжется вообще по умолчанию.
Быстро вяжется, если пареллельно бросить Ethernet кабель. Если кабель отключить поживет пару минут и отсохнет. Если кабель оствить, через те-же пару минут, будет говорить, что он одсоединен, как вроде он только-что перевязался.
Карточка версии: 1.6.40
Дрова на карточке: 11.5.0.32
Current Firmware Version: V2.03
На прошивке 2.06 вижу по отзывам, что проблемы те-же.
To Support: ребята, давайте решать проблему. Она явно в D-Link я расто работаю в разных WiFi сетях и нигде не было проблем, ктроме моего домашнего D-Link DI-524.
СообщениеДобавлено: Пн окт 13, 2008 22:43
Такая же ситуация, если ставить скорость подключения не Auto или 11 Мбит в перфомансе роутера:
Monday October 13, 2008 23:24:46 Associated: 00-19-CB-74-D6-98 st=0
Monday October 13, 2008 23:24:50 Disassociated: 00-19-CB-74-D6-98 because WPA retey failed
Monday October 13, 2008 23:24:53 Associated: 00-19-CB-74-D6-98 st=0
Monday October 13, 2008 23:24:58 Disassociated: 00-19-CB-74-D6-98 because WPA retey failed
Monday October 13, 2008 23:25:52 Associated: 00-19-CB-74-D6-98 st=0
Monday October 13, 2008 23:25:57 Disassociated: 00-19-CB-74-D6-98 because WPA retey failed
Если 11 или Auto, то сразу:
Monday October 13, 2008 23:26:47 Associated: 00-19-CB-74-D6-98 st=0
и все ок.
DI-524 (2.06p08)
Zyxel G302E 11b/g
Была до этого dlink dwl-510 так та вообще тока на 11 сатбильно работала с этим роутером. на 54 Мбита пинги за 1500 мс. или вообще пакеты не доходили. а при подключении в логах как написано выше было :(((( думал дело в сетевой карте. окозалось не совсем.
И, кстати, скорость скачивания по локалке - WAN-WLAN не превышает 6Мбит, хотя в наше локалке народ тянет и под 50-80 Мбит
Что нить дельное может посоветуете. это лечится?
СообщениеДобавлено: Вт окт 14, 2008 14:23
2 roman moiseev
По логам роутер попросту пароль не принимает или сбрасывает его.Есть возможность друго клиента прицепить?Ибо у нас роутер с WPA (2) работает корректно.
2 V.Belya
Про интел отдельно:да,были проблемы с совместимостью адаптеров интела и наших роутеров,но с драйверами старше ноября 2007 года и последней прошивкой роутера должно работать.
СообщениеДобавлено: Вт окт 14, 2008 14:52
Да, после обновления дров на Интеле работает очень стабильно.
Прошивку на рутере менять не пришлось.
Спасибо.
СообщениеДобавлено: Сб ноя 01, 2008 20:39
обновил дрова на зюхеле - нормально пашет. спс.
СообщениеДобавлено: Пт ноя 07, 2008 13:23
Товарищи, ткните носом в совет, плиз.
К сабжу подключены с одной стороны пчелайн по эзернету, с другой стороны 1 комп тоже кабелем, и 2 - вайфаем.
Пока комп, подключенный кабелем, выключен - все отлично (если это не совпадение, конечно).
Включаю этот - начинает рандомно пропадать связь по вайфаю, причем просто втупую отваливается и подключиться заново можно только ребутнув точку.
Подскажите, плиз, что можно отключить (включить) в настройках, или может прошивку правильную посоветуете..
Версия аппаратной части - B4
Firmware Version: V2.06Patch08RU , Wed, May 07 2008
Раньше была прошивка 07, февральская, вроде бы, но когда с меня качали большие файлы по фтп, отваливался инет.
Если нужна еще какая-нибудь инфа (логи, или еще что-нибудь) - напишите, я выложу.
Спасибо!
СообщениеДобавлено: Сб янв 23, 2010 10:50
V.Belya писал(а):
...ребята, давайте решать проблему. Она явно в D-Link я расто работаю в разных WiFi сетях и нигде не было проблем, ктроме моего домашнего D-Link DI-524.
Не соглашусь, у меня дома на этом роутере висят:
1. WiFi Link 4965AG в Packarde и
2. Broadcom 802.11a/b/g WLAN в compaq 6715b
Так вот сбоит Паккард. Каков же вывод?
Ежику понятно - дело в WiFi Link 4965AG.
Интересный симптом отловил сегодня - на батареях Паккард не входил в сеть даже в метре от роутера... Подключил 220 В, и ... как по маслу.... при среднем уровне сигнала, т.е. в самой дальней комнате...
Глючит WiFi Link 4965AG !!!
