Текущее время: Вт окт 13, 2026 15:37
 Заголовок сообщения: DI-624S: IP Spoofing в логах
СообщениеДобавлено: Чт сен 20, 2007 18:26
Здравствуйте!
В логах постоянно появляются записи такого рода:
Sep 20 19:21:17  DOS [UDP]: Attack Incoming 192.168.0.167->192.168.0.1 [IP Spoofing]
Sep 20 19:21:16  DOS [UDP]: Attack Incoming 192.168.0.167->192.168.0.1 [IP Spoofing]
Sep 20 19:21:15  DOS [UDP]: Attack Incoming 192.168.0.167->192.168.0.1 [IP Spoofing]
Sep 20 19:21:06  DOS [UDP]: Attack Incoming 192.168.0.167->192.168.0.1 [IP Spoofing]
Sep 20 19:21:05  DOS [UDP]: Attack Incoming 192.168.0.167->192.168.0.1 [IP Spoofing]
Sep 20 19:21:05  DOS [TCP]: Attack Incoming 192.168.0.167->10.13.200.3 [IP Spoofing]
Sep 20 19:21:01  DOS [UDP]: Attack Incoming 192.168.0.167->192.168.0.1 [IP Spoofing]
Sep 20 19:20:59  DOS [UDP]: Attack Incoming 192.168.0.167->192.168.0.1 [IP Spoofing]
Sep 20 19:20:59  DOS [TCP]: Attack Incoming 192.168.0.167->10.13.200.3 [IP Spoofing]
Sep 20 19:20:58  DOS [UDP]: Attack Incoming 192.168.0.167->192.168.0.1 [IP Spoofing]
Sep 20 19:20:57  DOS [UDP]: Attack Incoming 192.168.0.167->192.168.0.1 [IP Spoofing]
Sep 20 19:20:56  DOS [TCP]: Attack Incoming 192.168.0.167->10.13.200.3 [IP Spoofing]
Sep 20 19:20:49  DOS [UDP]: Attack Incoming 192.168.0.167->192.168.0.1 [IP Spoofing]
Sep 20 19:20:45  DOS [UDP]: Attack Incoming 192.168.0.167->192.168.0.1 [IP Spoofing]
Sep 20 19:20:43  DOS [UDP]: Attack Incoming 192.168.0.167->192.168.0.1 [IP Spoofing]
Sep 20 19:20:42  DOS [UDP]: Attack Incoming 192.168.0.167->192.168.0.1 [IP Spoofing]
Sep 20 19:19:41  DOS [ICMP]: Attack Incoming 192.168.0.100->10.13.20.163 [IP Spoofing]
Sep 20 19:19:41  DOS [ICMP]: Attack Incoming 192.168.0.100->10.13.115.240 [IP Spoofing]
Sep 20 19:19:41  DOS [ICMP]: Attack Incoming 192.168.0.100->10.13.17.158 [IP Spoofing]
Sep 20 19:19:41  DOS [ICMP]: Attack Incoming 192.168.0.100->10.13.29.155 [IP Spoofing]
Что они означают? Как с этим бороться? Из-за чего это может быть? Как это влияет на производительность роутера?
СообщениеДобавлено: Вт сен 25, 2007 09:39
Народ, помогите, пожалуйста. Сложно ответить что ли?
СообщениеДобавлено: Сб сен 29, 2007 20:21
Присоединяюсь к вопросу. У меня такие-же логи. Первый IP в строке лога - мой, второй меняется и принадлежит локалке провайдера. Что это за атака такая?
СообщениеДобавлено: Пн окт 01, 2007 10:58
Скорее всего Вы клонировали MAC адрес на WAN порту роутера. Из-за этого одинаковый MAC у роутера обнаруживается и в подсети LAN и в подсети WAN. Роутер считает, что имеет место подмена IP/MAC и ругается. В принципе, ничего страшного в этом нет.
СообщениеДобавлено: Пн окт 01, 2007 12:10
Действительно, и на wan и на lan интерфейсе у роутера одинаковый mac-адрес: http://slil.ru/24920216. То есть в настройках wan стоит его сменить?
СообщениеДобавлено: Пн окт 01, 2007 13:59
Да, лучше сменить. Однако, уточните у провайдера, нет ли у него привязки по MAC адресу.
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 51
