Текущее время: Сб окт 03, 2026 13:46
СообщениеДобавлено: Пт июн 01, 2012 09:06
DFL-800:/> Reason: Exception 'DataAbort' occurred at address 0x78a7950
Generation date/time: 2012-06-01 08:56:12
List of loaded PE-modules:
fwloader(2.00.22): BA:0x00100000, EP:0x00101028, SS:0x0, IS:0x1a2000
fwcore(2.27.03.25-14780): BA:0x07290038, EP:0x00088a78, SS:0x200000, IS:0xb3b000
Register dump:
r0 : 0x06d916a8, r1 : 0x00fd032b, r2 : 0x0000002c, r3 : 0x0000002e, r4 : 0x06d91
494,
r5 : 0x06bf0290, r6 : 0x7329f43d, r7 : 0x00005018, r8 : 0x00fd0116, r9 : 0x06bf0
290,
r10: 0x00000270, r11: 0x0728eab0, r12: 0x06d91494, sp : 0x0728ea70, lr : 0x077bc
61c
Stack dump:
47af47d1 822088cb b0193bf8 0441451f 45ac5b5f 80de9d1b c771e6bd 0faac0bf
4eba85cd 8dd92133 cd0dfb45 0cc33d5f 3efa7064 89cb2373 c8dce469 167fc9bb
556f5a0d 9324dea3 d43523e5 15456927 c41a28ff 9765f1e3 d8763aa5 6aaf8a12
c8d945e7 9d180a23 dcb74f85 1aef780f 59ff3295 98943257 e783feb9 2208f827
6464f1e1 a352c9af e5397805 26b4bc45 675a02f9 a86a475d e97a8d0c 2a762c97
18b2e3ac 3ee4da45 ed475ccd 2874e5c7 6f212d9b b0ec7393 f1fcb71c 34241733
7335aa9d b251bc7f f141e749 374e0561 785e06b1 b96e9895 fa7ee12c 3b73d8b7
7a206921 bdafb0f3 fe4308ed 3fd03b73 87c86b1d c6d82e8b 047d3711 436d62a7
c50df304 c631dbc6 476e4645 48ae9b5f 8962aac9 c9e87f73 0b833549 4c937a8f
8d5f4109 7d4ac252 08eca191 57fc643f 96d63c2d d5892143 1623c433 55e95a47
9625e9e1 d4aca05b 1f6e9869 5e7e526f 9d49130d dc45a2f7 1c87894d 5d97ce94
53d8fbba eaf9e72c b81f1494 51edda80 a2e928c0 e1dff555 26933c05 6619f8bf
a4b0b179 e83a8343 29b6365d d9a5ca86 ac43bd6d eb53745b 2ab8c3ed 69b3c877
7f716b0d a8d511da c859433e 4040fec7 7a870c78 a35369f4 66952a49 f59459af
03422c36 29dd02a3 d71943e9 98dea603 5fa6661a 19f6fb8e 9c85a878 93e72d95
f06816c6 3fa931a9 873e1526 ccc12f17 a08172eb 9b04f650 721be76b fc6c8fab
c9cfe6bf 0abe2b79 930c0a1a ac0e2d74 cd73d343 04db408b 4c0e0ab5 90a4caf8
d1b511a6 12c5058b 53d59ad5 96c37b79 6608e1a0 170668d3 5f3e430d 9e0e19a7
daca3b77 1bba7ea1 5c57c4e5 9d680a27 de784f69 1c121b6b 6302562d a2339057
e5c29c5d 2510bf38 64d9eef5 a2c2db07 e1d29595 2f47667b 6e457499 ad03a41f
eb3b8ea2 2b633d87 6ad56b25 ae6c5cc7 ef7ca389 308ce8c1 77443a99 b4746787
f564ac5b 3214e90f 730757cb b0379d7a f127d8b6 39f213d9 7ae258f3 bb2f9ce4
fc3fe8fe 3d5027e3 7e606d25 bf70b267 0659e24b 47482913 847897d7 c568d15a
021b1a86 430b4774 86e29734 c7f2dc76 0e2bcf01 4d3b8b8b 8c7d1da1 cb6d54e7
0d4436c1 4d68944b 8f64c145 d0750687 d12d4bc5 923d912e 93a5d64e d7f75947
165cefa9 56d6a612 80e5ea54 2e2fbdad 1a0775cd 5b17bb5b f8fc5820 dd384597
1e488ae1 5f58d023 d2d5cb8f d74f6c91 22899fe9 639de52b a4aa2a69 e5ba6faf
26cab4f1 600bd4ef a8eb3d0b e9068459 2b0bc9ed 6ce0f1e3 ad2c560d ee3c99bb
28643165 7775ca43 b64315a1 f55396af 6fd1a855 749e3943 b5ae7e8d f6bec3cd
37cf0911 78df4e52 b9ef9395 faffd8d7 3c112699 7d206359 be30a89d ff40719f
40513321 81617871 c2612e35 038202e7 64924836 85a28d6a c1622f05 073e1701
482fa3e9 89e3a273 cddb08c9 0b2cc29f 4a3a0d45 8917a5df cf34fcbd 10450fdf
Faulting instruction: 0x078a7950 (opcode: 0xe4c03001)
Instructions surrounding the faulting one
0x0a000004
0xe4d13001
0xe2422001
0xe3720001
-> 0xe4c03001
0x1afffffa
0xe1a000р+IDE ctlr 0, device 1: Can't identify device!
СообщениеДобавлено: Пт июн 01, 2012 09:08
не пойму еще что значит это сообщение при загрузке
Ethernet eth0: MAC address 22:11:44:33:66:55
IP: 10.9.9.1/255.255.255.0, Gateway: 10.9.9.1
Default server: 192.168.0.91
как будто какое то устройство пытается подключить
СообщениеДобавлено: Пт июн 01, 2012 09:22
На это можно не обращать внимания - нет тут 2-го IDE-устройства, флеш-карта с софтом одна ведь подключена.
А вот то, что дамп вываливает - плохо... Тут или с питанием проблемы или ОЗУ "подбилось" или даже на CF-карточке информация "разваливается". Файл LICENSE.LIC спасайте! Остальное относительно просто можно восстановить.
СообщениеДобавлено: Пт июн 01, 2012 09:32
а что такое licence.lic что там ценного?
СообщениеДобавлено: Пт июн 01, 2012 09:53
разобрал.. внутри два кондера вздутых по питанию.. надо перепаять..
СообщениеДобавлено: Пт июн 01, 2012 10:32
Если взялись менять - то все 1000мкФ х 6.3В меняйте, независимо от того, вздулись они или нет. Аккуратно блок питания вскройте и там ещё посмотрите, возможно что тоже "грибы взошли" :D
PS: licence.lic - это файл с ключём-лицензией на софт. Если его протерять, то DFL превращается в кусок зелёной фанеры!
СообщениеДобавлено: Пт июн 01, 2012 13:13
а как его можно скопировать и обратно залить?
СообщениеДобавлено: Пт июн 01, 2012 13:22
при помощи карт ридера
вытащить из устройства флешку и в карт ридер ( не советую пользоватся проводником винды )
Сейчас этот форум просматривают: Google [Bot] и гости: 192
