Текущее время: Вс ноя 08, 2026 05:04
СообщениеДобавлено: Пт ноя 16, 2007 00:30
DI-804HV Firmware Version: V1.44b11, Fri, Feb 09 2007
Настройки, выданные провайдером МТУ Интел (через Никос, Мытищи):
My IP Address 10.11.52.241
My Subnet Mask 255.255.255.0
My Gateway 10.11.52.1
Server IP/Name 10.0.0.1
PPTP Account ***
PPTP Password ***
LAN
IP Address 192.168.0.1
DHCP Server Disabled
MAC Address у провайдера прописан
Лог:
WAN Type: PPTP (V1.44b11)
Display time: Friday February 09, 2007 00:04:26
Friday February 09, 2007 00:00:04 DOD:triggered internally
Friday February 09, 2007 00:00:04 PPTP start to dial-up
Friday February 09, 2007 00:00:04 PPTP server=10.0.0.1
Friday February 09, 2007 00:01:10 PPTP:error=-112
Friday February 09, 2007 00:01:14 DOD:triggered internally
Friday February 09, 2007 00:01:14 PPTP start to dial-up
Friday February 09, 2007 00:01:14 PPTP server=10.0.0.1
Friday February 09, 2007 00:01:36 Restarted by 192.168.0.10
Friday February 09, 2007 00:01:38 DOD:UDP trigger from 192.168.0.10:33868 to 87.110.162.164:7678
Friday February 09, 2007 00:01:38 PPTP start to dial-up
Friday February 09, 2007 00:01:38 PPTP server=10.0.0.1
Friday February 09, 2007 00:02:45 PPTP:error=-112
Friday February 09, 2007 00:02:45 DOD:TCP trigger from 192.168.0.10:4386 to 85.254.180.15:31074
Friday February 09, 2007 00:02:45 PPTP start to dial-up
Friday February 09, 2007 00:02:45 PPTP server=10.0.0.1
Friday February 09, 2007 00:03:45 PPTP:error=-112
Friday February 09, 2007 00:03:45 DOD:TCP trigger from 192.168.0.10:4426 to 84.193.169.38:443
Friday February 09, 2007 00:03:45 PPTP start to dial-up
Friday February 09, 2007 00:03:45 PPTP server=10.0.0.1
Status
LAN
MAC Address 00-0D-88-02-54-62
WAN
MAC Address 00-15-58-3B-90-95
Connection PPTP Disconnected
IP Address 0.0.0.0
Connection Time -
Subnet Mask 255.255.255.255
Gateway 0.0.0.0
Domain Name Server 212.188.4.10, 195.34.32.116
Peripheral
Dial-up Modem Not ready
Device Time: Fri Feb 09 00:05:26 2007
После настройки инет есть в течении 10 мин. Потом обрывается и логах только ошибка 112 или 200.При выключении и включении устройства коннекта больше нет. Пинг до 10.0.0.1 и 10.11.52.1 есть, до www.ya.ru нет.
Прошивал разными прошивками с Вашего сайта - ситуация абсолютно одинаковая. Носил девайс к провайдеру. Сказали, что все настройки правильные и что такие глюки у длинк бывают. Посоветовали опять перепрошить. Посоветуйте что ещё можно сделать. Комп, подключенный напрямую к инету с этими настройками работает замечательно.
СообщениеДобавлено: Вт ноя 20, 2007 15:23
Up
Ну что, dlink мне не ответит?
СообщениеДобавлено: Вт ноя 20, 2007 16:35
Раньше стоял комп и все работало, а теперь воткнул роутер и не пашет ? Прально ?
поинтересуйся у провайдера а нет ли у него привязки по MAC адресу ?
была ситуация один в один !
Позвонил провайдеру, сняли привязку (предупредили, типа а вы вкурсе , что если привязку убрать то любой с вашим ip и с вашим логином может в инет лазить =) ) , настроил , проверил ... заработало
Снова позвонил провайдеру, попросил чтоб вернули привязку, тока к MAC'у сетевухи которая торчит сейчас (т.е. перепривязали к MAC'у WAN порта роутера).
И было мне счастье =)
и тебе скорее всего будет.
удачи=)
СообщениеДобавлено: Чт ноя 22, 2007 18:00
я попробовал - щастья не было
все аналогично прошивка последняя b11
PPTP for Russia
Dynamic
connect живет 15 мин
в логах ноль
