Текущее время: Сб ноя 07, 2026 23:22
 Заголовок сообщения: DI-824HV - проблемы с подключением
СообщениеДобавлено: Пн янв 15, 2007 03:20
сразу лог:
WAN Type: PPTP (V1.43)
Display time: Thursday October 26, 2006 15:12:35
Page1
Thursday October 26, 2006 14:33:54 PPTP:error=-112
Thursday October 26, 2006 14:34:02 DOD:TCP trigger from 192.168.0.100:1277 to <какойто внешний адрес>:80
Thursday October 26, 2006 14:34:02 PPTP start to dial-up
Thursday October 26, 2006 14:34:02 PPTP server=10.59.3.19 GATEWAY
Thursday October 26, 2006 14:34:36 MSCHAP1: OK
Thursday October 26, 2006 14:34:36 IPCP1: IP is <мой публичный IP адрес>
Thursday October 26, 2006 14:36:06 Restarted by 192.168.0.100
Thursday October 26, 2006 14:36:26 Restarted by 192.168.0.100
Thursday October 26, 2006 14:36:29 DOD:TCP trigger from 192.168.0.100:1368 to <какойто внешний адрес>:80
Thursday October 26, 2006 14:36:29 PPTP start to dial-up
Thursday October 26, 2006 14:36:29 PPTP server=10.59.3.19 GATEWAY
Thursday October 26, 2006 14:36:33 PPTP:error=-112
Thursday October 26, 2006 14:36:36 DOD:TCP trigger from 10.59.3.19:1723 to 10.41.81.100:65535
Thursday October 26, 2006 14:36:36 PPTP start to dial-up
Thursday October 26, 2006 14:36:36 PPTP server=10.59.3.19 GATEWAY
Thursday October 26, 2006 14:37:41 PPTP:error=-112
Thursday October 26, 2006 14:38:44 Restarted by 192.168.0.100
Thursday October 26, 2006 14:39:55 Restarted by 192.168.0.100
Thursday October 26, 2006 14:40:10 DOD:triggered internally
Thursday October 26, 2006 14:40:10 PPTP start to dial-up
Page2
Thursday October 26, 2006 14:40:10 PPTP server=10.59.3.19 GATEWAY
Thursday October 26, 2006 14:40:10 MSCHAP1: OK
Thursday October 26, 2006 14:40:10 IPCP1: DNS1 is unknown
Thursday October 26, 2006 14:40:10 IPCP1: IP is <мой публичный IP адрес>
на дату и время не смотрите, с ней отдельная проблема, да и вообще раутер часто перезагружается..
Настройки через подключение на раутере такие:
- PPTP/StaticIP
Настройки через (ручное) подключение на WinXP (SP2) соединие такие:
- Security->Security Options->Typical (recommended setting)
- Require secured password (включено)
- Require data encryption (выключено)
Если на раутере стоит Home->WAN:
WAN Settings:
- Static IP Address
то подключение через WinXP соединение (вручную фактически) происходит мгновенно, и интернет работает нормально (правда при этом не видны локальные ресурсы провайдера)
Собственно проблемы появляются, когда переходишь на автоматическое подключение через раутер (PPTP/StaticIP)
Во-первых, раутер подключается не всегда и не сразу, иногда проходит несколько минут перед подключением. Напоминаю, что ручное подключение происходит менее чем за секунду (проверялось несколько раз в течении (!) полугода).
Во-вторых, когда он не может подключится, выскакивает error: -112, что это понятия не имею.
В-третьих, когда он якобы пишет что подключается:
Выясняется что он, интернет, всё-равно не работает, а раутер находится в каком-то "подвешанном" состоянии (и вроде написал что подключился, и вроде не подключился, т.к. инет не работает):
IP Address: 87.249.58.253
Connection Time: -
Subnet Mask: 255.255.255.255
В поле <Connection Time> почемуто прочерк.
При этом если включить опять Static режим:
Home->WAN->WAN Settings->Static IP Address
а потом сразу обратно PPTP/StaticIP:
Thursday October 26, 2006 14:36:05 Restarted by 192.168.0.100
То это иногда таки помогает, а иногда всёже нет:
Приходится постоянно делать одно и тоже, перегружать раутер в Static режим, устанавливать соединение через WinXP соединение, выключать WinXP соединение и перегружать раутер обратно в PPTP/StaticIP (на вкладке Home->WAN->WAN Settings). Только тогда раутер выходит из "анабиоза" и чтото делает:
Заметил, что когда раутер всё-таки устанавливает соединение (это когда интернет начинает работать), между строчками:
и
появляется:
Но факт остаётся фактом: соединение устанавливается не сразу, при этом при установке соединения вылетают -112 ошибки, и после либо раутер устанавливает "неправильное" соединение, либо соединяется. И всё это часто происходит за относительно не короткий промежуток времени.
Что порекомендуете делать?
СообщениеДобавлено: Пн янв 15, 2007 12:03
Приведите настройки со страницы Home->WAN
СообщениеДобавлено: Ср янв 17, 2007 12:27
[WAN Settings]
Others->PPTP
[PPTP]
- StaticIP
My IP Address: 10.41.81.100
My Subnet Mask: 255.255.255.0
My Gateway: 10.41.81.5
Server IP/Name: 10.59.3.19
Connection ID: GATEWAY
MTU: 1400
Connect mode select: Connect-on-demand
Change the TTL value: Enabled
IGMP: Enabled
СообщениеДобавлено: Ср янв 17, 2007 12:42
Перепрошейте вот на эту прошивку:
ftp://ftp.dlink.ru/pub/Router/DI-804HV/ ... 1207155433).zip
После перепрошивки обязательно сбросьте в заводские установки.
СообщениеДобавлено: Чт янв 18, 2007 02:55
ага, вкусненькое появилось ^^
будем тестить.. как чтото разрешится, тут сообщу о положительных/отрицательных результатах.
СообщениеДобавлено: Чт янв 18, 2007 03:59
Похоже не намного лучше, но лучше.
Также иногда не коннектит сразу, чего то ждет, и потом устанавливает "неправильное" соединение, но по ощущениям - реже.
СообщениеДобавлено: Чт янв 18, 2007 10:10
Не могли бы Вы узнать у провайдера какой у него pptp сервер и, если возможно, файл конфигурации сервера.
СообщениеДобавлено: Чт янв 18, 2007 17:10
Думаю придётся достаточно долго собирать такую информацию, т.к. иногда даже тех поддержка не знает технических деталей или знает но не досканально все. :~(
СообщениеДобавлено: Вт апр 03, 2007 19:43
Я сам провайдер. Предоставляю инет через впн авторизатор. Pptp-сервер сделан на windows 2003 server enterprise (естественно R&RAS). Залил на DI-804HV прошивку упомянутую выше, настроил должным образом (жаль настроек не так много как у винды), а коннекта нет вообще как и не было. Наверно те же грабли.
Я сам люблю снифать сетевой трафик и разбираться в протоколах. Так вот с помощью Ethereal я проснифал общение роутера с сервером и увидел, что роутер отвечает серверу пакетом PPP LCP Protocol Reject. Покопавшись во внутренностях пакета нашел следующее:
Rejected protocol: Compression Control Protocol (0x80fd)
Журнал системных событий при этом показывает сообщение:
The following error occurred in the Point to Point Protocol module on port: VPN3-99, UserName: SERVER\user. The remote computer does not support the required data encryption type.
Методы проверки подлинности на сервере используются MS-CHAP и MS-CHAPv2. Насколько я понял роутер поддерживает MSCHAP1 точно. Так в чем же проблема может быть?
СообщениеДобавлено: Ср апр 04, 2007 12:07
проблема в том, что шифрование роутером не поддерживается.
СообщениеДобавлено: Ср апр 04, 2007 15:12
А в каких роутерах поддерживается? И будет ли поддерживаться в DI-804HV?
СообщениеДобавлено: Ср апр 04, 2007 15:25
CCP не поддерживается и добавление его поддержки не планируется.
Пришлите на мой ящик дамп, что Вы поймали, возможно проблема в чем-то другом.
СообщениеДобавлено: Ср апр 04, 2007 17:22
Да я уже разрешил подключения без шифрования. Вроде работает. Если будут проблемы тогда надамплю вам сколько пожелаете ))). И открою новую тему, а то эта даже называется так, что никто не догадается, что тут говорится еще и о DI-804HV.
Спасибо за ответ. Ну жалко конечно что CCP не собираетесь поддерживать (((
