Текущее время: Пн сен 28, 2026 09:10
 Заголовок сообщения: Dir-655 + Wifi по расписаню = disconnect
СообщениеДобавлено: Вт мар 03, 2009 10:41
Здраствуйте,
Роутер Dir-655 A3 1.21WW
Подключен по PPPoE dual Russia
Пи использовании Wifi по расписанию при всключении Wifi происходит Disconnect соединения.
При ручном включении все нормально.
Лог:
03-03-2009   06:59:09   System3.Info   192.168.0.1   Tue Mar 03 07:59:15 2009 D-Link Systems DIR-655 System Log: Blocked incoming ICMP error message (ICMP type 3) from 81.200.22.232 to 85.141.247.171 as there is no TCP connection active between 85.141.247.171:4201 and 192.168.1.2:21241
03-03-2009   06:59:30   System3.Info   192.168.0.1   Tue Mar 03 07:59:35 2009 D-Link Systems DIR-655 System Log: Blocked incoming UDP packet from 58.107.15.177:60359 to 85.141.247.171:22384
03-03-2009   06:59:55   System3.Warning   192.168.0.1   Tue Mar 03 08:00:00 2009 D-Link Systems DIR-655 System Log: : Wireless schedule start
03-03-2009   07:00:00   System3.Warning   192.168.0.1   Wed Feb 25 22:26:45 2009 D-Link Systems DIR-655 System Log: Wireless schedule init
03-03-2009   07:00:00   System3.Info   192.168.0.1   Wed Feb 25 22:26:45 2009 D-Link Systems DIR-655 System Log: Device initialized
03-03-2009   07:00:00   System3.Info   192.168.0.1   Wed Feb 25 22:26:46 2009 D-Link Systems DIR-655 System Log: LAN Ethernet Carrier Detected
03-03-2009   07:00:00   System3.Info   192.168.0.1   Wed Feb 25 22:26:46 2009 D-Link Systems DIR-655 System Log: LAN interface is up
03-03-2009   07:00:00   System3.Info   192.168.0.1   Wed Feb 25 22:26:47 2009 D-Link Systems DIR-655 System Log: WAN interface cable has been connected
03-03-2009   07:00:00   System3.Info   192.168.0.1   Wed Feb 25 22:26:47 2009 D-Link Systems DIR-655 System Log: Bringing up WAN using Russia PPPoE
03-03-2009   07:00:00   System3.Info   192.168.0.1   Wed Feb 25 22:26:47 2009 D-Link Systems DIR-655 System Log: Attempting to start always-on WAN connection
03-03-2009   07:00:00   System3.Info   192.168.0.1   Wed Feb 25 22:26:47 2009 D-Link Systems DIR-655 System Log: Trying to establish INTERNET PPPoE connection
03-03-2009   07:00:00   System3.Info   192.168.0.1   Wed Feb 25 22:26:47 2009 D-Link Systems DIR-655 System Log: Discovering PPPoE servers for INTERNET PPPoE Session
СообщениеДобавлено: Вт мар 03, 2009 17:52
Спасибо проверим.
СообщениеДобавлено: Ср мар 04, 2009 14:29
Проблему подтвердить не могу.
Соединение PPPoE Russia Dual Access
И по расписанию и без расписания PPPoE соединение не разрывается при подключении по Wi-Fi.
Попробуйте прошить снова и сбросьте в заводские настройки. В меню TIME установите свой часовой пояс (если он не установлен).
СообщениеДобавлено: Ср мар 04, 2009 18:07
Спасибо, перепрошивка+сброс помогло.
СообщениеДобавлено: Чт мар 05, 2009 18:54
Update
нет, все равно отключается, и время почемуто назад откатывается.
05-03-2009   17:59:55   System3.Info   192.168.0.1   Thu Mar 05 17:59:58 2009 D-Link DIR-655 System Log: Blocked incoming UDP packet from 75.151.86.214:42494 to 91.77.45.24:40363
05-03-2009   17:59:58   System3.Warning   192.168.0.1   Thu Mar 05 18:00:01 2009 D-Link DIR-655 System Log: : Wireless schedule start
05-03-2009   18:00:04   System3.Warning   192.168.0.1   Thu Mar 05 15:39:21 2009 D-Link DIR-655 System Log: Wireless schedule init
05-03-2009   18:00:04   System3.Info   192.168.0.1   Thu Mar 05 15:39:21 2009 D-Link DIR-655 System Log: Device initialized
05-03-2009   18:00:04   System3.Info   192.168.0.1   Thu Mar 05 15:39:22 2009 D-Link DIR-655 System Log: LAN Ethernet Carrier Detected
05-03-2009   18:00:04   System3.Info   192.168.0.1   Thu Mar 05 15:39:22 2009 D-Link DIR-655 System Log: LAN interface is up
05-03-2009   18:00:04   System3.Info   192.168.0.1   Thu Mar 05 15:39:23 2009 D-Link DIR-655 System Log: WAN interface cable has been connected
05-03-2009   18:00:04   System3.Info   192.168.0.1   Thu Mar 05 15:39:23 2009 D-Link DIR-655 System Log: Bringing up WAN using PPPoE
05-03-2009   18:00:04   System3.Info   192.168.0.1   Thu Mar 05 15:39:23 2009 D-Link DIR-655 System Log: Attempting to start always-on WAN connection
05-03-2009   18:00:04   System3.Info   192.168.0.1   Thu Mar 05 15:39:23 2009 D-Link DIR-655 System Log: Trying to establish INTERNET PPPoE connection
05-03-2009   18:00:04   System3.Info   192.168.0.1   Thu Mar 05 15:39:23 2009 D-Link DIR-655 System Log: Discovering PPPoE servers for INTERNET PPPoE Session
05-03-2009   18:00:04   System3.Info   192.168.0.1   Thu Mar 05 15:39:24 2009 D-Link DIR-655 System Log: Discovering PPPoE servers for INTERNET PPPoE Session
05-03-2009   18:00:06   System3.Info   192.168.0.1   Thu Mar 05 15:39:26 2009 D-Link DIR-655 System Log: Discovering PPPoE servers for INTERNET PPPoE Session
05-03-2009   18:00:06   System3.Info   192.168.0.1   Thu Mar 05 15:39:26 2009 D-Link DIR-655 System Log: Offer received for INTERNET PPPoE Session, service offered is STREAM from STREAM (0030880169E9)
05-03-2009   18:00:06   System3.Info   192.168.0.1   Thu Mar 05 15:39:26 2009 D-Link DIR-655 System Log: Offer received for INTERNET PPPoE Session, service offered is mtu from STREAM (0030880169E9)
05-03-2009   18:00:06   System3.Info   192.168.0.1   Thu Mar 05 15:39:26 2009 D-Link DIR-655 System Log: Offer received for INTERNET PPPoE Session, service offered is mgts from STREAM (0030880169E9)
05-03-2009   18:00:06   System3.Info   192.168.0.1   Thu Mar 05 15:39:26 2009 D-Link DIR-655 System Log: Offer received for INTERNET PPPoE Session, service offered is mgts.ru from STREAM (0030880169E9)
05-03-2009   18:00:06   System3.Info   192.168.0.1   Thu Mar 05 15:39:26 2009 D-Link DIR-655 System Log: Offer received for INTERNET PPPoE Session, service offered is MyLAN from STREAM (0030880169E9)
05-03-2009   18:00:06   System3.Info   192.168.0.1   Thu Mar 05 15:39:26 2009 D-Link DIR-655 System Log: Offer received for INTERNET PPPoE Session, service offered is mtu:stream from STREAM (0030880169E9)
05-03-2009   18:00:06   System3.Info   192.168.0.1   Thu Mar 05 15:39:26 2009 D-Link DIR-655 System Log: Offer received for INTERNET PPPoE Session, service offered is mtu:games from STREAM (0030880169E9)
05-03-2009   18:00:06   System3.Info   192.168.0.1   Thu Mar 05 15:39:26 2009 D-Link DIR-655 System Log: Offer of service STREAM accepted for INTERNET PPPoE Session
05-03-2009   18:00:06   System3.Info   192.168.0.1   Thu Mar 05 15:39:26 2009 D-Link DIR-655 System Log: Issuing request for offer for INTERNET PPPoE Session
05-03-2009   18:00:06   System3.Info   192.168.0.1   Thu Mar 05 15:39:26 2009 D-Link DIR-655 System Log: Established INTERNET PPPoE connection, session id 10902
05-03-2009   18:00:06   System3.Info   192.168.0.1   Thu Mar 05 15:39:26 2009 D-Link DIR-655 System Log: LCP sets remote options: ACCM: FFFFFFFF, ACFC: 1, PFC: 0, MRU: 1492
05-03-2009   18:00:06   System3.Info   192.168.0.1   Thu Mar 05 15:39:26 2009 D-Link DIR-655 System Log: LCP sets remote auth: C223
05-03-2009   18:00:06   System3.Info   192.168.0.1   Thu Mar 05 15:39:26 2009 D-Link DIR-655 System Log: LCP sets local options: ACCM: 00000000, ACFC: 1, PFC: 0, MRU: 1492
05-03-2009   18:00:06   System3.Info   192.168.0.1   Thu Mar 05 15:39:26 2009 D-Link DIR-655 System Log: PPP network up with IP Address 91.78.221.62
05-03-2009   18:00:06   System3.Info   192.168.0.1   Thu Mar 05 15:39:26 2009 D-Link DIR-655 System Log: Estimating speed of WAN interface
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 66
