Текущее время: Ср ноя 11, 2026 18:27
СообщениеДобавлено: Чт окт 23, 2008 08:45
Здраствуйте, есть проблема которая не решилась с выходом новой прошивки http://ftp.dlink.ru/pub/Router/DI-804HV ... .51b03.BIN[/url]
проблема с Dial-up Network, всё прописываю, конект есть...
при открытии страница открывается но не полностью, смотрю (статус/девайс инфо) hang-up и снова dialling и так по кругу...
подскажите пожлуйста в чём проблема модем прицеплен к компу работает нормально, а с роутером срывает соединение...
см. лог
Wed Oct 22 22:47:28 2008 COM2 start to dial-up
Wed Oct 22 22:47:28 2008 COM2: baud=115200
Wed Oct 22 22:47:28 2008 DIAL2: tx ATE0V1
Wed Oct 22 22:47:29 2008 DIAL2: rx ааааааааATE0V1
Wed Oct 22 22:47:30 2008 DIAL2: rx
Wed Oct 22 22:47:31 2008 DIAL2: tx +++
Wed Oct 22 22:47:32 2008 DIAL2: rx
Wed Oct 22 22:47:33 2008 DIAL2: tx +++
Wed Oct 22 22:47:34 2008 DIAL2: rx
Wed Oct 22 22:48:45 2008 DOD:triggered internally
Wed Oct 22 22:48:45 2008 COM2 start to dial-up
Wed Oct 22 22:48:45 2008 COM2: baud=115200
Wed Oct 22 22:48:45 2008 DIAL2: tx ATE0V1
Wed Oct 22 22:48:46 2008 DIAL2: rx ATE0V1
Wed Oct 22 22:48:47 2008 DIAL2: rx
Wed Oct 22 22:48:48 2008 DIAL2: tx +++
Wed Oct 22 22:48:48 2008 DIAL2: rx
Wed Oct 22 22:48:49 2008 DIAL2: tx ATZ
Wed Oct 22 22:48:49 2008 DIAL2: rx OK
Wed Oct 22 22:48:49 2008 DIAL2: tx ATH0
Wed Oct 22 22:48:50 2008 DIAL2: rx OK
Wed Oct 22 22:48:50 2008 DIAL2: tx AT
Wed Oct 22 22:48:50 2008 DIAL2: tx ATE0V1
Wed Oct 22 22:48:51 2008 DIAL2: rx OK
Wed Oct 22 22:48:51 2008 DIAL2: tx AT+CGDCONT=1,"IP","freenet.beeline.ua"
Wed Oct 22 22:48:55 2008 DIAL2: rx OK
Wed Oct 22 22:48:55 2008 DIAL2: tx ATDT*99***1#
Wed Oct 22 22:48:57 2008 DIAL2: rx CONNECT 115200
Wed Oct 22 22:49:06 2008 PAP2: Welcome!
Wed Oct 22 22:49:06 2008 IPCP2: IP is 10.200.4.182
Wed Oct 22 22:49:06 2008 IPCP2: DNS0 is 77.247.218.226
Wed Oct 22 22:49:06 2008 IPCP2: DNS1 is 77.247.218.227
Thu Oct 23 00:09:22 2008 Connection is broken
Thu Oct 23 00:09:22 2008 COM2 start to hang-up
Thu Oct 23 00:09:22 2008 ang-up001
Thu Oct 23 00:09:27 2008 COM2: baud=115200
Thu Oct 23 00:09:28 2008 DIAL2: tx +++
Thu Oct 23 00:09:29 2008 DIAL2: rx E0
Thu Oct 23 00:09:31 2008 DIAL2: tx ATH0
Thu Oct 23 00:09:31 2008 DIAL2: rx OK
Thu Oct 23 00:09:31 2008 ang-up002
Thu Oct 23 00:09:31 2008 ang-up003
Thu Oct 23 00:09:31 2008 ang-up004
Thu Oct 23 00:09:31 2008 ang-up005
Thu Oct 23 00:09:31 2008 ang-up006
Thu Oct 23 00:09:31 2008 ang-up007
Thu Oct 23 00:09:31 2008 ang-up008
Thu Oct 23 00:09:32 2008 ang-up009
Thu Oct 23 00:09:32 2008 ang-up0010
Thu Oct 23 00:12:04 2008 UPP: Eventing NG:-12
Thu Oct 23 00:12:07 2008 DOD:triggered internally
Thu Oct 23 00:12:07 2008 COM2 start to dial-up
Thu Oct 23 00:12:07 2008 COM2 is in console mode
Thu Oct 23 00:12:10 2008 DOD:TCP trigger from 192.168.0.21:2119 to 217.20.175.107:80
Thu Oct 23 00:12:10 2008 COM2 start to dial-up
Thu Oct 23 00:12:10 2008 COM2 is in console mode
Thu Oct 23 00:12:16 2008 DOD:TCP trigger from 192.168.0.21:2192 to 217.20.175.107:80
Thu Oct 23 00:12:16 2008 COM2 start to dial-up
Thu Oct 23 00:12:16 2008 COM2: baud=115200
Thu Oct 23 00:12:16 2008 DIAL2: tx ATE0V1
Thu Oct 23 00:12:17 2008 DIAL2: rx ааааааааATE0V1
Thu Oct 23 00:12:18 2008 DIAL2: tx +++
Thu Oct 23 00:12:20 2008 DIAL2: rx
Thu Oct 23 00:12:21 2008 DIAL2: tx +++
Thu Oct 23 00:12:22 2008 DIAL2: rx
Thu Oct 23 00:12:26 2008 DOD:TCP trigger from 192.168.0.21:2193 to 217.20.175.107:80
Thu Oct 23 00:12:26 2008 COM2 start to dial-up
Thu Oct 23 00:12:26 2008 COM2: baud=115200
Thu Oct 23 00:12:26 2008 DIAL2: tx ATE0V1
Thu Oct 23 00:12:27 2008 DIAL2: rx OK
Thu Oct 23 00:12:27 2008 DIAL2: tx AT+CGDCONT=1,"IP","freenet.beeline.ua"
Thu Oct 23 00:12:31 2008 DIAL2: rx OK
Thu Oct 23 00:12:31 2008 DIAL2: tx ATDT*99***1#
Thu Oct 23 00:12:32 2008 DIAL2: rx CONNECT 115200
Thu Oct 23 00:12:42 2008 PAP2: Welcome!
Thu Oct 23 00:12:42 2008 IPCP2: IP is 10.200.1.183
Thu Oct 23 00:12:42 2008 IPCP2: DNS0 is 77.247.218.226
Thu Oct 23 00:12:42 2008 IPCP2: DNS1 is 77.247.218.227
Thu Oct 23 00:13:12 2008 Connection is broken
Thu Oct 23 00:13:12 2008 COM2 start to hang-up
Thu Oct 23 00:13:12 2008 ang-up001
Thu Oct 23 00:13:12 2008 COM2: baud=115200
Thu Oct 23 00:13:13 2008 DIAL2: tx +++
Thu Oct 23 00:13:14 2008 DIAL2: rx
Thu Oct 23 00:13:16 2008 DIAL2: tx ATH0
Thu Oct 23 00:13:16 2008 DIAL2: rx OK
Thu Oct 23 00:13:16 2008 ang-up002
Thu Oct 23 00:13:16 2008 ang-up003
Thu Oct 23 00:13:16 2008 ang-up004
Thu Oct 23 00:13:16 2008 ang-up005
Thu Oct 23 00:13:16 2008 ang-up006
Thu Oct 23 00:13:16 2008 ang-up007
Thu Oct 23 00:13:16 2008 ang-up008
Thu Oct 23 00:13:16 2008 DOD:TCP trigger from 192.168.0.21:2208 to 217.20.175.107:80
Thu Oct 23 00:13:17 2008 ang-up009
Thu Oct 23 00:13:17 2008 ang-up0010
Thu Oct 23 00:13:17 2008 COM2 start to dial-up
Thu Oct 23 00:13:17 2008 COM2: baud=115200
Thu Oct 23 00:13:17 2008 DIAL2: tx ATE0V1
Thu Oct 23 00:13:18 2008 DIAL2: rx OK
Thu Oct 23 00:13:18 2008 DIAL2: tx AT+CGDCONT=1,"IP","freenet.beeline.ua"
Thu Oct 23 00:13:22 2008 DIAL2: rx OK
Thu Oct 23 00:13:22 2008 DIAL2: tx ATDT*99***1#
Thu Oct 23 00:13:23 2008 DIAL2: rx CONNECT 115200
Thu Oct 23 00:13:28 2008 PAP2: Welcome!
Thu Oct 23 00:13:28 2008 IPCP2: IP is 10.200.1.241
Thu Oct 23 00:13:28 2008 IPCP2: DNS0 is 77.247.218.226
Thu Oct 23 00:13:28 2008 IPCP2: DNS1 is 77.247.218.227
Thu Oct 23 00:14:56 2008 Connection is broken
Thu Oct 23 00:14:56 2008 COM2 start to hang-up
Thu Oct 23 00:14:56 2008 ang-up001
Thu Oct 23 00:14:56 2008 COM2: baud=115200
Thu Oct 23 00:14:57 2008 DIAL2: tx +++
Thu Oct 23 00:14:57 2008 DIAL2: rx "ppЋ »xЭ> ¶Nќ;Р0"Ќ{2\HЖ·!†‰FёWB@Xf А
Thu Oct 23 00:14:59 2008 DIAL2: tx ATH0
Thu Oct 23 00:14:59 2008 DIAL2: rx OK
Thu Oct 23 00:14:59 2008 ang-up002
Thu Oct 23 00:14:59 2008 ang-up003
Thu Oct 23 00:14:59 2008 ang-up004
Thu Oct 23 00:14:59 2008 ang-up005
Thu Oct 23 00:14:59 2008 ang-up006
Thu Oct 23 00:14:59 2008 ang-up007
Thu Oct 23 00:14:59 2008 ang-up008
Thu Oct 23 00:15:00 2008 DOD:TCP trigger from 192.168.0.21:2297 to 81.222.128.24:80
Thu Oct 23 00:15:00 2008 ang-up009
Thu Oct 23 00:15:00 2008 ang-up0010
Thu Oct 23 00:15:00 2008 COM2 start to dial-up
Thu Oct 23 00:15:00 2008 COM2: baud=115200
Thu Oct 23 00:15:00 2008 DIAL2: tx ATE0V1
Thu Oct 23 00:15:01 2008 DIAL2: rx OK
Thu Oct 23 00:15:01 2008 DIAL2: tx AT+CGDCONT=1,"IP","freenet.beeline.ua"
Thu Oct 23 00:15:05 2008 DIAL2: rx OK
Thu Oct 23 00:15:05 2008 DIAL2: tx ATDT*99***1#
Thu Oct 23 00:15:06 2008 DIAL2: rx CONNECT 115200
Thu Oct 23 00:15:11 2008 PAP2: Welcome!
Thu Oct 23 00:15:11 2008 IPCP2: IP is 10.200.2.227
Thu Oct 23 00:15:11 2008 IPCP2: DNS0 is 77.247.218.226
Thu Oct 23 00:15:11 2008 IPCP2: DNS1 is 77.247.218.227
СообщениеДобавлено: Чт окт 23, 2008 14:30
и ещё один лог, да хочу заметить если сделать конект (Connect mode select Always-on) и никто не обращается в интернет, соединение висит часами хоть целый день, но когда открываеш сайт (http://driver.ru/ http://www.rambler.ru/) соединение вроде не срывается, при открытии (http://www.gismeteo.ua/) соединение диалапа срывается страница полузагруженная в браузере жмёш обновить и опять коннект и так по кругу...
P.S. проверено несколько раз...
Сотрудники D-LINKа что вы мне можете посоветовать,
заранее благодарю...
System Logs
Thu Oct 23 00:18:30 2008 DOD:triggered internally
Thu Oct 23 00:18:30 2008 COM2 start to dial-up
Thu Oct 23 00:18:30 2008 COM2: baud=115200
Thu Oct 23 00:18:30 2008 DIAL2: tx ATE0V1
Thu Oct 23 00:18:31 2008 DIAL2: rx OK
Thu Oct 23 00:18:31 2008 DIAL2: tx AT+CGDCONT=1,"IP","freenet.beeline.ua"
Thu Oct 23 00:18:35 2008 DIAL2: rx OK
Thu Oct 23 00:18:35 2008 DIAL2: tx ATDT*99***1#
Thu Oct 23 00:18:36 2008 DIAL2: rx CONNECT 115200
Thu Oct 23 00:18:40 2008 PAP2: Welcome!
Thu Oct 23 00:18:40 2008 IPCP2: IP is 10.200.1.75
Thu Oct 23 00:18:40 2008 IPCP2: DNS0 is 77.247.218.226
Thu Oct 23 00:18:40 2008 IPCP2: DNS1 is 77.247.218.227
Thu Oct 23 00:24:07 2008 Connection is broken
Thu Oct 23 00:24:07 2008 COM2 start to hang-up
Thu Oct 23 00:24:07 2008 ang-up001
Thu Oct 23 00:24:07 2008 COM2: baud=115200
Thu Oct 23 00:24:08 2008 DIAL2: tx +++
Thu Oct 23 00:24:09 2008 DIAL2: rx E(
Thu Oct 23 00:24:11 2008 DIAL2: tx ATH0
Thu Oct 23 00:24:11 2008 DIAL2: rx OK
Thu Oct 23 00:24:11 2008 ang-up002
Thu Oct 23 00:24:11 2008 ang-up003
Thu Oct 23 00:24:11 2008 ang-up004
Thu Oct 23 00:24:11 2008 ang-up005
Thu Oct 23 00:24:11 2008 ang-up006
Thu Oct 23 00:24:11 2008 ang-up007
Thu Oct 23 00:24:11 2008 ang-up008
Thu Oct 23 00:24:12 2008 ang-up009
Thu Oct 23 00:24:12 2008 ang-up0010
Thu Oct 23 00:24:14 2008 DOD:TCP trigger from 192.168.0.21:2409 to 93.158.134.11:80
Thu Oct 23 00:24:14 2008 COM2 start to dial-up
Thu Oct 23 00:24:14 2008 COM2: baud=115200
Thu Oct 23 00:24:14 2008 DIAL2: tx ATE0V1
Thu Oct 23 00:24:15 2008 DIAL2: rx OK
Thu Oct 23 00:24:15 2008 DIAL2: tx AT+CGDCONT=1,"IP","freenet.beeline.ua"
Thu Oct 23 00:24:19 2008 DIAL2: rx OK
Thu Oct 23 00:24:19 2008 DIAL2: tx ATDT*99***1#
Thu Oct 23 00:24:20 2008 DIAL2: rx CONNECT 115200
Thu Oct 23 00:24:25 2008 PAP2: Welcome!
Thu Oct 23 00:24:25 2008 IPCP2: IP is 10.200.3.20
Thu Oct 23 00:24:25 2008 IPCP2: DNS0 is 77.247.218.226
Thu Oct 23 00:24:25 2008 IPCP2: DNS1 is 77.247.218.227
Thu Oct 23 00:27:18 2008 Connection is broken
Thu Oct 23 00:27:18 2008 COM2 start to hang-up
Thu Oct 23 00:27:18 2008 ang-up001
Thu Oct 23 00:27:18 2008 COM2: baud=115200
Thu Oct 23 00:27:19 2008 DIAL2: tx +++
Thu Oct 23 00:27:19 2008 DIAL2: rx E(ы@
Thu Oct 23 00:27:21 2008 DIAL2: tx ATH0
Thu Oct 23 00:27:22 2008 DIAL2: rx OK
Thu Oct 23 00:27:22 2008 ang-up002
Thu Oct 23 00:27:22 2008 ang-up003
Thu Oct 23 00:27:22 2008 ang-up004
Thu Oct 23 00:27:22 2008 ang-up005
Thu Oct 23 00:27:22 2008 ang-up006
Thu Oct 23 00:27:22 2008 ang-up007
Thu Oct 23 00:27:22 2008 ang-up008
Thu Oct 23 00:27:23 2008 ang-up009
Thu Oct 23 00:27:23 2008 ang-up0010
Thu Oct 23 00:27:26 2008 DOD:triggered internally
Thu Oct 23 00:27:26 2008 COM2 start to dial-up
Thu Oct 23 00:27:26 2008 COM2: baud=115200
Thu Oct 23 00:27:26 2008 DIAL2: tx ATE0V1
Thu Oct 23 00:27:27 2008 DIAL2: rx OK
Thu Oct 23 00:27:27 2008 DIAL2: tx AT+CGDCONT=1,"IP","freenet.beeline.ua"
Thu Oct 23 00:27:31 2008 DIAL2: rx OK
Thu Oct 23 00:27:31 2008 DIAL2: tx ATDT*99***1#
Thu Oct 23 00:27:32 2008 DIAL2: rx CONNECT 115200
Thu Oct 23 00:27:36 2008 PAP2: Welcome!
Thu Oct 23 00:27:36 2008 IPCP2: IP is 10.200.0.248
Thu Oct 23 00:27:36 2008 IPCP2: DNS0 is 77.247.218.226
Thu Oct 23 00:27:36 2008 IPCP2: DNS1 is 77.247.218.227
Thu Oct 23 00:27:53 2008 Connection is broken
Thu Oct 23 00:27:53 2008 COM2 start to hang-up
Thu Oct 23 00:27:53 2008 ang-up001
Thu Oct 23 00:27:53 2008 COM2: baud=115200
Thu Oct 23 00:27:54 2008 DIAL2: tx +++
Thu Oct 23 00:27:55 2008 DIAL2: rx E0
Thu Oct 23 00:27:57 2008 DIAL2: tx ATH0
Thu Oct 23 00:27:57 2008 DIAL2: rx OK
Thu Oct 23 00:27:57 2008 ang-up002
Thu Oct 23 00:27:57 2008 ang-up003
Thu Oct 23 00:27:57 2008 ang-up004
Thu Oct 23 00:27:57 2008 ang-up005
Thu Oct 23 00:27:57 2008 ang-up006
Thu Oct 23 00:27:57 2008 ang-up007
Thu Oct 23 00:27:57 2008 ang-up008
Thu Oct 23 00:27:58 2008 DOD:TCP trigger from 192.168.0.21:2526 to 74.125.19.167:80
Thu Oct 23 00:27:58 2008 ang-up009
Thu Oct 23 00:27:58 2008 ang-up0010
Thu Oct 23 00:27:58 2008 COM2 start to dial-up
Thu Oct 23 00:27:58 2008 COM2: baud=115200
Thu Oct 23 00:27:58 2008 DIAL2: tx ATE0V1
Thu Oct 23 00:27:59 2008 DIAL2: rx OK
Thu Oct 23 00:27:59 2008 DIAL2: tx AT+CGDCONT=1,"IP","freenet.beeline.ua"
Thu Oct 23 00:28:03 2008 DIAL2: rx OK
Thu Oct 23 00:28:03 2008 DIAL2: tx ATDT*99***1#
Thu Oct 23 00:28:04 2008 DIAL2: rx CONNECT 115200
Thu Oct 23 00:28:09 2008 PAP2: Welcome!
Thu Oct 23 00:28:09 2008 IPCP2: IP is 10.200.1.153
Thu Oct 23 00:28:09 2008 IPCP2: DNS0 is 77.247.218.226
Thu Oct 23 00:28:09 2008 IPCP2: DNS1 is 77.247.218.227
Thu Oct 23 00:30:17 2008 Connection is broken
Thu Oct 23 00:30:17 2008 COM2 start to hang-up
Thu Oct 23 00:30:17 2008 ang-up001
Thu Oct 23 00:30:17 2008 COM2: baud=115200
Thu Oct 23 00:30:18 2008 DIAL2: tx +++
Thu Oct 23 00:30:19 2008 DIAL2: rx
Thu Oct 23 00:30:21 2008 DIAL2: tx ATH0
Thu Oct 23 00:30:21 2008 DIAL2: rx OK
Thu Oct 23 00:30:21 2008 ang-up002
Thu Oct 23 00:30:21 2008 ang-up003
Thu Oct 23 00:30:21 2008 ang-up004
Thu Oct 23 00:30:21 2008 ang-up005
Thu Oct 23 00:30:21 2008 ang-up006
Thu Oct 23 00:30:21 2008 ang-up007
Thu Oct 23 00:30:21 2008 ang-up008
Thu Oct 23 00:30:22 2008 DOD:TCP trigger from 192.168.0.21:2585 to 85.112.115.53:80
Thu Oct 23 00:30:22 2008 ang-up009
Thu Oct 23 00:30:22 2008 ang-up0010
Thu Oct 23 00:30:22 2008 COM2 start to dial-up
Thu Oct 23 00:30:22 2008 COM2: baud=115200
Thu Oct 23 00:30:22 2008 DIAL2: tx ATE0V1
Thu Oct 23 00:30:23 2008 DIAL2: rx OK
Thu Oct 23 00:30:23 2008 DIAL2: tx AT+CGDCONT=1,"IP","freenet.beeline.ua"
Thu Oct 23 00:30:27 2008 DIAL2: rx OK
Thu Oct 23 00:30:27 2008 DIAL2: tx ATDT*99***1#
Thu Oct 23 00:30:28 2008 DIAL2: rx CONNECT 115200
Thu Oct 23 00:30:33 2008 PAP2: Welcome!
Thu Oct 23 00:30:33 2008 IPCP2: IP is 10.200.0.229
Thu Oct 23 00:30:33 2008 IPCP2: DNS0 is 77.247.218.226
Thu Oct 23 00:30:33 2008 IPCP2: DNS1 is 77.247.218.227
Thu Oct 23 00:44:09 2008 Connection is broken
Thu Oct 23 00:44:09 2008 COM2 start to hang-up
Thu Oct 23 00:44:09 2008 ang-up001
Thu Oct 23 00:44:09 2008 COM2: baud=115200
Thu Oct 23 00:44:10 2008 DIAL2: tx +++
Thu Oct 23 00:44:19 2008 DIAL2: rx nдZйЃk¦®˜є`ZйЃk¦®˜є`ZйЃk¦®˜є`ZйЃХ,mЬ¬©dЮя
Thu Oct 23 00:44:21 2008 DIAL2: tx ATH0
Thu Oct 23 00:44:21 2008 DIAL2: rx OK
Thu Oct 23 00:44:21 2008 ang-up002
Thu Oct 23 00:44:21 2008 ang-up003
Thu Oct 23 00:44:21 2008 ang-up004
Thu Oct 23 00:44:21 2008 ang-up005
Thu Oct 23 00:44:21 2008 ang-up006
Thu Oct 23 00:44:21 2008 ang-up007
Thu Oct 23 00:44:21 2008 ang-up008
Thu Oct 23 00:44:22 2008 ang-up009
Thu Oct 23 00:44:22 2008 ang-up0010
Thu Oct 23 00:44:23 2008 DOD:192.168.0.21 query DNS for img.gad.org.ua
Thu Oct 23 00:44:23 2008 COM2 start to dial-up
Thu Oct 23 00:44:23 2008 COM2: baud=115200
Thu Oct 23 00:44:23 2008 DIAL2: tx ATE0V1
Thu Oct 23 00:44:23 2008 DIAL2: rx OK
Thu Oct 23 00:44:23 2008 DIAL2: tx AT+CGDCONT=1,"IP","freenet.beeline.ua"
Thu Oct 23 00:44:27 2008 DIAL2: rx OK
Thu Oct 23 00:44:27 2008 DIAL2: tx ATDT*99***1#
Thu Oct 23 00:44:28 2008 DIAL2: rx CONNECT 115200
Thu Oct 23 00:44:34 2008 PAP2: Welcome!
Thu Oct 23 00:44:34 2008 IPCP2: IP is 10.200.3.79
Thu Oct 23 00:44:34 2008 IPCP2: DNS0 is 77.247.218.226
Thu Oct 23 00:44:34 2008 IPCP2: DNS1 is 77.247.218.227
Thu Oct 23 00:44:43 2008 COM2 start to hang-up
Thu Oct 23 00:44:43 2008 ang-up001
Thu Oct 23 00:44:43 2008 COM2: baud=115200
Thu Oct 23 00:44:44 2008 DIAL2: tx +++
СообщениеДобавлено: Пт окт 24, 2008 12:32
Мы знаем о проблемах в работе с модемами подключенными через com порт и работаем над их устранением.
Сейчас этот форум просматривают: Baidu [Spider] и гости: 24
