Текущее время: Чт окт 01, 2026 13:24
 Заголовок сообщения: 2740 u
СообщениеДобавлено: Сб мар 15, 2008 23:13
Проблема такая по WAN подключение ограничено или отсутствует, а по WLAN подключаетсят олько один из двух компов что сделать чтоб усё нормально работало?
Firmware Version: DRU_DSL-2740U_3.06L.04V_1.23.A2pB021c.d17m
LOG :view&configure
Date/Time
Facility
Severity
Message
Jan 1 02:09:05 syslog emerg BCM96345 started: BusyBox v1.00 (2007.02.07-13:36+0000)
Jan 1 02:09:05 user warn kernel: pSdramPHY=0xA1FFFFF8, 0x1B78BC 0xDEADBEEF
Jan 1 02:09:05 user warn kernel: AdslCoreHwReset: AdslOemDataAddr = 0xA1FFB114
Jan 1 02:09:05 user warn kernel: dgasp: kerSysRegisterDyingGaspHandler: dsl0 registered
Jan 1 02:09:05 user crit kernel: eth0 Link UP.
Jan 1 02:09:05 user warn kernel: ip_tables: (C) 2000-2002 Netfilter core team
Jan 1 02:09:05 user warn kernel: ip_conntrack version 2.1 (253 buckets, 0 max) - 368 bytes per conntrack
Jan 1 02:09:05 user warn kernel: ip_conntrack_pptp version 2.1 loaded
Jan 1 02:09:05 user warn kernel: ip_nat_pptp version 2.0 loaded
Jan 1 02:09:05 user warn kernel: ip_conntrack_h323: init
Jan 1 02:09:05 user warn kernel: ip_nat_h323: initialize the module!
Jan 1 02:09:05 user warn kernel: ip_conntrack_rtsp v0.01 loading
Jan 1 02:09:05 user crit kernel: ADSL G.994 training
Jan 1 02:09:05 user warn kernel: ip_nat_rtsp v0.01 loading
Jan 1 02:09:05 user info kernel: device eth0 entered promiscuous mode
Jan 1 02:09:05 user info kernel: br0: port 1(eth0) entering learning state
Jan 1 02:09:05 user info kernel: br0: topology change detected, propagating
Jan 1 02:09:05 user info kernel: br0: port 1(eth0) entering forwarding state
Jan 1 02:09:05 user crit kernel: ADSL G.992 started
Jan 1 02:09:05 user crit kernel: ADSL G.992 channel analysis
Jan 1 02:09:05 user info kernel: device wl0 entered promiscuous mode
Jan 1 02:09:05 user info kernel: br0: port 2(wl0) entering learning state
Jan 1 02:09:05 user info kernel: br0: port 2(wl0) entering forwarding state
Jan 1 02:09:05 user info kernel: device wl0.1 entered promiscuous mode
Jan 1 02:09:05 user info kernel: device nas_8_35 entered promiscuous mode
Jan 1 02:09:05 user info kernel: br0: port 4(nas_8_35) entering learning state
Jan 1 02:09:05 user info kernel: br0: port 4(nas_8_35) entering forwarding state
Jan 1 02:09:05 user crit kernel: nge
Jan 1 02:09:05 user crit kernel: ADSL link up, interleaved, us=587, ds=8963
Jan 1 02:09:05 user alert kernel: Intrusion -> IN=ppp_8_35_1 OUT= MAC= SRC=195.13.166.234 DST=88.205.160.241 LEN=48 TOS=0x00 PREC=0x00 TTL=113 ID=27697 DF PROTO=TCP SPT=2950 DPT=16253 WINDOW=65535 RES=0x00 SYN URGP=0
Jan 1 02:09:05 user info kernel: br0: port 2(wl0) entering disabled state
Jan 1 02:09:05 user alert kernel: Intrusion -> IN=ppp_8_35_1 OUT= MAC= SRC=91.124.135.164 DST=88.205.160.241 LEN=52 TOS=0x00 PREC=0x00 TTL=47 ID=65352 DF PROTO=TCP SPT=11401 DPT=16253 WINDOW=65535 RES=0x00 SYN URGP=0
Jan 1 02:09:05 user alert kernel: Intrusion -> IN=ppp_8_35_1 OUT= MAC= SRC=91.124.135.164 DST=88.205.160.241 LEN=52 TOS=0x00 PREC=0x00 TTL=47 ID=75 DF PROTO=TCP SPT=11401 DPT=16253 WINDOW=65535 RES=0x00 SYN URGP=0
Jan 1 02:09:05 user alert kernel: Intrusion -> IN=ppp_8_35_1 OUT= MAC= SRC=77.51.125.191 DST=88.205.160.241 LEN=48 TOS=0x00 PREC=0x00 TTL=121 ID=64785 DF PROTO=TCP SPT=4515 DPT=16253 WINDOW=65535 RES=0x00 SYN URGP=0
Jan 1 02:09:05 user alert kernel: Intrusion -> IN=ppp_8_35_1 OUT= MAC= SRC=77.51.125.191 DST=88.205.160.241 LEN=48 TOS=0x00 PREC=0x00 TTL=121 ID=65052 DF PROTO=TCP SPT=4515 DPT=16253 WINDOW=65535 RES=0x00 SYN URGP=0
Jan 1 02:09:05 user alert kernel: Intrusion -> IN=ppp_8_35_1 OUT= MAC= SRC=87.79.206.188 DST=88.205.160.241 LEN=52 TOS=0x00 PREC=0x00 TTL=119 ID=41780 DF PROTO=TCP SPT=4522 DPT=16253 WINDOW=32767 RES=0x00 SYN URGP=0
Jan 1 02:09:05 user alert kernel: Intrusion -> IN=ppp_8_35_1 OUT= MAC= SRC=87.79.206.188 DST=88.205.160.241 LEN=52 TOS=0x00 PREC=0x00 TTL=119 ID=41941 DF PROTO=TCP SPT=4522 DPT=16253 WINDOW=32767 RES=0x00 SYN URGP=0
Jan 1 02:09:05 user alert kernel: Intrusion -> IN=ppp_8_35_1 OUT= MAC= SRC=87.79.206.188 DST=88.205.160.241 LEN=52 TOS=0x00 PREC=0x00 TTL=119 ID=42285 DF PROTO=TCP SPT=4522 DPT=16253 WINDOW=32767 RES=0x00 SYN URGP=0
Jan 1 02:09:05 user alert kernel: Intrusion -> IN=ppp_8_35_1 OUT= MAC= SRC=84.159.253.217 DST=88.205.160.241 LEN=48 TOS=0x00 PREC=0x00 TTL=114 ID=13037 DF PROTO=TCP SPT=2175 DPT=16253 WINDOW=64240 RES=0x00 SYN URGP=0
Jan 1 02:09:05 user alert kernel: Intrusion -> IN=ppp_8_35_1 OUT= MAC= SRC=84.159.253.217 DST=88.205.160.241 LEN=48 TOS=0x00 PREC=0x00 TTL=114 ID=13319 DF PROTO=TCP SPT=2175 DPT=16253 WINDOW=64240 RES=0x00 SYN URGP=0
Jan 1 02:09:05 user alert kernel: Intrusion -> IN=ppp_8_35_1 OUT= MAC= SRC=195.22.140.72 DST=88.205.160.241 LEN=48 TOS=0x00 PREC=0x00 TTL=115 ID=30057 DF PROTO=TCP SPT=29798 DPT=16253 WINDOW=65535 RES=0x00 SYN URGP=0
Jan 1 02:09:05 user alert kernel: Intrusion -> IN=ppp_8_35_1 OUT= MAC= SRC=89.19.165.149 DST=88.205.160.241 LEN=48 TOS=0x00 PREC=0x00 TTL=118 ID=46101 DF PROTO=TCP SPT=55583 DPT=16253 WINDOW=65535 RES=0x00 SYN URGP=0
Jan 1 02:09:05 user alert kernel: Intrusion -> IN=ppp_8_35_1 OUT= MAC= SRC=91.78.22.226 DST=88.205.160.241 LEN=48 TOS=0x00 PREC=0x00 TTL=117 ID=61782 DF PROTO=TCP SPT=20545 DPT=16253 WINDOW=16384 RES=0x00 SYN URGP=0
Jan 1 02:09:05 user alert kernel: Intrusion -> IN=ppp_8_35_1 OUT= MAC= SRC=77.235.105.92 DST=88.205.160.241 LEN=48 TOS=0x00 PREC=0x00 TTL=115 ID=55993 DF PROTO=TCP SPT=4623 DPT=16253 WINDOW=65535 RES=0x00 SYN URGP=0
Jan 1 02:09:05 user alert kernel: Intrusion -> IN=ppp_8_35_1 OUT= MAC= SRC=77.235.105.92 DST=88.205.160.241 LEN=48 TOS=0x00 PREC=0x00 TTL=115 ID=56063 DF PROTO=TCP SPT=4623 DPT=16253 WINDOW=65535 RES=0x00 SYN URGP=0
Jan 1 02:09:05 user alert kernel: Intrusion -> IN=ppp_8_35_1 OUT= MAC= SRC=77.235.105.92 DST=88.205.160.241 LEN=48 TOS=0x00 PREC=0x00 TTL=115 ID=56125 DF PROTO=TCP SPT=4623 DPT=16253 WINDOW=65535 RES=0x00 SYN URGP=0
Jan 1 02:09:05 user alert kernel: Intrusion -> IN=ppp_8_35_1 OUT= MAC= SRC=78.36.134.8 DST=88.205.160.241 LEN=48 TOS=0x00 PREC=0x00 TTL=121 ID=18874 DF PROTO=TCP SPT=1655 DPT=16253 WINDOW=65535 RES=0x00 SYN URGP=0
Jan 1 02:09:05 user crit kernel: ADSL link down
Jan 1 02:09:05 user warn kernel: BcmAdsl_Initialize=0xC005D228, g_pFnNotifyCallback=0xC00736B4
Jan 1 02:09:05 user warn kernel: Saving OEM data from 0xA1FFB114
Jan 1 02:09:05 user warn kernel: Restoring OEM data from 0xA1FFB114
Jan 1 02:09:05 user warn kernel: Dennis:core reset finish
Jan 1 02:09:05 user crit kernel: ADSL G.992 message exchange
Jan 1 02:09:05 user crit kernel: ADSL link up, interleaved, us=466, ds=8967
Jan 1 02:09:05 user alert kernel: T= MAC= SRC=90.151.131.179 DST=90.151.155.83 LEN=48 TOS=0x00 PREC=0x00 TTL=121 ID=60446 DF PROTO=TCP SPT=3747 DPT=1433 WINDOW=65320 RES=0x00 SYN URGP=0
Jan 1 02:09:05 user alert kernel: Intrusion -> IN=ppp_8_35_1 OUT= MAC= SRC=90.151.131.179 DST=90.151.155.83 LEN=48 TOS=0x00 PREC=0x00 TTL=121 ID=61534 DF PROTO=TCP SPT=3747 DPT=1433 WINDOW=65320 RES=0x00 SYN URGP=0
Jan 1 02:09:05 user alert kernel: Intrusion -> IN=ppp_8_35_1 OUT= MAC= SRC=90.151.189.3 DST=90.151.155.83 LEN=48 TOS=0x00 PREC=0x00 TTL=122 ID=14538 DF PROTO=TCP SPT=1655 DPT=1433 WINDOW=64800 RES=0x00 SYN URGP=0
Jan 1 02:09:05 user alert kernel: Intrusion -> IN=ppp_8_35_1 OUT= MAC= SRC=90.151.189.3 DST=90.151.155.83 LEN=48 TOS=0x00 PREC=0x00 TTL=122 ID=15602 DF PROTO=TCP SPT=1655 DPT=1433 WINDOW=64800 RES=0x00 SYN URGP=0
Jan 1 02:09:05 user alert kernel: Intrusion -> IN=ppp_8_35_1 OUT= MAC= SRC=90.151.137.53 DST=90.151.155.83 LEN=48 TOS=0x00 PREC=0x00 TTL=121 ID=61795 DF PROTO=TCP SPT=3089 DPT=1433 WINDOW=65320 RES=0x00 SYN URGP=0
Jan 1 02:09:05 user alert kernel: Intrusion -> IN=ppp_8_35_1 OUT= MAC= SRC=90.151.137.53 DST=90.151.155.83 LEN=48 TOS=0x00 PREC=0x00 TTL=121 ID=63002 DF PROTO=TCP SPT=3089 DPT=1433 WINDOW=65320 RES=0x00 SYN URGP=0
Jan 1 02:09:05 user alert kernel: Intrusion -> IN=ppp_8_35_1 OUT= MAC= SRC=90.151.105.204 DST=90.151.155.83 LEN=48 TOS=0x00 PREC=0x00 TTL=121 ID=50647 DF PROTO=TCP SPT=1852 DPT=1433 WINDOW=16384 RES=0x00 SYN URGP=0
Jan 1 02:09:05 user alert kernel: Intrusion -> IN=ppp_8_35_1 OUT= MAC= SRC=90.151.105.204 DST=90.151.155.83 LEN=48 TOS=0x00 PREC=0x00 TTL=121 ID=51436 DF PROTO=TCP SPT=1852 DPT=1433 WINDOW=16384 RES=0x00 SYN URGP=0
Jan 1 02:09:05 user alert kernel: Intrusion -> IN=ppp_8_35_1 OUT= MAC= SRC=90.151.137.53 DST=90.151.155.83 LEN=48 TOS=0x00 PREC=0x00 TTL=121 ID=8003 DF PROTO=TCP SPT=3558 DPT=1433 WINDOW=65320 RES=0x00 SYN URGP=0
Jan 1 02:09:05 user alert kernel: Intrusion -> IN=ppp_8_35_1 OUT= MAC= SRC=90.151.137.53 DST=90.151.155.83 LEN=48 TOS=0x00 PREC=0x00 TTL=121 ID=9038 DF PROTO=TCP SPT=3558 DPT=1433 WINDOW=65320 RES=0x00 SYN URGP=0
Jan 1 02:09:05 user alert kernel: Intrusion -> IN=ppp_8_35_1 OUT= MAC= SRC=219.232.238.43 DST=90.151.155.83 LEN=40 TOS=0x00 PREC=0x00 TTL=99 ID=256 PROTO=TCP SPT=6000 DPT=1433 WINDOW=16384 RES=0x00 SYN URGP=0
Jan 1 02:09:05 user alert kernel: Intrusion -> IN=ppp_8_35_1 OUT= MAC= SRC=90.151.103.70 DST=90.151.155.83 LEN=48 TOS=0x00 PREC=0x00 TTL=121 ID=41503 DF PROTO=TCP SPT=2980 DPT=2967 WINDOW=65320 RES=0x00 SYN URGP=0
Jan 1 02:09:05 user alert kernel: Intrusion -> IN=ppp_8_35_1 OUT= MAC= SRC=90.151.22.142 DST=90.151.155.83 LEN=48 TOS=0x00 PREC=0x00 TTL=121 ID=54250 DF PROTO=TCP SPT=1107 DPT=1433 WINDOW=65320 RES=0x00 SYN URGP=0
Jan 1 02:09:05 user alert kernel: Intrusion -> IN=ppp_8_35_1 OUT= MAC= SRC=90.151.138.192 DST=90.151.155.83 LEN=48 TOS=0x00 PREC=0x00 TTL=121 ID=35664 DF PROTO=TCP SPT=4904 DPT=2967 WINDOW=65320 RES=0x00 SYN URGP=0
Jan 1 02:09:05 user alert kernel: Intrusion -> IN=ppp_8_35_1 OUT= MAC= SRC=90.151.138.192 DST=90.151.155.83 LEN=48 TOS=0x00 PREC=0x00 TTL=121 ID=37660 DF PROTO=TCP SPT=4904 DPT=2967 WINDOW=65320 RES=0x00 SYN URGP=0
Jan 1 02:09:05 user alert kernel: Intrusion -> IN=ppp_8_35_1 OUT= MAC= SRC=90.151.138.192 DST=90.151.155.83 LEN=48 TOS=0x00 PREC=0x00 TTL=121 ID=32458 DF PROTO=TCP SPT=3915 DPT=2967 WINDOW=65320 RES=0x00 SYN URGP=0
Jan 1 02:09:05 user alert kernel: Intrusion -> IN=ppp_8_35_1 OUT= MAC= SRC=90.151.138.192 DST=90.151.155.83 LEN=48 TOS=0x00 PREC=0x00 TTL=121 ID=34147 DF PROTO=TCP SPT=3915 DPT=2967 WINDOW=65320 RES=0x00 SYN URGP=0
Jan 1 02:09:05 user alert kernel: Intrusion -> IN=ppp_8_35_1 OUT= MAC= SRC=90.151.130.150 DST=90.151.155.83 LEN=48 TOS=0x00 PREC=0x00 TTL=121 ID=32240 DF PROTO=TCP SPT=4925 DPT=5900 WINDOW=65320 RES=0x00 SYN URGP=0
Jan 1 02:09:05 user alert kernel: Intrusion -> IN=ppp_8_35_1 OUT= MAC= SRC=90.151.130.150 DST=90.151.155.83 LEN=48 TOS=0x00 PREC=0x00 TTL=121 ID=32241 DF PROTO=TCP SPT=4940 DPT=5900 WINDOW=65320 RES=0x00 SYN URGP=0
Jan 1 02:09:21 user debug syslog: ethctl vport query 2>/var/vcfgerr
Jan 1 02:09:21 user debug syslog: rm /var/vcfgerr
Jan 1 02:09:22 user debug syslog: ping -c 1 -q 10.212.50.24
Jan 1 02:09:33 user debug syslog: ping -c 1 -q 195.54.2.1
Jan 1 02:22:55 user alert kernel: Intrusion -> IN=ppp_8_35_1 OUT= MAC= SRC=90.151.130.150 DST=90.151.155.83 LEN=48 TOS=0x00 PREC=0x00 TTL=121 ID=28362 DF PROTO=TCP SPT=3661 DPT=2967 WINDOW=65320 RES=0x00 SYN URGP=0
Jan 1 02:29:59 user alert kernel: Intrusion -> IN=ppp_8_35_1 OUT= MAC= SRC=90.151.130.150 DST=90.151.155.83 LEN=48 TOS=0x00 PREC=0x00 TTL=121 ID=31450 DF PROTO=TCP SPT=3996 DPT=2967 WINDOW=65320 RES=0x00 SYN URGP=0
Jan 1 02:33:41 user debug igmp[2791]: iptables -t filter -I FORWARD 1 -i br0 -d 239.255.255.250 -j DROP 2>/dev/null
Jan 1 02:33:41 user debug igmp[2793]: iptables -t filter -D FORWARD -i br0 -d 239.255.255.250 -j ACCEPT 2>/dev/null
Jan 1 02:34:45 user debug igmp[2813]: iptables -t filter -I FORWARD 1 -i br0 -d 239.255.255.250 -j DROP 2>/dev/null
Jan 1 02:34:45 user debug igmp[2815]: iptables -t filter -D FORWARD -i br0 -d 239.255.255.250 -j ACCEPT 2>/dev/null
Jan 1 02:35:08 user debug syslog: wlctl authe_sta_list > /var/wl_authe
Jan 1 02:35:08 user debug syslog: wlctl assoclist > /var/wl_assoc
Jan 1 02:35:08 user debug syslog: wlctl autho_sta_list > /var/wl_autho
Copyright © 2007 D-Link Systems, Inc.
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 160
