Текущее время: Пт окт 02, 2026 07:32
 Заголовок сообщения: DI-804 как вылечить блокировку..
СообщениеДобавлено: Вс дек 19, 2004 02:33
При скачивании файла регетом, он ругаеися на
Error 3820 2:30:49 19.12.2004 Error #800705B4(Возврат из операции произошел из-за превышения времени ожидания.) in WaitForReadyLock
и
Error 3811 2:30:36 19.12.2004 Error #800705B4(Возврат из операции произошел из-за превышения времени ожидания.) in CRgHttpSession::RequestFile()
логи роутера:
Thursday August 12, 2004 00:22:12 Blocked access attempt from 63.241.72.197:80 to TCP port 58089
Thursday August 12, 2004 00:22:12 Blocked access attempt from 63.241.72.197:80 to TCP port 58091
Thursday August 12, 2004 00:22:12 Blocked access attempt from 63.241.72.197:80 to TCP port 58081
Thursday August 12, 2004 00:22:12 Blocked access attempt from 63.241.72.197:80 to TCP port 58083
Thursday August 12, 2004 00:22:12 Blocked access attempt from 63.241.72.197:80 to TCP port 58085
Thursday August 12, 2004 00:22:12 Blocked access attempt from 63.241.72.197:80 to TCP port 58087
Thursday August 12, 2004 00:22:13 Blocked access attempt from 63.241.72.197:80 to TCP port 57905
Thursday August 12, 2004 00:22:13 Blocked access attempt from 63.241.72.197:80 to TCP port 57983
Thursday August 12, 2004 00:22:13 Blocked access attempt from 63.241.72.197:80 to TCP port 58089
Thursday August 12, 2004 00:22:13 Blocked access attempt from 63.241.72.197:80 to TCP port 58091
Thursday August 12, 2004 00:22:24 Blocked access attempt from 63.241.72.197:80 to TCP port 57983
Thursday August 12, 2004 00:22:24 Blocked access attempt from 63.241.72.197:80 to TCP port 57905
Thursday August 12, 2004 00:22:38 Blocked access attempt from 63.241.72.197:80 to TCP port 58111
Thursday August 12, 2004 00:22:41 Blocked access attempt from 63.241.72.197:80 to TCP port 58103
Thursday August 12, 2004 00:22:42 Blocked access attempt from 63.241.72.197:80 to TCP port 58113
Thursday August 12, 2004 00:22:42 Blocked access attempt from 63.241.72.197:80 to TCP port 58115
Thursday August 12, 2004 00:22:44 Blocked access attempt from 63.241.72.197:80 to TCP port 58111
Thursday August 12, 2004 00:22:45 Blocked access attempt from 63.241.72.197:80 to TCP port 58119
Thursday August 12, 2004 00:22:45 Blocked access attempt from 63.241.72.197:80 to TCP port 58121
Thursday August 12, 2004 00:22:45 Blocked access attempt from 63.241.72.197:80 to TCP port 58113
как это можно вылечить.
соединение pptp, static ip
из-за этой блокировки маленькая скорость скачивания.
С деньгами может каждый, а ты попробуй без денег.
 Заголовок сообщения: Re: DI-804 как вылечить блокировку..
СообщениеДобавлено: Пн дек 20, 2004 13:41
а кто такой - 63.241.72.197 ?
СообщениеДобавлено: Вт дек 21, 2004 16:22
Это сайт с которого я качал файл.
логи одни и теже, только разные ip с которых происходит скачка.
СообщениеДобавлено: Вт дек 21, 2004 16:55
Тогда надо у софтины увеличить время ожидания ответа.
Эти блокировки происходят потому, что сессия закрывается раньше,
а потом приходит ответный пакет (на уже закрытый порт) - и блокируется
СообщениеДобавлено: Вт дек 21, 2004 17:27
такая же проблема... только DI-824VUP+
похоже что нат на маршрутизаторе что-то не так делает... регет и таймауты тут ни при чем!
может SPI моде виноват?
Best Regards,
Maksim Malchuk
СообщениеДобавлено: Ср янв 12, 2005 13:34
Модератор
Модератор
Либо SPI, либо DOS. Попробуйте их в разных комбинациях.
СообщениеДобавлено: Пт янв 14, 2005 12:35
СообщениеДобавлено: Вс янв 16, 2005 16:31
Они стоят по умолчанию(ВЫКЛ)
Кого включить кого выключить.
ЗЫ: Существуе ли иписани программы D-View(желательно на русском у или на английском)
СообщениеДобавлено: Вс янв 23, 2005 00:44
up
СообщениеДобавлено: Пн янв 24, 2005 12:21
Модератор
Модератор
SPI - включить, DOS выключить. При этом препятствия минимальные.
По D-View см. на нашем фтп, буквально в течении часа должна появится презенташка русскоязычная.
СообщениеДобавлено: Вт янв 25, 2005 20:58
Кстати, где бы почитать, что именно делает SPI, а что DoS?
СообщениеДобавлено: Вт янв 25, 2005 21:01
У меня сейчас обе функции включены, и я вижу (на unix'овых машинах) жалобы ntpd о пропаданиях доступа к ntp серверам. Похоже - NAT слишком быстро сбрасывает записи в своей таблице...
Сейчас этот форум просматривают: Google [Bot] и гости: 81
