Текущее время: Чт сен 24, 2026 10:11
СообщениеДобавлено: Ср июн 20, 2012 18:15
Всем доброго времени суток!
Суть проблемы такова: у друга поднят VPN на WS2008 с доступом в интернет, хотелось бы подключиться к нему используя официальную 1.3.3 прошивку. Хотелось бы, да не выходит.. На версии keenetic проблем не возникает.
Лог 1.3.3:
Jan  1 00:02:58 pptp[1219]: Plugin /usr/lib/pppd/pptp.so loaded.
Jan  1 00:02:58 pptp[1219]: PPTP plugin version 0.8.3 compiled against pppd 2.4.4
Jan  1 00:02:58 pptp[1220]: pppd 2.4.4 started by admin, uid 0
Jan  1 00:02:58 pptp[1220]: Check server 10.6.15.178
Jan  1 00:02:58 pptp[1220]: route_add: have route to host on this dev eth2.5
Jan  1 00:02:58 pptp[1220]: route_add: host in same net
Jan  1 00:02:58 pptp[1221]: IP: 10.6.15.178
Jan  1 00:02:58 pptp[1221]: control connection
Jan  1 00:02:58 pptp[1221]: unix_sock
Jan  1 00:02:58 pptp[1222]: Sent control packet type is 1 'Start-Control-Connection-Request'
Jan  1 00:02:58 pptp[1222]: Received Start Control Connection Reply
Jan  1 00:02:58 pptp[1222]: Client connection established.
Jan  1 00:02:59 pptp[1222]: Sent control packet type is 7 'Outgoing-Call-Request'
Jan  1 00:02:59 pptp[1222]: Received Outgoing Call Reply.
Jan  1 00:02:59 pptp[1222]: Outgoing call established (call ID 1, peer's call ID 6461).
Jan  1 00:02:59 pptp[1220]: Using interface ppp0
Jan  1 00:02:59 pptp[1220]: Connect: ppp0 <--> pptp (10.6.15.178)
Jan  1 00:02:59 pptp[1220]: Connect time 3.0 minutes.
Jan  1 00:02:59 pptp[1220]: Sent 0 bytes, received 0 bytes.
Jan  1 00:03:01 pptp[1220]: Connect time 3.1 minutes.
Jan  1 00:03:01 pptp[1220]: Sent 0 bytes, received 0 bytes.
Jan  1 00:03:01 pptp[1222]: PPTP_SET_LINK_INFO received from peer_callid 1
Jan  1 00:03:01 pptp[1222]:   send_accm is 00000000, recv_accm is FFFFFFFF
Jan  1 00:03:01 pptp[1222]: Non-zero Async Control Character Maps are not supported!
Jan  1 00:03:01 pptp[1220]: EAP: unknown authentication type 26; Naking
Jan  1 00:03:01 pptp[1222]:   send_accm is FFFFFFFF, recv_accm is FFFFFFFF
Jan  1 00:03:01 pptp[1220]: EAP: peer reports authentication failure
Jan  1 00:03:01 pptp[1220]: lcp_close: unit:0, reason: "Failed to authenticate ourselves to peer" (status: 19, state: 9, was_ip_down: 0)
Jan  1 00:03:01 pptp[1220]: Connection terminated.
Jan  1 00:03:01 pptp[1222]: Received Call Clear Request.
Jan  1 00:03:02 pptp[1222]: Closing connection (unhandled)
Jan  1 00:03:02 pptp[1222]: Sent control packet type is 12 'Call-Clear-Request'
Jan  1 00:03:02 pptp[1222]: Closing connection (call state)
Jan  1 00:03:02 pptp[1220]: lcp_close: unit:0, reason: "" (status: 19, state: 0, was_ip_down: 0)
Jan  1 00:03:02 pptp[1220]: lcp_close: send ip_down to resident(status: 19)
Jan  1 00:03:02 pptp[1220]: Couldn't get PPP statistics: No such device
Jan  1 00:03:02 pptp[1220]: Terminating on signal 15
Jan  1 00:03:02 pptp[1220]: Exit.(5)
Лог keenetic:
Jun 20 04:08:19 pptp[2862]: Plugin pptp.so loaded.
Jun 20 04:08:19 pptp[2862]: PPTP plugin version 0.8.3 compiled against pppd 2.4.4
Jun 20 04:08:19 pptp[2863]: pppd 2.4.4 started by root, uid 0
Jun 20 04:08:19 pptp[2864]: IP: 10.6.15.178
Jun 20 04:08:19 pptp[2864]: control connection
Jun 20 04:08:19 pptp[2864]: unix_sock
Jun 20 04:08:19 pptp[2866]: Sent control packet type is 1 'Start-Control-Connection-Request'
Jun 20 04:08:19 pptp[2866]: Received Start Control Connection Reply
Jun 20 04:08:19 pptp[2866]: Client connection established.
Jun 20 04:08:20 pptp[2866]: Sent control packet type is 7 'Outgoing-Call-Request'
Jun 20 04:08:20 pptp[2866]: Received Outgoing Call Reply.
Jun 20 04:08:20 pptp[2866]: Outgoing call established (call ID 1, peer's call ID 56120).
Jun 20 04:08:20 pptp[2863]: Using interface ppp0
Jun 20 04:08:20 pptp[2863]: Connect: ppp0 <--> pptp (10.6.15.178)
Jun 20 04:08:22 pptp[2866]: PPTP_SET_LINK_INFO received from peer_callid 1
Jun 20 04:08:22 pptp[2866]:   send_accm is 00000000, recv_accm is FFFFFFFF
Jun 20 04:08:22 pptp[2866]: Non-zero Async Control Character Maps are not supported!
Jun 20 04:08:22 pptp[2863]: CHAP authentication succeeded
Jun 20 04:08:25 pptp[2863]: replacing old default route to eth2.2 [10.6.15.1]
Jun 20 04:08:25 pptp[2863]: local  IP address 7.7.7.9
Jun 20 04:08:25 pptp[2863]: remote IP address 7.7.7.1
Jun 20 04:08:25 pptp[2863]: primary   DNS address 91.190.68.2
Jun 20 04:08:25 pptp[2863]: secondary DNS address 91.203.177.4
Заранее благодарю за любую информацию)
Сейчас этот форум просматривают: Google [Bot] и гости: 78
