Текущее время: Сб окт 03, 2026 19:32
 Заголовок сообщения: Проблема с DI-804HV
СообщениеДобавлено: Пн июл 16, 2007 15:01
ПОДНИМАЮ ДВА ТУННЕЛЯ В ФИЛИАЛЕ С ОФИСОМ . В ОФИСЕ ДВЕ ЛИНИИ ... ОДИН ТУННЕЛЬ РАБОТАЕТ ВТОРОЙ НЕТ ПИШЕТ РОУТЕР В ФИЛИАЛЕ СЛЕДУЮЩЕЕ
Friday August 18, 2006 13:30:31 Send IKE M1(INIT) : 87.117.166.127 --> 83.151.4.94
Friday August 18, 2006 13:30:31 Receive IKE M2(RESP) : 83.151.4.94 --> 87.117.166.127
Friday August 18, 2006 13:30:31 Try to match with ENC:3DES AUTH:PSK HASH:SHA1 Group:Group1
Friday August 18, 2006 13:30:31 Send IKE M3(KEYINIT) : 87.117.166.127 --> 83.151.4.94
Friday August 18, 2006 13:30:31 Receive IKE M4(KEYRESP) : 83.151.4.94 --> 87.117.166.127
Friday August 18, 2006 13:30:32 Send IKE M5(IDINIT) : 87.117.166.127 --> 83.151.4.94
Friday August 18, 2006 13:30:32 Receive IKE M6(IDRESP) : 83.151.4.94 --> 87.117.166.127
Friday August 18, 2006 13:30:32 IKE Phase1 (ISAKMP SA) established : 83.151.4.94 <-> 87.117.166.127
Friday August 18, 2006 13:30:32 SPD : reject mobile user(83.151.4.94) using subnet[192.168.2.0/255.255.255.0] with others(83.151.4.148)
Friday August 18, 2006 13:30:37 Receive IKE Q1(QINIT) : [83.151.4.94]-->[87.117.166.127]
Friday August 18, 2006 13:30:37 SPD : reject mobile user(83.151.4.94) using subnet[192.168.2.0/255.255.255.0] with others(83.151.4.148)
Friday August 18, 2006 13:30:42 Receive IKE Q1(QINIT) : [83.151.4.94]-->[87.117.166.127]
Friday August 18, 2006 13:30:42 SPD : reject mobile user(83.151.4.94) using subnet[192.168.2.0/255.255.255.0] with others(83.151.4.148)
Friday August 18, 2006 13:30:47 Receive IKE Q1(QINIT) : [83.151.4.94]-->[87.117.166.127]
Friday August 18, 2006 13:30:47 SPD : reject mobile user(83.151.4.94) using subnet[192.168.2.0/255.255.255.0] with others(83.151.4.148)
Friday August 18, 2006 13:30:57 Receive IKE Q1(QINIT) : [83.151.4.94]-->[87.117.166.127]
Friday August 18, 2006 13:30:57 SPD : reject mobile user(83.151.4.94) using subnet[192.168.2.0/255.255.255.0] with others(83.151.4.148)
Friday August 18, 2006 13:31:07 Receive IKE Q1(QINIT) : [83.151.4.94]-->[87.117.166.127]
Friday August 18, 2006 13:31:07 SPD : reject mobile user(83.151.4.94) using subnet[192.168.2.0/255.255.255.0] with others(83.151.4.148)
СообщениеДобавлено: Пн июл 16, 2007 15:20
и ВООБЩЕ МОЖНО КИДАТЬ ДВА ТУННЕЛЯ НА ОДИНАКОВЫЕ ПОДСЕТИ
office 192.168.2.0/255.255.255.0/83.151.4.148
192.168.4.0/255.255.255.0 ESP tunnel IKE established 1925
office1 192.168.2.0/255.255.255.0/ 83.151.4.94
192.168.4.0/255.255.255.0 Idle 0
СообщениеДобавлено: Пн июл 16, 2007 15:30
Нет, подсети в туннелях должны быть разными.
СообщениеДобавлено: Пн июл 16, 2007 15:34
Как же выйти из данной ситуации... хотелось бы повысить стабильность работы туннеля между офисом и филиалом...
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 206
