Текущее время: Сб окт 03, 2026 12:20
 Заголовок сообщения: Проблемма с DSA - 3110
СообщениеДобавлено: Пн окт 29, 2007 15:34
После прошивки аппарат потерял все настройки подключения.
По терминалу пишет следующее:
Ethernet eth1: MAC address 00:00:83:38:50:02
IP: 10.9.9.1/255.255.255.0, Gateway: 10.9.9.1
Default server: 10.9.9.10, DNS server IP: 0.0.0.0
EM-434 Ver.AB0 2006-02-06 (For Ver.AB)
RedBoot(tm) bootstrap and debug environment [ROM]
Non-certified release, version UNKNOWN - built 19:15:21, Feb 7 2006
Platform: CastleNet IXP425 Development Platform (XScale)
Copyright (C) 2000, 2001, 2002, Red Hat, Inc.
RAM: 0x00000000-0x04000000, 0x00067ef0-0x1ffd1000 available
FLASH: 0x50000000 - 0x51000000, 128 blocks of 0x00020000 bytes each.
Booting Menu: default loading linux
1. Linux booting
2. Redboot command line
Please select:2
== Executing boot script in 1.000 seconds - enter ^C to abort
RedBoot> fis load ramdisk
RedBoot> fis load zimage
RedBoot> exec
Using base address 0x11600000 and length 0x00200000
Uncompressing Linux..................................................................... done, booting the kernel.
Linux version 2.6.13-mppe-mppc (sanya@sanya) (gcc version 4.0.3) #1 Fri Nov 24 13:19:17 MSK 2006
CPU: XScale-IXP42x Family [690541f1] revision 1 (ARMv5TE)
Machine: Intel IXDP425 Development Platform
Memory policy: ECC disabled, Data cache writeback
CPU0: D VIVT undefined 5 cache
CPU0: I cache: 32768 bytes, associativity 32, 32 byte lines, 32 sets
CPU0: D cache: 32768 bytes, associativity 32, 32 byte lines, 32 sets
Built 1 zonelists
Kernel command line: console=ttyS0,115200 root=/dev/ram0 initrd=0x00800000,8M mem=64M@0x00000000
PID hash table entries: 512 (order: 9, 8192 bytes)
Console: colour dummy device 80x30
Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
Memory: 64MB = 64MB total
Memory: 54400KB available (1729K code, 380K data, 96K init)
Mount-cache hash table entries: 512
CPU: Testing write buffer coherency: ok
checking if image is initramfs...it isn't (no cpio magic); looks like an initrd
Freeing initrd memory: 8192K
NET: Registered protocol family 16
PCI: IXP4xx is host
PCI: IXP4xx Using direct access for memory space
PCI: bus0: Fast back to back transfers enabled
dmabounce: registered device 0000:00:01.0 on pci bus
dmabounce: registered device 0000:00:02.0 on pci bus
TC classifier action (bugs to netdev@vger.kernel.org cc hadi@cyberus.ca)
NetWinder Floating Point Emulator V0.97 (double precision)
JFFS2 version 2.2. (NAND) (C) 2001-2003 Red Hat, Inc.
Initializing Cryptographic API
Serial: 8250/16550 driver $Revision: 1.90 $ 4 ports, IRQ sharing disabled
ttyS0 at MMIO 0xc8000000 (irq = 15) is a XScale
ttyS1 at MMIO 0xc8001000 (irq = 15) is a XScale
io scheduler noop registered
io scheduler anticipatory registered
io scheduler deadline registered
io scheduler cfq registered
RAMDISK driver initialized: 2 RAM disks of 32768K size 1024 blocksize
loop: loaded (max 8 devices)
IXP4XX-Flash.0: Found 1 x16 devices at 0x0 in 16-bit bank
Intel/Sharp Extended Query Table at 0x0031
Using buffer write method
cfi_cmdset_0001: Erase suspend on write enabled
Searching for RedBoot partition table in IXP4XX-Flash.0 at offset 0xfe0000
8 RedBoot partitions found on MTD device IXP4XX-Flash.0
Creating 8 MTD partitions on "IXP4XX-Flash.0":
0x00000000-0x00060000 : "RedBoot"
0x00060000-0x00080000 : "mac"
0x00080000-0x00180000 : "params"
0x00180000-0x00380000 : "zimage"
0x00380000-0x00b80000 : "ramdisk"
0x00b80000-0x00fc0000 : "unallocated"
0x00fc0000-0x00fc1000 : "RedBoot config"
0x00fe0000-0x01000000 : "FIS directory"
NET: Registered protocol family 2
IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
TCP established hash table entries: 4096 (order: 3, 32768 bytes)
TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
TCP: Hash tables configured (established 4096 bind 4096)
TCP reno registered
TCP bic registered
NET: Registered protocol family 17
NET: Registered protocol family 15
RAMDISK: Compressed image found at block 0
EXT2-fs warning: mounting unchecked fs, running e2fsck is recommended
VFS: Mounted root (ext2 filesystem).
Freeing init memory: 96K
Loading kernel modules...
Using /lib/modules/2.6.13-mppe-mppc/kernel/drivers/dlink/ixp425_rtc.ko
Module rtc v0.2 init
Using /lib/modules/2.6.13-mppe-mppc/kernel/drivers/dlink/gpio-led.ko
Module gpio led v0.1 init
Using /lib/modules/2.6.13-mppe-mppc/kernel/drivers/dlink/checkont.ko
checkont: successfully!
Using /lib/modules/2.6.13-mppe-mppc/kernel/drivers/ixp400.ko
ixp400: module license 'unspecified' taints kernel.
Intel IXP425 hardware manager v0.1
succeed
Using /lib/modules/2.6.13-mppe-mppc/kernel/drivers/net/ixp400_eth.ko
ixp400_eth: Initializing IXP400 NPE Ethernet driver software v. 1.4A
ixp400_eth: CPU clock speed (approx) = 266 MHz
[error] ixNpeDlImageMgrImageFind: imageId not found in image library header
ixp400_eth: Error starting NPE for Ethernet port 0!
insmod: cannot insert `/lib/modules/2.6.13-mppe-mppc/kernel/drivers/net/ixp400_eth.ko': Operation not permitted (-1): Operation not permitted
modprobe: failed to load module ixp400_eth
Using /lib/modules/2.6.13-mppe-mppc/kernel/drivers/net/8139too.ko
8139too Fast Ethernet driver 0.9.27
PCI: enabling device 0000:00:01.0 (0140 -> 0143)
eth0: RealTek RTL8139 at 0x1000, 22:11:44:33:66:55, IRQ 28
PCI: enabling device 0000:00:02.0 (0140 -> 0143)
eth1: RealTek RTL8139 at 0x1400, 22:11:44:33:66:55, IRQ 27
Using /lib/modules/2.6.13-mppe-mppc/kernel/net/8021q/8021q.ko
802.1Q VLAN Support v1.8 Ben Greear <greearb@candelatech.com>
All bugs added by David S. Miller <davem@redhat.com>
modprobe: module nf_conntrack_pptp not found.
modprobe: failed to load module nf_conntrack_pptp
Using /lib/modules/2.6.13-mppe-mppc/kernel/drivers/char/n_hdlc.ko
HDLC line discipline: version $Revision: 4.8 $, maxframe=4096
N_HDLC line discipline registered.
Using /lib/modules/2.6.13-mppe-mppc/kernel/drivers/net/slhc.koCSLIP: code copyright 1989 Regents of the University of California
Using /lib/modules/2.6.13-mppe-mppc/kernel/drivers/net/ppp_generic.ko
PPP generic driver version 2.4.2
Using /lib/modules/2.6.13-mppe-mppc/kernel/drivers/net/pppox.ko
NET: Registered protocol family 24
Using /lib/modules/2.6.13-mppe-mppc/kernel/drivers/net/pppoe.ko
Using /lib/modules/2.6.13-mppe-mppc/kernel/drivers/net/ppp_synctty.ko
Using /lib/modules/2.6.13-mppe-mppc/kernel/lib/crc-ccitt.ko
Using /lib/modules/2.6.13-mppe-mppc/kernel/drivers/net/ppp_async.ko
Using /lib/modules/2.6.13-mppe-mppc/kernel/drivers/net/ppp_deflate.ko
PPP Deflate Compression module registered
Using /lib/modules/2.6.13-mppe-mppc/kernel/drivers/net/bsd_comp.ko
PPP BSD Compression module registered
Using /lib/modules/2.6.13-mppe-mppc/kernel/crypto/arc4.ko
Using /lib/modules/2.6.13-mppe-mppc/kernel/crypto/sha1.ko
modprobe: module ppp_mppe not found.
modprobe: failed to load module ppp_mppe
Using /lib/modules/2.6.13-mppe-mppc/kernel/drivers/net/ppp_mppe_mppc.ko
MPPE/MPPC encryption/compression module registered
Starting system logging: done.
System time...
timezone hour offset = "-3"
name=MSK-3MSD, exported "MSK-3MSD"
base address 0x64
rtcclock: Mon Oct 29 07:33:19 2007
Timezone:
minutes to west: 0
dst time : 0
RTC clock: Mon Oct 29 07:33:19 2007
date: Mon Oct 29 10:33:19 MSK 2007
done.
Initializing random number generator... done.
Preparing auto config from "/proc/mtd" into /tmp/eth-conf...
Getting MAC address...
dev: size erasesize name
mtd0: 00060000 00020000 "RedBoot"
mtd1: 00020000 00020000 "mac"
OK: MAC mtd partition founded on /dev/mtd1
sizeof struct macrecord=7
Config file named "/etc/default/eth_macs" not found,
/tmp/eth-conf: eth0 has mac 00:90:0B:0A:44:FA
Checking spelling for "00:90:0B:0A:44:FA"...OK
INTERFACE eth0 SUCCESSFULLY CONFIGURED WITH 00:90:0B:0A:44:FA..........OK
/tmp/eth-conf: eth1 has mac 00:90:0B:0A:44:FB
Checking spelling for "00:90:0B:0A:44:FB"...OK
INTERFACE eth1 SUCCESSFULLY CONFIGURED WITH 00:90:0B:0A:44:FB..........OK
/tmp/eth-conf: eth2 has mac 00:90:0B:0A:44:FC
Checking spelling for "00:90:0B:0A:44:FC"...OK
SIOCSIFHWADDR: No such device
INTERFACE eth2 CANNOT BE CONFIGURED WITH 00:90:0B:0A:44:FC........ERROR
/tmp/eth-conf: eth3 has mac 00:90:0B:0A:44:FD
Checking spelling for "00:90:0B:0A:44:FD"...OK
INTERFACE eth3 CANNOT BE CONFIGURED WITH 00:90:0B:0A:44:FD........ERROR
Starting network...
RTNETLINK answers: File exists
eth0: link down
Cannot find device "eth2"
SIOCGIFFLAGS: No such device
Cannot find device "eth3"
net.ipv4.ip_forward = 1
/etc/init.d/S45nat: 6: setmasqnets.sh: not found
Stopping udhcpd (simple DHCP Server)...
killall: udhcpd: no process killed
Starting dnsproxy ...
* setting dns proxy firewall (drop WANs)..
modprobe: module xt_tcpudp not found.
modprobe: failed to load module xt_tcpudp
Using /lib/modules/2.6.13-mppe-mppc/kernel/net/ipv4/netfilter/ip_tables.ko
ip_tables: (C) 2000-2002 Netfilter core team
* checking leases for backward compatibility...
* start server...
/etc/init.d/S49dns: 65: /usr/bin/dnsproxy: not found
Cannot start dnsproxy!!
Starting pptpd: done.
Starting sshd: OK
Mounting jffs2 filesystem
Starting DSA-3100 hotspot system...
* Loading modules
* sch_sfq
insmod /lib/modules/2.6.13-mppe-mppc/kernel/net/sched/sch_sfq.ko
Using /lib/modules/2.6.13-mppe-mppc/kernel/net/sched/sch_sfq.ko
* sch_htb
insmod /lib/modules/2.6.13-mppe-mppc/kernel/net/sched/sch_htb.ko
Using /lib/modules/2.6.13-mppe-mppc/kernel/net/sched/sch_htb.ko
* cls_u32
insmod /lib/modules/2.6.13-mppe-mppc/kernel/net/sched/cls_u32.ko
Using /lib/modules/2.6.13-mppe-mppc/kernel/net/sched/cls_u32.ko
u32 classifier
Actions configured
* ipt_REDIRECT
insmod /lib/modules/2.6.13-mppe-mppc/kernel/net/ipv4/netfilter/ip_conntrack.ko
Using /lib/modules/2.6.13-mppe-mppc/kernel/net/ipv4/netfilter/ip_conntrack.ko
ip_conntrack version 2.1 (512 buckets, 4096 max) - 260 bytes per conntrack
insmod /lib/modules/2.6.13-mppe-mppc/kernel/net/ipv4/netfilter/iptable_nat.ko
Using /lib/modules/2.6.13-mppe-mppc/kernel/net/ipv4/netfilter/iptable_nat.ko
insmod /lib/modules/2.6.13-mppe-mppc/kernel/net/ipv4/netfilter/ipt_REDIRECT.ko
Using /lib/modules/2.6.13-mppe-mppc/kernel/net/ipv4/netfilter/ipt_REDIRECT.ko
* xt_quota
modprobe: module xt_quota not found.
modprobe: failed to load module xt_quota
* xt_state
modprobe: module xt_state not found.
modprobe: failed to load module xt_state
* nf_nat_ftp
modprobe: module nf_nat_ftp not found.
modprobe: failed to load module nf_nat_ftp
* nf_nat_tftp
modprobe: module nf_nat_tftp not found.
modprobe: failed to load module nf_nat_tftp
* nf_nat_pptp
modprobe: module nf_nat_pptp not found.
modprobe: failed to load module nf_nat_pptp
* Prepare database
* Updating allowed nets in hotspot database....
/etc/init.d/S65dsa3100: 76: /bin/parce_interface.sh: not found
* Allowed nets now are: /(eth0) /(eth1)
/etc/init.d/S65dsa3100: 76: sqlite3: not found
* Starting engine
* Starting main server
* Starting moderator
* Prepare control
* Setting printer
* Supress printk
/etc/init.d/S65dsa3100: 76: /usr/local/bin/hstools: not found
killall: getty: no process killed
Bummer, could not run '/sbin/getty': No such file or directory
и тд. до бесконечности
можно ли его реанимировать и как?
СообщениеДобавлено: Пн окт 29, 2007 16:20
Вероятнее всего вы не дождались завершения обновления. Процесс этот долог... Теперь, увы, только восстанавливать в сервисном центре.
СообщениеДобавлено: Пн окт 29, 2007 18:20
Прошивка обновлялась удалённо и физически вмешаться в процесс обновления не мог..
оставил заявку в сервис центр. Спасибо
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 195
