Текущее время: Пн ноя 09, 2026 12:35
 Заголовок сообщения: DI-824VUP+ постоянно рвет коннект PPTP
СообщениеДобавлено: Чт май 08, 2008 17:20
1. DI-824VUP+, Current Firmware Version: v2.00, Firmware Date: Wed, Oct 31 2007
2. Настройки выданные провайдером 2КОМ (2COM):
"My Internet Connection is:" Russian PPTP (Dual Access)
Далее в секции "RUSSIA PPTP (DUAL ACCESS) Internet Connection Type :" Static IP
В поле PPTP IP Address: IP адрес по договору
В поле PPTP Subnet Mask: 255.255.255.0
В поле PPTP Gateway IP Address: адрес вашего шлюза
В поле PPTP Server IP or Name: адрес вашего шлюза
В поле User: логин
В поле Password: пароль
В поле Reconnect Mode: Always on
В поле Primary DNS Server: 0.0.0.0
В поле Secondary DNS Server: 0.0.0.0
В поле MTU: 1400
В поле MAC Address: Clone Your PC`s MAC Address
http://www.2com.net/index.php?id=113
3. IP назначен LAN интерфейсу: 192.168.0.1, маска: 255.255.255.0, домен: -
4.
Sun May 04 22:58:22 2008 Unallowable association from: 00-16-CF-46-8A-CD
Sun May 04 22:58:22 2008 PPTP:error=-112
Sun May 04 22:58:22 2008 DOD:TCP trigger from 192.168.0.178:52220 to 193.219.33.215:443
Sun May 04 22:58:22 2008 PPTP start to dial-up
Sun May 04 22:58:22 2008 PPTP server=192.168.53.2
Sun May 04 22:58:26 2008 Unallowable association from: 00-16-CF-46-8A-CD
Sun May 04 22:58:29 2008 Unallowable association from: 00-16-CF-46-8A-CD
Sun May 04 22:58:30 2008 Unallowable association from: 00-16-CF-46-8A-CD
Sun May 04 22:58:37 2008 Unallowable association from: 00-16-CF-46-8A-CD
Sun May 04 22:58:38 2008 Unallowable association from: 00-13-46-DE-B3-D9
Sun May 04 22:58:45 2008 Unallowable association from: 00-16-CF-46-8A-CD
Sun May 04 22:58:47 2008 Unallowable association from: 00-16-CF-46-8A-CD
Sun May 04 22:58:48 2008 Unallowable association from: 00-13-46-DE-B3-D9
Sun May 04 22:58:51 2008 Unallowable association from: 00-16-CF-46-8A-CD
Sun May 04 22:58:54 2008 Unallowable association from: 00-16-CF-46-8A-CD
Sun May 04 22:58:55 2008 Unallowable association from: 00-16-CF-46-8A-CD
Sun May 04 22:58:55 2008 Unallowable association from: 00-13-46-DE-B3-D9
Sun May 04 22:59:00 2008 Unallowable association from: 00-13-46-DE-B3-D9
Sun May 04 22:59:01 2008 Unallowable association from: 00-13-46-DE-B3-D9
Sun May 04 22:59:01 2008 Unallowable association from: 00-16-CF-46-8A-CD
Sun May 04 22:59:03 2008 Unallowable association from: 00-13-46-DE-B3-D9
Sun May 04 22:59:08 2008 Unallowable association from: 00-16-CF-46-8A-CD
Sun May 04 22:59:09 2008 Unallowable association from: 00-16-CF-46-8A-CD
Sun May 04 22:59:16 2008 Unallowable association from: 00-16-CF-46-8A-CD
Sun May 04 22:59:17 2008 Unallowable association from: 00-13-46-DE-B3-D9
Sun May 04 22:59:17 2008 Unallowable association from: 00-16-CF-46-8A-CD
Sun May 04 22:59:18 2008 Unallowable association from: 00-13-46-DE-B3-D9
Sun May 04 22:59:19 2008 Unallowable association from: 00-13-46-DE-B3-D9
Sun May 04 22:59:20 2008 Unallowable association from: 00-13-46-DE-B3-D9
Sun May 04 22:59:22 2008 Unallowable association from: 00-13-46-DE-B3-D9
Sun May 04 22:59:23 2008 Unallowable association from: 00-13-46-DE-B3-D9
Sun May 04 22:59:24 2008 Unallowable association from: 00-16-CF-46-8A-CD
Sun May 04 22:59:25 2008 PPTP:error=-112
Sun May 04 22:59:26 2008 Unallowable association from: 00-16-CF-46-8A-CD
Sun May 04 22:59:26 2008 DOD:TCP trigger from 192.168.0.178:52323 to 147.46.135.241:80
Sun May 04 22:59:26 2008 PPTP start to dial-up
Sun May 04 22:59:26 2008 PPTP server=192.168.53.2
Sun May 04 22:59:27 2008 Unallowable association from: 00-13-46-DE-B3-D9
Sun May 04 23:03:39 2008 PPTP:error=-112
Sun May 04 23:03:39 2008 DOD:TCP trigger from 192.168.0.178:52660 to 75.30.67.185:63763
Sun May 04 23:03:39 2008 PPTP start to dial-up
Sun May 04 23:03:39 2008 PPTP server=192.168.53.2
Sun May 04 23:04:43 2008 PPTP:error=-112
Sun May 04 23:04:43 2008 DOD:TCP trigger from 192.168.0.178:52766 to 210.240.235.246:24544
Sun May 04 23:04:43 2008 PPTP start to dial-up
С первого дня покупки постоянно рвется коннект. Время сеанса разное, бывало и сутки коннект без обрыва, а иногда и 5 сек не держит. Сначала была ошибка 200, а после перепрошивки еще и 112.
СообщениеДобавлено: Ср май 14, 2008 11:01
Есть кто?
Проблема осталась и после перепрошивки. Ошибки 200 и 112.
СообщениеДобавлено: Ср май 14, 2008 15:07
Сложно что-либо сказать.... В логе видно только, что сервер недоступен (Error 112)
СообщениеДобавлено: Ср май 14, 2008 15:12
А ошибка 200 что значит? И где можно посмотреть список этих ошибок?
СообщениеДобавлено: Ср май 14, 2008 16:21
http://www.dlink.ru/technical/faq_internet.php#14
200 - сервер по каким-то причинам отверг подключение.
СообщениеДобавлено: Ср май 14, 2008 17:23
Может стоит прописать маршруты в настройках? Если да, то какие?
СообщениеДобавлено: Ср май 14, 2008 21:31
У меня было практически то же самое. Причем началось после нескольких месяцев стабильной работы.
Вылечилось несколькими грубыми наездами на техподдержку провайдера домашней сети, которые долго уверяли что проблема с моей стороны. После вразумления как-то само прошло, хотя что было - не признались.
СообщениеДобавлено: Чт май 15, 2008 13:30
Меня например постоянно раскручивают на настройку роутера их специалистами. Услуга платная, и стоит она недешево. При этом подробные настройки для моего роутера не предоставляются и на письма они не отвечают. М/б эти палки в колеса являются маркетинговым ходом :shock: Жду Корбину.
СообщениеДобавлено: Сб май 17, 2008 11:36
Сбросил роутер резетом, перепрошил, снова сбросил. Коннект рвется с той же охотой, но теперь еще и ошибка 214 появилась)))
Mon May 05 00:52:39 2008 PPTP start to dial-up
Mon May 05 00:52:39 2008 PPTP server=192.168.xx.2
Mon May 05 00:52:47 2008 CHAP1: Welcome
Mon May 05 00:00:00 2008
Mon May 05 00:52:47 2008 IPCP1: DNS1 is unknown
Mon May 05 00:52:47 2008 IPCP1: IP is 172.30.xx.yy
Mon May 05 00:52:47 2008 IPCP1: DNS0 is 195.98.160.25
Mon May 05 00:53:05 2008 PPTP start to dial-down
Mon May 05 00:53:08 2008 PPTP:error=-200
Mon May 05 00:53:14 2008 DOD:triggered internally
Mon May 05 00:53:14 2008 PPTP start to dial-up
Mon May 05 00:53:14 2008 PPTP server=192.168.xx.2
Mon May 05 00:53:18 2008 PPTP:error=-214
Mon May 05 00:53:19 2008 DOD:UDP trigger from 192.168.0.zzz:123 to 17.72.133.42:123
Mon May 05 00:53:19 2008 PPTP start to dial-up
Mon May 05 00:53:19 2008 PPTP server=192.168.xx.2
Mon May 05 00:53:19 2008 PPTP:error=-112
Mon May 05 00:53:28 2008 DOD:triggered internally
Mon May 05 00:53:28 2008 PPTP start to dial-up
 Заголовок сообщения: Та же проблема
СообщениеДобавлено: Вс май 18, 2008 12:01
Постоянно рвет коннект каждые 45- 60 минут причем регулярно..
Кто то говорит перегревается кто то говорит что неисправен..
А мне уже пох..... жаль что деньги выкинул зря..
Кстати кто нить может последнюю прошивку дать на D-Link DI-824VUP+.
Заранее спасибо.. И еще интересно никто их не тюнингует?
Провайдер у меня Корбина. Живу в бутово
 Заголовок сообщения: Re: Та же проблема
СообщениеДобавлено: Пн май 19, 2008 10:43
Если используются p2p клиенты, ограничте количество соединений на них,
Сейчас этот форум просматривают: Baidu [Spider] и гости: 26
