Текущее время: Чт сен 17, 2026 06:05
 Заголовок сообщения: Безопасность Dir-320
СообщениеДобавлено: Вс окт 03, 2010 12:40
Добрый день подскажите мне в системном журнале выдает постоянно
ATTACK Detected: 001[Xmas] attack from WAN (ip:95.133.58.173) detected. Packet dropped.
Jan 1 21:15:54 ATTACK Detected: 001[Xmas] attack from WAN (ip:66.196.65.169) detected. Packet dropped.
Jan 1 21:15:49 ATTACK Detected: 001[Xmas] attack from WAN (ip:66.196.65.169) detected. Packet dropped.
Jan 1 21:15:47 ATTACK Detected: 001[Xmas] attack from WAN (ip:66.196.65.169) detected. Packet dropped.
Jan 1 21:15:46 ATTACK Detected: 001[Xmas] attack from WAN (ip:66.196.65.169) detected. Packet dropped.
Jan 1 21:15:45 ATTACK Detected: 001[Xmas] attack from WAN (ip:66.196.65.169) detected. Packet dropped.
Jan 1 21:58:50 ATTACK Detected: 001[Xmas] attack from WAN (ip:93.85.18.70) detected. Packet dropped.
Jan 1 21:58:41 ATTACK Detected: 001[Xmas] attack from WAN (ip:178.125.16.25) detected. Packet dropped.
Jan 1 21:58:39 ATTACK Detected: 001[Xmas] attack from WAN (ip:95.79.44.137) detected. Packet dropped.
Jan 1 21:58:35 ATTACK Detected: 001[Xmas] attack from WAN (ip:46.0.102.164) detected. Packet dropped.
Jan 1 21:58:22 ATTACK Detected: 001[Xmas] attack from WAN (ip:95.79.44.137) detected. Packet dropped.
Jan 1 21:58:15 ATTACK Detected: 001[Xmas] attack from WAN (ip:188.186.129.75) detected. Packet dropped.
Jan 1 21:58:15 ATTACK Detected: 001[Xmas] attack from WAN (ip:95.79.44.137) detected. Packet dropped.
Jan 1 21:58:04 ATTACK Detected: 001[Xmas] attack from WAN (ip:95.73.2.10) detected. Packet dropped.
Jan 1 21:57:58 ATTACK Detected: 001[Xmas] attack from WAN (ip:95.79.44.137) detected. Packet dropped.
Jan 1 21:57:53 ATTACK Detected: 001[Xmas] attack from WAN (ip:178.125.16.25) detected. Packet dropped.
Jan 1 22:02:08 ATTACK Detected: 001[Xmas] attack from WAN (ip:94.180.174.243) detected. Packet dropped.
Jan 1 22:02:04 ATTACK Detected: 001[Xmas] attack from WAN (ip:95.79.44.137) detected. Packet dropped.
Jan 1 22:02:03 ATTACK Detected: 001[Xmas] attack from WAN (ip:94.180.174.243) detected. Packet dropped.
Jan 1 22:01:56 ATTACK Detected: 001[Xmas] attack from WAN (ip:94.180.174.243) detected. Packet dropped.
Jan 1 22:01:51 ATTACK Detected: 001[Xmas] attack from WAN (ip:94.180.174.243) detected. Packet dropped.
Jan 1 22:01:48 ATTACK Detected: 001[Xmas] attack from WAN (ip:95.79.44.137) detected. Packet dropped.
Jan 1 22:01:47 ATTACK Detected: 001[Xmas] attack from WAN (ip:95.79.205.127) detected. Packet dropped.
Jan 1 22:01:24 ATTACK Detected: 001[Xmas] attack from WAN (ip:95.79.44.137) detected. Packet dropped.
Jan 1 22:01:16 ATTACK Detected: 001[Xmas] attack from WAN (ip:95.79.44.137) detected. Packet dropped.
Jan 1 22:01:12 ATTACK Detected: 001[Xmas] attack from WAN (ip:95.79.44.137) detected. Packet dropped.
теперь еще добавилось
Jan 1 00:20:33 ATTACK Detected: 002[TCP-FLOODING] attack from WAN (ip:91.209.51.98) detected. Packet dropped.
Jan 1 00:20:26 ATTACK Detected: 002[TCP-FLOODING] attack from WAN (ip:178.176.225.171) detected. Packet dropped.
Jan 1 00:20:26 ATTACK Detected: 001[Xmas] attack from WAN (ip:188.162.74.89) detected. Packet dropped.
Jan 1 00:20:22 ATTACK Detected: 001[Xmas] attack from WAN (ip:83.243.71.190) detected. Packet dropped.
Jan 1 00:20:20 ATTACK Detected: 002[TCP-FLOODING] attack from WAN (ip:92.244.120.112) detected. Packet dropped.
Jan 1 00:20:18 ATTACK Detected: 001[Xmas] attack from WAN (ip:109.188.13.146) detected. Packet dropped.
Jan 1 00:20:14 ATTACK Detected: 002[TCP-FLOODING] attack from WAN (ip:92.249.122.28) detected. Packet dropped.
Jan 1 00:20:09 ATTACK Detected: 001[Xmas] attack from WAN (ip:87.117.187.48) detected. Packet dropped.
Jan 1 00:20:08 ATTACK Detected: 002[TCP-FLOODING] attack from WAN (ip:46.98.74.31) detected. Packet dropped.
и вот так 40 страниц.
потом пропадает интернет и в конце логов пишет
Jan 1 22:10:20 PPPoE: Sending PADT for session1. (Session ID: 1fa)
Jan 1 22:10:19 PPP: Connection terminated.
Версия прошивки: Версия программного обеспечения : 1.21 , Fri 17 Jul 2009
пароль на вход в роутер состоит из 15 символов
вай фай шифруется и состоит из 14 символов
Из-за этого интернет подлагивает, как лучше настроить роутер чтобы этого небыло или хотябы немешало?
Все это началось примерно 3 дня назад. Причем непонятно чего( Помогите!!!
Заранее спасибо.
СообщениеДобавлено: Вс окт 03, 2010 16:43
SPI отключен в настройках файрвола? Странно, до этого видел такое только на DIR-300 NRU, там это конкретный глюк прошивки.
На самом деле эти пакеты приходят в ответ на ваши открытые соединения, скажем, аськи или торрента. В клиенте торрента, кстати, рекомендую отключить протокол uTP, опция называется Управление скоростью.
СообщениеДобавлено: Вс окт 03, 2010 17:29
Хорошо бы указывать версию клиента, в которой вы советуете отключать что -то. Могут неправильно понять :wink:
DIR-100 на полке, DIR-655 в использовании...
СообщениеДобавлено: Вс окт 03, 2010 20:19
Несмог ответить так как опять были траблы с инетом.
Вобщем вчера звонил провайдру сказали что типа ничего незнают, а сегодня заявили что есть такая проблема типа инет вылетает и что они с этим разбираются. Кстати у меня такого вообще небыло это вот только 3-2 дня такая лажа а так все было просто супер.
Вобщем непомогло(((( проблема остается куча атак.
