Текущее время: Ср сен 30, 2026 20:41
СообщениеДобавлено: Пт ноя 12, 2010 22:01
# cat /etc/racoon/racoon.conf
path pre_shared_key "/etc/racoon/psk.txt";
path certificate "/etc/racoon/certs";
log debug;
listen {
    isakmp 222.48.47.234 [500];
# Connection aclass
remote 111.48.47.233 {
        nat_traversal on;
        proposal {
                encryption_algorithm 3des;
                hash_algorithm md5;
                authentication_method pre_shared_key;
                dh_group modp1024;
        passive off;
       my_identifier address 222.48.47.234;
       verify_identifier off;
        lifetime time 30 min;
        peers_identifier address 111.48.47.233;
        exchange_mode main;
        generate_policy on;
sainfo address 172.16.0.0/24[any] any address 192.168.0.0/24[any] any {
        pfs_group modp1024;
        authentication_algorithm hmac_md5;
        compression_algorithm deflate;
ругается на несовпадение шифрования наверное
DEBUG: Compared: DB:Peer
DEBUG: (lifetime = 1800:28800)
DEBUG: (lifebyte = 0:0)
DEBUG: enctype = 3DES-CBC:Blowfish-CBC
DEBUG: (encklen = 0:128)
DEBUG: hashtype = MD5:SHA
DEBUG: authmethod = pre-shared key:pre-shared key
DEBUG: dh_group = 1024-bit MODP group:1024-bit MODP group
DEBUG: type=Encryption Algorithm, flag=0x8000, lorv=AES-CBC
DEBUG: type=Key Length, flag=0x8000, lorv=128
DEBUG: type=Hash Algorithm, flag=0x8000, lorv=MD5
DEBUG: type=Authentication Method, flag=0x8000, lorv=pre-shared key
DEBUG: type=Group Description, flag=0x8000, lorv=1024-bit MODP group
DEBUG: type=Life Type, flag=0x8000, lorv=seconds
DEBUG: type=Life Duration, flag=0x8000, lorv=28800
ERROR: rejected enctype: DB(prop#1:trns#1):Peer(prop#0:trns#0) = 3DES-CBC:AES-CBC
ERROR: rejected enctype: DB(prop#1:trns#1):Peer(prop#0:trns#7) = 3DES-CBC:Blowfish-CBC
ERROR: rejected hashtype: DB(prop#1:trns#1):Peer(prop#0:trns#7) = MD5:SHA
ERROR: no suitable proposal found.
ERROR: failed to get valid proposal.
ERROR: failed to pre-process packet.
ERROR: phase1 negotiation failed.
борьба по материалам faq
http://www.dlink.ru/ru/faq/92/512.html
http://www.dlink.ru/ru/faq/92/520.html
СообщениеДобавлено: Сб ноя 13, 2010 15:41
Какие настройки выполенны на DFL?
СообщениеДобавлено: Сб ноя 13, 2010 15:51
Как то так под дефолтные настройки DFL
path include "/etc/racoon";
# search this file for pre_shared_key with various ID key.
# racoon will look for certificate file in the directory,
# if the certificate/certificate request payload is received.
#path certificate "/etc/cert";
# "padding" defines some parameter of padding.  You should not touch these.
padding
        maximum_length 20;      # maximum padding length.
        randomize off;          # enable randomize length.
        strict_check off;       # enable strict check.
        exclusive_tail off;     # extract last one octet.
       isakmp server_ip [500];
       isakmp_natt 1server_ip [4500];
remote DFL_IP
       exchange_mode main;
       doi ipsec_doi;
       situation identity_only;
       my_identifier address server_ip;
       peers_identifier address dfl_ip;
       lifetime time 28800 sec;
       initial_contact on;
       nat_traversal off;
       proposal_check obey;
proposal {
       hash_algorithm md5;
       dh_group 2;
sainfo subnet 192.168.40.0/24 any subnet 192.168.0.0/24 any
       pfs_group 2;
       lifetime time 3600 sec;
Не забывает про ядерные политики:
/etc/ipsec-tools.conf
spdadd 192.168.0.0/24 192.168.40.0/24 any -P out ipsec esp/tunnel/91.205.195.26-91.205.192.26/require;
spdadd 192.168.40.0/24 192.168.0.0/24 any -P in ipsec esp/tunnel/91.205.192.26-91.205.195.26/require;
Подгружаем их в ядро.
sudo invoke-rc.d setkey restart
СообщениеДобавлено: Сб ноя 13, 2010 16:38
Какая прошивка используется на DFL?
Сейчас этот форум просматривают: Bing [Bot], Google [Bot] и гости: 140
