Текущее время: Сб окт 03, 2026 17:46
 Заголовок сообщения: Инет на DI-604
СообщениеДобавлено: Чт окт 25, 2007 06:08
Проблема в том что вроде как инет через VPN но как то странно он работает
на яндекс пускает. на все остальное нет, хотя пинги ходят.
Прошивка 3.21RU
Соединение PPPT настроено нормально, в статусе говорит что Connected
Помогите пожалуйста
Вот лог
System Logs
Wed Oct 24 23:08:42 2007 Unrecognized attempt blocked from 221.208.208.98:47414 to 213.242.235.54 UDP:1027
Wed Oct 24 23:09:11 2007 Unrecognized attempt blocked from 213.242.233.72:4673 to 213.242.235.54 TCP:445
Wed Oct 24 23:09:14 2007 Unrecognized attempt blocked from 213.242.233.72:4673 to 213.242.235.54 TCP:445
Wed Oct 24 23:10:14 2007 Unrecognized attempt blocked from 213.242.233.72:2614 to 213.242.235.54 TCP:445
Wed Oct 24 23:10:17 2007 Unrecognized attempt blocked from 213.242.233.72:2614 to 213.242.235.54 TCP:445
Wed Oct 24 23:14:05 2007 Unrecognized attempt blocked from 213.242.235.168:1558 to 213.242.235.54 TCP:135
Wed Oct 24 23:14:08 2007 start to hang-up
Wed Oct 24 23:16:12 2007 DOD:triggered internally
Wed Oct 24 23:16:12 2007 start to dial-up
Wed Oct 24 23:16:12 2007 PPTP:PNS=10.19.0.1
Wed Oct 24 23:16:14 2007 PPP1: TX LCP Request
Wed Oct 24 23:16:14 2007 PPP1: RX LCP Request
Wed Oct 24 23:16:14 2007 PPP1: TX LCP ACK
Wed Oct 24 23:16:14 2007 PPP1: RX LCP NAK/REJECT
Wed Oct 24 23:16:14 2007 PPP1: TX LCP Request2
Wed Oct 24 23:16:14 2007 PPP1: RX LCP ACK
Wed Oct 24 23:16:14 2007 Unrecognized attempt blocked from MSCHAP1: S=23B8C4BC5AD5456E65BCB7C7B24109B43BCA3DA0
Wed Oct 24 23:16:14 2007 PPP1: TX IPCP Reguest
Wed Oct 24 23:16:14 2007 PPP1: RX IPCP Request
Wed Oct 24 23:16:14 2007 PPP1: RX IPCP NACK/REJECT
Wed Oct 24 23:16:14 2007 IPCP1: IP is 213.242.235.54
Wed Oct 24 23:16:14 2007 IPCP1: DNS0 is 195.58.27.158
Wed Oct 24 23:16:14 2007 IPCP1: DNS1 is 195.58.1.145
Wed Oct 24 23:16:14 2007 PPP1: RX IPCP ACK
Wed Oct 24 23:16:54 2007 Unrecognized attempt blocked from 61.163.36.142:6000 to 213.242.235.54 TCP:1433
Wed Oct 24 23:22:23 2007 Unrecognized attempt blocked from 212.176.111.200:1137 to 213.242.235.54 TCP:135
Wed Oct 24 23:23:07 2007 Unrecognized attempt blocked from 213.242.235.168:1815 to 213.242.235.54 TCP:135
Wed Oct 24 23:24:52 2007 Unrecognized attempt blocked from 213.238.67.68:17661 to 213.242.235.54 TCP:135
Wed Oct 24 23:32:12 2007 Unrecognized attempt blocked from 213.242.235.168:2065 to 213.242.235.54 TCP:135
Wed Oct 24 23:34:15 2007 Unrecognized attempt blocked from 221.208.208.91:49386 to 213.242.235.54 UDP:1027
Wed Oct 24 23:34:15 2007 Unrecognized attempt blocked from 221.208.208.91:49386 to 213.242.235.54 UDP:1026
Wed Oct 24 23:39:53 2007 Unrecognized attempt blocked from 221.209.110.20:45710 to 213.242.235.54 UDP:1027
Wed Oct 24 23:39:53 2007 Unrecognized attempt blocked from 221.209.110.20:45710 to 213.242.235.54 UDP:1026
Wed Oct 24 23:41:13 2007 Unrecognized attempt blocked from 213.242.235.168:2320 to 213.242.235.54 TCP:135
Wed Oct 24 23:47:37 2007 Unrecognized attempt blocked from 221.208.208.83:49752 to 213.242.235.54 UDP:1026
Wed Oct 24 23:47:37 2007 Unrecognized attempt blocked from 221.208.208.83:49752 to 213.242.235.54 UDP:1027
Wed Oct 24 23:47:54 2007 Unrecognized attempt blocked from 213.242.217.172:3156 to 213.242.235.54 TCP:445
Wed Oct 24 23:49:16 2007 Unrecognized attempt blocked from 213.242.217.172:3284 to 213.242.235.54 TCP:135
Wed Oct 24 23:50:19 2007 Unrecognized attempt blocked from 213.242.235.168:2575 to 213.242.235.54 TCP:135
СообщениеДобавлено: Чт окт 25, 2007 06:44
понизь MTU.
СообщениеДобавлено: Чт окт 25, 2007 06:50
До скольки?
Сейчас у меня дефолтное.
СообщениеДобавлено: Чт окт 25, 2007 06:54
lexxA писал(а):
До скольки?
Понижай с шагом, например 50 пока не заработает нормально (если заработает)
СообщениеДобавлено: Чт окт 25, 2007 07:02
altctrldel писал(а):
lexxA писал(а):
До скольки?
если не поможет то что тогда?
СообщениеДобавлено: Чт окт 25, 2007 07:09
Тогда можно, например, написать сюда " понизил дл 1000 и не помогло. Что делать дальше?"
СообщениеДобавлено: Чт окт 25, 2007 07:13
Спасибо, вечером попробую.
СообщениеДобавлено: Вс окт 28, 2007 00:10
Тоже самое и у меня. Тока у меня РРРоЕ динамический айпи. Я вообщем уменьшил до 1450 и пошло!!! :D Спасибо за то что такая тема есть!!! Я уже 2 недели мучался.
СообщениеДобавлено: Вс окт 28, 2007 07:23
Таких тем - море. Пора добавить сюда:
viewtopic.php?t=26431
Сейчас этот форум просматривают: Google [Bot] и гости: 185
