Текущее время: Вс сен 27, 2026 07:53
 Заголовок сообщения: DIR-615 чудит
СообщениеДобавлено: Ср фев 18, 2009 00:17
Уважаемая тех подержка ПОМОГИТЕ!!!. Роутер DIR-615 начал чудить. Нормально отработав пару дней зеленый шарик говорящий о наличии интернета загорелся красным. Сейчас сижу в полевых условиях на полу рядом с этим чудом. В логах какая то каша.
27 Log Entries: Priority Time Message
[INFO] Sat Jan 31 10:34:18 2004 Log viewed by IP address 192.168.0.199
[INFO] Sat Jan 31 10:34:13 2004 Above message repeated 2 times
[WARN] Sat Jan 31 10:34:13 2004 Blocked packet from 0.0.0.0 to 0.0.0.0 (LAND Attack)
[INFO] Sat Jan 31 10:34:10 2004 Above message repeated 1 times
[INFO] Sat Jan 31 10:34:07 2004 Log viewed by IP address 192.168.0.199
[INFO] Sat Jan 31 10:33:54 2004 Allowed configuration authentication by IP address 192.168.0.199
[WARN] Sat Jan 31 10:33:42 2004 A network computer (athlon) was assigned the IP address of 192.168.0.199.
[INFO] Sat Jan 31 10:33:40 2004 Wireless system with MAC address 001E589ADA32 associated
[WARN] Sat Jan 31 10:33:35 2004 Blocked packet from 0.0.0.0 to 0.0.0.0 (LAND Attack)
[INFO] Sat Jan 31 10:33:30 2004 Wireless system with MAC address 001E589ADA32 disconnected for reason: Received Deauthentication.
[WARN] Sat Jan 31 10:33:29 2004 Blocked packet from 0.0.0.0 to 0.0.0.0 (LAND Attack)
[INFO] Sat Jan 31 10:33:24 2004 Wireless system with MAC address 001E589ADA32 associated
[WARN] Sat Jan 31 10:33:19 2004 Blocked packet from 0.0.0.0 to 0.0.0.0 (LAND Attack)
[INFO] Sat Jan 31 10:33:05 2004 Above message repeated 5 times
[INFO] Sat Jan 31 10:33:03 2004 Bringing up WAN using RUSSIA PPTP
[INFO] Sat Jan 31 10:33:03 2004 WAN interface cable has been connected
[WARN] Sat Jan 31 10:32:43 2004 A network computer (0050BF6746AB) was assigned the IP address of 192.168.0.197.
[INFO] Sat Jan 31 10:32:34 2004 Allowed configuration authentication by IP address 192.168.0.197
[INFO] Sat Jan 31 10:32:31 2004 Starting DHCP server
[INFO] Sat Jan 31 10:32:22 2004 LAN interface is up
[INFO] Sat Jan 31 10:32:22 2004 LAN Ethernet Carrier Detected
[INFO] Sat Jan 31 10:32:22 2004 Device initialized
[WARN] Sat Jan 31 10:32:22 2004 gw_wireless_schedule init
[INFO] Sat Jan 31 10:32:22 2004 Wireless Link is up
[INFO] Sat Jan 31 10:32:21 2004 Unlock AP setup
[INFO] Sat Jan 31 10:32:21 2004 No Internet access policy is in effect. Unrestricted Internet access allowed to everyone
[INFO] Wed Dec 31 16:00:00 1969 Loaded configuration from non-volatile memory
Прошивки пробовал все с этого сайта, но на всех одно и тоже. Как выйти из ситуации? Или лучше сдать в магазин пока еще есть время?
В настоящий момент прошивка установленна 223RU с важего сайта. Обнавлял прошувку до последней версии после чего решил откатиться назад так как она все же тогда работала.
Конектиться по PPTP с запросом имени и пароля. IP динамичисекий. Через комп все работает, а роутер инета не видет хотя ранее видел все прекрасно. Провайдер билайн, он же корбина телеком. Город Ростов на-Дону.
PS: стоило обрадоваться что мне повезло и вот оно привалило... "Счастье"...
СообщениеДобавлено: Ср фев 18, 2009 16:46
Обязательно обновитесь до последней прошивки, после обновления роутер надо сбрасывать в заводские настрйки и перенастраивать вручную. А проблема у вас с wireles попробуйте подключиться к роутеру кабелем.
СообщениеДобавлено: Ср фев 18, 2009 23:55
Спасибо что обратили внимание на тему. Прошивку обновлял, эффекта ровно ноль. То что роутер надо сбрасывать в заводские настрйки и перенастраивать вручную я вкурсе. Так и делал. Сейчас стоит DIR-100 и нормально пашет уже 4 часа 20 минут. Через торрент качаются фильмы, работает аська и лозию при этом в сети и все тип топ...
СообщениеДобавлено: Чт фев 19, 2009 19:02
Попробуйте отключить у DIR-615 wi-fi
СообщениеДобавлено: Пт фев 20, 2009 19:47
Спасибо, но уже сделать этого не смогу так как сдал его в магазин пока была возможность. Тест с DIR-100 и роутером от 3СОМ показало чо чудил именно 615й.
Практика показала что в сетях корбины 615й не работает.
В настоящее время подключен 3СОМ 3CRWER200-75. Система работает замечательно. Адаптеры WI-FI установленны DWA-160 и DWA-510. Оба работают отлично. Шифрование WPA.
Сейчас этот форум просматривают: Bing [Bot] и гости: 41
