Текущее время: Пн ноя 02, 2026 08:31
СообщениеДобавлено: Сб апр 01, 2006 12:50
в общем у меня тут проблема...:
Здраствуйте, не могли бы вы подсказать ... если конечно компитентны в этом вопросе: FreeBSD 5.4 не подключается к интернету через PPPoE...
rc.conf:
ppp_enable="YES"
ppp_mode="ddial"
ppp_nat="YES"
ppp_profile="name_of_service_provider"
ifconfig_de0="inet 213.154.220.46 netmask 255.255.255.252"
#defaultrouter="192.168.0.99"
gateway_enable="YES"
hostname="myserver"
ifconfig_rl0="inet 192.168.0.98 netmask 255.255.255.0"
network_interfaces="lo0 rl0 de0"
defaultrouter="213.124.220.46"
inetd_enable="YES"
named_enable="YES"
named_flags="-u bind -g bind"
linux_enable="YES"
usbd_enable="YES"
nfs_server_enable="NO"
nfs_client_enable="NO"
firewall_enable="YES"
firewall_type="Open"
ppp.conf:
default:
set log Phase tun command # you can add more detailed logging if you wish
set ifaddr 10.0.0.1/0 10.0.0.2/0
name_of_service_provider:
set device PPPoE: de0 # replace xl1 with your Ethernet device
set authname unlimited
set authkey *****
set dial
set login
add default HISADDR
pppoe.conf:
default:
set device PPPoE:de0 # replace xl1 with your Ethernet device
set authkey *******
set dial
set login
add default HISADDR
/var/log/ppp.log:
Apr 1 10:53:35 alfaclub ppp[198]: tun0: Warning: : Cannot send a netgraph mess>
Apr 1 10:53:35 alfaclub ppp[198]: tun0: Warning: deflink: Device (PPPoE:) must>
Apr 1 10:53:35 alfaclub ppp[198]: tun0: Warning: deflink: Device (de0) must be>
Apr 1 10:53:35 alfaclub ppp[198]: tun0: Phase: deflink: Enter pause (30) for r>
Apr 1 10:54:05 alfaclub ppp[198]: tun0: Warning: : Cannot send a netgraph mess>
Apr 1 10:54:05 alfaclub ppp[198]: tun0: Warning: deflink: Device (PPPoE:) must>
Apr 1 10:54:05 alfaclub ppp[198]: tun0: Warning: deflink: Device (de0) must be>
Apr 1 10:54:05 alfaclub ppp[198]: tun0: Phase: deflink: Enter pause (30) for r>
Apr 1 10:54:35 alfaclub ppp[198]: tun0: Warning: : Cannot send a netgraph mess>
Apr 1 10:54:35 alfaclub ppp[198]: tun0: Warning: deflink: Device (PPPoE:) must>
Apr 1 10:54:35 alfaclub ppp[198]: tun0: Warning: deflink: Device (de0) must be>
Apr 1 10:54:35 alfaclub ppp[198]: tun0: Phase: deflink: Enter pause (30) for r>
Apr 1 10:55:05 alfaclub ppp[198]: tun0: Warning: : Cannot send a netgraph mess>
Apr 1 10:55:05 alfaclub ppp[198]: tun0: Warning: deflink: Device (PPPoE:) must>
Apr 1 10:55:05 alfaclub ppp[198]: tun0: Warning: deflink: Device (de0) must be>
Apr 1 10:55:05 alfaclub ppp[198]: tun0: Phase: deflink: Enter pause (30) for r>
Device (PPPoE:) must begin with a '/', a '!' or contain at l>
Warning: deflink: Device (de0) must begin with a '/', a '!' or contain at leas>
Phase: deflink: Enter pause (30) for redialing.
Warning: : Cannot send a netgraph message: Invalid argument
Warning: deflink: Device (PPPoE:) must begin with a '/', a '!' or contain at l>
Warning: deflink: Device (PPPoE:) must begin with a '/', a '!' or contain at least one ':'
Warning: deflink: Device (de0) must begin with a '/', a '!' or contain at leas one ':
немогу понять в чем дело :oops:
СообщениеДобавлено: Пн апр 03, 2006 13:45
В хандбук заглядывали?
