Текущее время: Сб окт 03, 2026 18:24
СообщениеДобавлено: Сб янв 17, 2009 20:24
Проблема: девайс самопроизвольно "перезагружается" с интервалом 40-50мин.
Пробовал отключать WIFI и выдергивать кабель WAN, результат тотже.
Прошивка:
Current Firmware Version: v2.10
Firmware Date: Mon, Dec 29 2008
(Раньше была от 2006г, версию не помню, результат был тот же)
LOG при перезагрузке:
Tuesday October 03, 2006 00:00:00 Associated: 00-1E-58-9C-0D-31 st=0
Tuesday October 03, 2006 00:00:02 DOD:TCP trigger from 192.168.0.2:18145 to 92.252.226.22:21280
Tuesday October 03, 2006 00:00:02 PPPoE start to dial-up
Tuesday October 03, 2006 00:00:02 PADI sent
Tuesday October 03, 2006 00:00:02 PADR sent
Tuesday October 03, 2006 00:00:03 PADR sent
Tuesday October 03, 2006 00:00:03 PADS recv 8002 E80D
Tuesday October 03, 2006 00:00:03 PAP3: Authentication success,Welcome!
Tuesday October 03, 2006 00:00:08 Associated: 00-1E-58-9C-0D-31 st=0
Tuesday October 03, 2006 00:03:03 PPP3: retry fail
Tuesday October 03, 2006 00:03:04 DOD:TCP trigger from 192.168.0.2:3947 to 10.200.26.159:56010
Tuesday October 03, 2006 00:03:04 PPPoE start to dial-up
Tuesday October 03, 2006 00:03:04 PADT sent
Tuesday October 03, 2006 00:03:05 PADI sent
Tuesday October 03, 2006 00:03:05 PADR sent
Tuesday October 03, 2006 00:03:05 PADS recv 8002 9231
Tuesday October 03, 2006 00:03:05 PAP3: Authentication success,Welcome!
Tuesday October 03, 2006 00:03:55 Restarted by 192.168.0.2
Tuesday October 03, 2006 00:03:56 DOD:UDP trigger from 192.168.0.2:3974 to 89.239.140.110:27016
Tuesday October 03, 2006 00:03:56 PPPoE start to dial-up
Tuesday October 03, 2006 00:03:55 PPPoE start to dial-up
Tuesday October 03, 2006 00:03:55 PADT sent
Tuesday October 03, 2006 00:03:57 PADI sent
Tuesday October 03, 2006 00:03:57 PADR sent
Tuesday October 03, 2006 00:03:57 PADS recv 8002 0C02
Tuesday October 03, 2006 00:03:57 PAP3: Authentication success,Welcome!
Tuesday October 03, 2006 00:03:57 IPCP3: IP is *.252.249.*
Tuesday October 03, 2006 00:03:57 IPCP3: DNS0 is *.239.139.131
Tuesday October 03, 2006 00:03:57 IPCP3: DNS1 is *.239.139.130
СообщениеДобавлено: Вт янв 20, 2009 00:07
UP
СообщениеДобавлено: Ср янв 21, 2009 18:14
Какой тип подключения? Используются ли p2p клиенты или роутер перезагружается даже без нагрузки?
СообщениеДобавлено: Ср янв 21, 2009 18:50
Перезагружался без нагрузки.
Сейчас сменил прошивку на D-Link_824VUP_v200(v200b14), работает уже 4 часа без перезагрузок.
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 173
