Текущее время: Пт сен 25, 2026 18:22
 Заголовок сообщения: роутер dir 655 WAN interface is down!
СообщениеДобавлено: Ср сен 17, 2008 15:12
незнаю что с этим поделать постояные разрывы лог [INFO] Wed Sep 17 16:09:06 2008 Stored configuration to non-volatile memory
[INFO] Wed Sep 17 16:08:33 2008 Log viewed by IP address 192.168.0.1
[WARN] Wed Sep 17 16:02:07 2008 The remote PPTP access concentrator is slow to respond. There may be connectivity problems.
[INFO] Wed Sep 17 16:01:43 2008 Above message repeated 1 times
[INFO] Wed Sep 17 15:59:09 2008 Log viewed by IP address 192.168.0.1
[INFO] Wed Sep 17 15:59:09 2008 Stored configuration to non-volatile memory
[INFO] Wed Sep 17 15:55:52 2008 Starting WAN Services
[INFO] Wed Sep 17 15:55:52 2008 WAN interface is up. Connection to Internet established with IP Address 79.111.158.113 and default gateway 212.1.254.36
[INFO] Wed Sep 17 15:55:52 2008 WAN interface is down
[INFO] Wed Sep 17 15:55:24 2008 Log viewed by IP address 192.168.0.1
[INFO] Wed Sep 17 15:55:22 2008 WAN interface is down
[INFO] Wed Sep 17 15:55:22 2008 Stopping WAN Services
[INFO] Wed Sep 17 15:55:18 2008 Log viewed by IP address 192.168.0.1
[INFO] Wed Sep 03 22:37:30 2008 Above message repeated 1 times
[INFO] Wed Sep 03 22:36:59 2008 Allowed configuration authentication by IP address 192.168.0.1
[INFO] Wed Sep 03 22:34:37 2008 Starting DHCP server
[INFO] Wed Sep 03 22:34:33 2008 Starting WAN Services
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 55
