Текущее время: Пт авг 21, 2026 15:19
 Заголовок сообщения: increase wifi speed on DIR-300NRU rev.B5
СообщениеДобавлено: Ср окт 24, 2012 21:13
hi
I've got a DIR-300NRU rev.B5 router running 1.3.3 firmware version. My problem is that the WiFi connection speed is 65 Mbps whereas the box says it can do 150. What settings should I use to achieve the maximum speed?
Setting it to N-only mode does not make any difference. I use WPA2-PSK encryption. Bandwidth is set to 20/40 Mhz-.
If additional information is needed, I will provide it.
 Заголовок сообщения: Re: increase wifi speed on DIR-300NRU rev.B5
СообщениеДобавлено: Ср окт 24, 2012 21:28
Каким устройством подключаетесь? Какой там адаптер?
СообщениеДобавлено: Ср окт 24, 2012 21:57
I'm connecting to the wifi network through a samsung galaxy s2. it says it is 802.11 a/b/g/n compatible.
СообщениеДобавлено: Чт окт 25, 2012 11:46
А другими устройствами не проверяли?
Полезные настройки
СообщениеДобавлено: Чт окт 25, 2012 16:32
I dont really know what other settings I should try. I've tried googling for some answers but all I found was setting bandwidth to 20/40Mhz which is already the default setting and making sure WPA2 encryption is used. I did not change any other settings from default (as far as I remember).
Сейчас этот форум просматривают: Bing [Bot], Google [Bot] и гости: 33
