Текущее время: Ср июл 29, 2026 23:50
СообщениеДобавлено: Пн авг 17, 2009 11:09
Роутер работает постоянно. Включаю комп, запускаю, например, Миранду (на которую настроен port forwarding) и роутер в 3 случаев из 5 перезагружается, разрывая соединение по Lan.
В процессе работы это встречается не часто.
Проблема вроде как стала появлятся после апдейта на прошивку FW226RUB06.bin.
Привожу log файл, сдампленный сразу же после перезагрузки роутера (сам в этом не бум-бум):
[INFO] Sat Jul 11 08:50:07 2009 Blocked incoming TCP connection request from 95.25.101.86:56380 to 85.141.170.105:59039
[INFO] Sat Jul 11 08:50:07 2009 Blocked incoming TCP connection request from 77.66.234.34:2552 to 85.141.170.105:59039
[INFO] Sat Jul 11 08:50:06 2009 Blocked incoming TCP connection request from 95.25.101.86:56380 to 85.141.170.105:59039
[INFO] Sat Jul 11 08:50:04 2009 Above message repeated 2 times
[INFO] Sat Jul 11 08:50:04 2009 Blocked incoming TCP connection request from 77.66.234.34:2552 to 85.141.170.105:59039
[INFO] Sat Jul 11 08:50:03 2009 Blocked incoming TCP connection request from 95.25.101.86:56380 to 85.141.170.105:59039
[INFO] Sat Jul 11 08:50:02 2009 Above message repeated 1 times
[INFO] Sat Jul 11 08:49:57 2009 Blocked incoming TCP connection request from 60.198.134.66:2751 to 85.141.170.105:14737
[INFO] Sat Jul 11 08:49:52 2009 Blocked incoming TCP connection request from 87.251.152.100:60531 to 85.141.170.105:21387
[INFO] Sat Jul 11 08:49:50 2009 Blocked incoming TCP connection request from 60.198.134.66:2751 to 85.141.170.105:14737
[INFO] Sat Jul 11 08:49:49 2009 Blocked incoming TCP connection request from 87.251.152.100:60531 to 85.141.170.105:21387
[INFO] Sat Jul 11 08:49:48 2009 Blocked incoming TCP connection request from 60.198.134.66:2751 to 85.141.170.105:14737
[INFO] Sat Jul 11 08:49:32 2009 Blocked incoming UDP packet from 83.217.196.3:60001 to 85.141.170.105:45353
[CRIT] Sat Jul 11 08:49:31 2009 The addressing of the Internet side learnt thru DHCP conflicts with the addressing selected for the LAN side.  Internet communications will be disabled until you have changed the LAN side addressing to resolve the problem.
[INFO] Sat Jul 11 08:49:28 2009 Blocked incoming UDP packet from 83.217.196.3:60001 to 85.141.170.105:45353
[INFO] Sat Jul 11 08:49:26 2009 Above message repeated 1 times
[INFO] Sat Jul 11 08:49:23 2009 Blocked incoming TCP connection request from 60.198.134.66:2521 to 85.141.170.105:14737
[INFO] Sat Jul 11 08:49:14 2009 Above message repeated 2 times
[INFO] Sat Jul 11 08:49:10 2009 Blocked incoming UDP packet from 59.112.217.169:16332 to 85.141.170.105:14737
[INFO] Sat Jul 11 08:49:08 2009 Blocked incoming TCP connection request from 59.112.217.169:4201 to 85.141.170.105:14737
[INFO] Sat Jul 11 08:49:06 2009 Blocked incoming UDP packet from 59.112.217.169:16332 to 85.141.170.105:14737
[INFO] Sat Jul 11 08:49:02 2009 Above message repeated 1 times
[INFO] Sat Jul 11 08:49:02 2009 Blocked incoming TCP connection request from 59.112.217.169:4201 to 85.141.170.105:14737
[INFO] Sat Jul 11 08:48:59 2009 Blocked incoming UDP packet from 59.112.217.169:16332 to 85.141.170.105:14737
[CRIT] Sat Jul 11 08:48:59 2009 The addressing of the Internet side learnt thru DHCP conflicts with the addressing selected for the LAN side.  Internet communications will be disabled until you have changed the LAN side addressing to resolve the problem.
[INFO] Sat Jul 11 08:48:59 2009 Blocked incoming TCP connection request from 59.112.217.169:4201 to 85.141.170.105:14737
[INFO] Sat Jul 11 08:48:52 2009 Log viewed by IP address 192.168.1.2
[INFO] Sat Jul 11 08:48:50 2009 Allowed configuration authentication by IP address 192.168.1.2
[INFO] Sat Jul 11 08:48:47 2009 Starting WAN Services
[INFO] Sat Jul 11 08:48:47 2009 WAN interface speed measurement completed
[CRIT] Sat Jul 11 08:48:43 2009 The addressing of the Internet side learnt thru DHCP conflicts with the addressing selected for the LAN side.  Internet communications will be disabled until you have changed the LAN side addressing to resolve the problem.
[INFO] Sat Jul 11 08:48:36 2009 Starting DHCP server
[CRIT] Sat Jul 11 08:48:35 2009 The addressing of the Internet side learnt thru DHCP conflicts with the addressing selected for the LAN side.  Internet communications will be disabled until you have changed the LAN side addressing to resolve the problem.
[INFO] Sat Jul 11 08:48:31 2009 Above message repeated 1 times
[INFO] Sat Jul 11 08:48:29 2009 Estimating speed of WAN interface
[INFO] Sat Jul 11 08:48:29 2009 WAN interface is up. Connection to Internet established with IP Address 85.141.170.105 and default gateway 85.141.168.1
[INFO] Sat Jul 11 08:48:29 2009 PPP network up with IP Address 85.141.170.105
[INFO] Sat Jul 11 08:48:29 2009 WAN interface is down
[CRIT] Sat Jul 11 08:48:29 2009 The addressing of the Internet side learnt thru DHCP conflicts with the addressing selected for the LAN side.  Internet communications will be disabled until you have changed the LAN side addressing to resolve the problem.
[INFO] Sat Jul 11 08:48:28 2009 LCP sets local options: ACCM: 00000000, ACFC: 1, PFC: 0, MRU: 1492
[INFO] Sat Jul 11 08:48:28 2009 LCP sets remote auth: C223
[INFO] Sat Jul 11 08:48:28 2009 LCP sets remote options: ACCM: FFFFFFFF, ACFC: 1, PFC: 0, MRU: 1492
[INFO] Sat Jul 11 08:48:28 2009 PPPoE session 0x08AA established
[CRIT] Sat Jul 11 08:48:28 2009 The addressing of the Internet side learnt thru DHCP conflicts with the addressing selected for the LAN side.  Internet communications will be disabled until you have changed the LAN side addressing to resolve the problem.
[INFO] Sat Jul 11 08:48:28 2009 PPPoE confirming session offer
[INFO] Sat Jul 11 08:48:28 2009 PPPoE received session offer
[INFO] Sat Jul 11 08:48:28 2009 Trying to establish a PPPoE connection
[INFO] Sat Jul 11 08:48:28 2009 Attempting to start always-on WAN connection
[INFO] Sat Jul 11 08:48:28 2009 WAN interface cable has been connected
[INFO] Sat Jul 11 08:48:28 2009 LAN interface is up
[INFO] Sat Jul 11 08:48:28 2009 LAN Ethernet Carrier Detected
[INFO] Sat Jul 11 08:48:27 2009 Device initialized
[WARN] Sat Jul 11 08:48:27 2009 gw_wireless_schedule init
[INFO] Sat Jul 11 08:48:27 2009 Wireless Link is up
[INFO] Sat Jul 11 08:48:26 2009 Unlock AP setup
[INFO] Sat Jul 11 08:48:26 2009 No Internet access policy is in effect. Unrestricted Internet access allowed to everyone
[INFO] Thu Jan 01 03:00:00 1970 Loaded configuration from non-volatile memory
Что порекомендуете?
СообщениеДобавлено: Пн авг 17, 2009 16:03
Используйте прошивку 2.27 из папки бета
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 71
