Текущее время: Пт окт 02, 2026 02:20
 Заголовок сообщения: Проблема с VPN DIR 655
СообщениеДобавлено: Пт ноя 19, 2010 13:22
Помогите пожалуйста решить проблему, при настройки VPN на роутере 655 каждые 30 секунды соединение обрывается.
В логах пишет вот такие данные.
[INFO] Fri Nov 19 12:12:33 2010 Blocked incoming TCP packet from 213.184.232.57:1723 to 192.168.1.101:16426 as PSH:ACK received but there is no active connection
[INFO] Fri Nov 19 12:12:27 2010 PPP network down
[INFO] Fri Nov 19 12:12:27 2010 PPTP tunnel ID 0xF3B7 has been closed
[INFO] Fri Nov 19 12:12:25 2010 PPTP ALG rejected packet from 213.184.232.57:1723 to 192.168.1.101:28012
[INFO] Fri Nov 19 12:12:16 2010 Dropped packet from 192.168.1.102 to 239.255.255.250 (IP protocol 17) as unable to create new session
[INFO] Fri Nov 19 12:12:10 2010 Above message repeated 5 times
[INFO] Fri Nov 19 12:12:10 2010 PPTP ALG rejected packet from 213.184.232.57:1723 to 192.168.1.101:28012
[INFO] Fri Nov 19 12:12:10 2010 Dropped packet from 192.168.1.102 to 239.255.255.250 (IP protocol 17) as unable to create new session
[INFO] Fri Nov 19 12:12:10 2010 Above message repeated 7 times
[INFO] Fri Nov 19 12:12:10 2010 Dropped packet from 192.168.1.102 to 239.192.152.143 (IP protocol 17) as unable to create new session
[INFO] Fri Nov 19 12:12:10 2010 Above message repeated 193 times
[INFO] Fri Nov 19 12:12:09 2010 Blocked incoming GRE packet from 213.184.232.57 to 192.168.1.101
[INFO] Fri Nov 19 12:12:09 2010 Above message repeated 1 times
[INFO] Fri Nov 19 12:12:09 2010 Dropped packet from 192.168.1.102 to 239.192.152.143 (IP protocol 17) as unable to create new session
[INFO] Fri Nov 19 12:12:09 2010 Above message repeated 117 times
[INFO] Fri Nov 19 12:12:08 2010 Dropped packet from 192.168.1.102 to 239.255.255.250 (IP protocol 17) as unable to create new session
[INFO] Fri Nov 19 12:12:08 2010 Above message repeated 1 times
[INFO] Fri Nov 19 12:12:08 2010 Blocked incoming GRE packet from 213.184.232.57 to 192.168.1.101
[INFO] Fri Nov 19 12:12:07 2010 Dropped packet from 192.168.1.102 to 239.255.255.250 (IP protocol 17) as unable to create new session
[INFO] Fri Nov 19 12:12:06 2010 Above message repeated 11 times
1.Прошивка 134 бета 8
2. Qos отключен.
3. Исполюется PPTP Rus
4. ALG все включены
5. SPI включен
Кроме того если настраивать тоже подключение на компьютере пропуская его через роутер VPN так же обрывается спустя 2 минуты.
 Заголовок сообщения: Re: Проблема с VPN DIR 655
СообщениеДобавлено: Сб ноя 20, 2010 12:09
1. Посмотри скорость WAN порта на роутере, там обычно AUTO стоит (у меня он всегда по авто гигабит ставил). Снизь до 100Mb, и пробуй!
2. Если пункт 1 не помог, посмотри значение MTU в PPTP, (о умолчанию на PPTP размер кадра 1400), у меня стоит 1392 (подбирается опытным путем), при 1400 иногда проскакивали битые пакеты.
DWL2000AP+, Dl-604, DIR-320, DIR-655, ....
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 177
