Текущее время: Ср сен 16, 2026 15:45
 Заголовок сообщения: DIR-300 частый разрыв сессии pppoe.
СообщениеДобавлено: Вс сен 05, 2010 23:08
Здравствуйте!
С недавнего времени роутер начал часто вечерами разрывать сессию.
Прошивка последняя, перезаливать не пробовал.
Настроено pppoe dual access russia.
Внешний ip статика.
лог девайса
Aug 24 23:10:49    Time synchronized at 2010/08/24, 23:10:49.
Aug 24 23:10:45    Remote management is disabled.
Aug 24 23:10:45    Block WAN PING is enabled.
Aug 24 23:10:45    DMZ disabled.
Aug 24 23:10:45    VPN (L2TP) Pass-Through enabled.
Aug 24 23:10:45    VPN (IPSec) Pass-Through enabled.
Aug 24 23:10:45    VPN (PPTP) Pass-Through enabled.
Aug 24 23:10:45    Domain blocking disabled.
Aug 24 23:10:45    URL blocking disabled.
Aug 24 23:10:44    MAC filter disabled.
Aug 24 23:10:43    IPCP: secondary DNS address 91.202.25.2.
Aug 24 23:10:43    IPCP: primary DNS address 91.202.24.2.
Aug 24 23:10:43    IPCP: remote IP address 172.16.139.9.
Aug 24 23:10:43    IPCP: local IP address xxx.xxx.xxx.xxx.
Aug 24 23:10:43    CHAP authentication succeeded.
Aug 24 23:10:41    PPPoE: Received PADS for session1. (Session ID: 89)
Aug 24 23:10:41    PPPoE: Sending PADR for session1.
Aug 24 23:10:41    PPPoE: Received PADO for session1, from 00:15:17:24:bd:89.
Aug 24 23:10:41    PPPoE: Sending PADI for session1.
Aug 24 23:10:40    PPPoE: Sending PADT for session1. (Session ID: 52)
Aug 24 23:10:40    PPPoE: Received PADS for session1. (Session ID: bc)
Aug 24 23:10:40    PPPoE: Sending PADR for session1.
Aug 24 23:10:40    PPPoE: Received PADO for session1, from 00:1a:92:46:35:3c.
Aug 24 23:10:40    PPPoE: Sending PADI for session1.
Aug 24 23:10:40    PPPoE: Received PADS for session1. (Session ID: 46)
Aug 24 23:10:40    PPPoE: Received PADO for session1, from 78:e7:d1:f5:70:26.
Aug 24 23:10:39    PPPoE: Sending PADI for session1.
Aug 24 23:09:43    PPPoE: Sending PADR for session1.
Aug 24 23:09:43    PPPoE: Received PADO for session1, from 78:e7:d1:f5:70:26.
Aug 24 23:09:43    PPPoE: Sending PADI for session1.
Aug 24 23:09:42    PPPoE: Sending PADT for session1. (Session ID: d1)
Aug 24 23:09:42    PPP: Connection terminated.
Aug 24 23:09:42    PPPoE: Received PADS for session1. (Session ID: d1)
Aug 24 23:09:41    PPPoE: Sending PADR for session1.
Aug 24 23:09:41    PPPoE: Received PADO for session1, from 18:a9:05:47:c3:04.
Aug 24 23:09:41    PPPoE: Sending PADI for session1.
Aug 24 23:09:41    PPPoE: Sending PADT for session1. (Session ID: a0)
Aug 24 23:09:40    PPP: Connection terminated.
Aug 24 23:09:40    PPPoE: Received PADS for session1. (Session ID: a0)
Aug 24 23:09:40    PPPoE: Sending PADR for session1.
Aug 24 23:09:40    PPPoE: Received PADO for session1, from f4:ce:46:0f:1a:0b.
Aug 24 23:09:40    PPPoE: Sending PADI for session1.
Aug 24 23:09:39    PPPoE: Sending PADT for session1. (Session ID: c4)
Aug 24 23:09:39    PPP: Connection terminated.
Aug 24 23:09:38    PPPoE: Received PADS for session1. (Session ID: c4)
Aug 24 23:09:38    PPPoE: Sending PADR for session1.
Aug 24 23:09:38    PPPoE: Received PADO for session1, from 78:e7:d1:f5:70:26.
Aug 24 23:09:38    PPPoE: Sending PADI for session1.
Aug 24 23:09:38    PPPoE: Sending PADT for session1. (Session ID: 121)
Aug 24 23:09:38    PPP: Connection terminated.
Aug 24 23:09:37    PPPoE: Received PADS for session1. (Session ID: 121)
Aug 24 23:09:37    PPPoE: Sending PADR for session1.
Aug 24 23:09:37    PPPoE: Received PADO for session1, from f4:ce:46:0f:1a:0b.
Aug 24 23:09:37    PPPoE: Sending PADI for session1.
Aug 24 23:09:36    PPPoE: Sending PADT for session1. (Session ID: 97)
Aug 24 23:09:36    PPP: Connection terminated.
Aug 24 23:09:35    PPPoE: Received PADS for session1. (Session ID: 97)
Aug 24 23:09:35    PPPoE: Sending PADR for session1.
Aug 24 23:09:35    PPPoE: Received PADO for session1, from 78:e7:d1:f5:70:26.
Aug 24 23:09:35    PPPoE: Sending PADI for session1.
Aug 24 23:09:35    PPPoE: Sending PADT for session1. (Session ID: b4)
Aug 24 23:09:35    PPP: Connection terminated.
Aug 24 23:09:34    PPPoE: Received PADS for session1. (Session ID: b4)
Aug 24 23:09:34    PPPoE: Sending PADR for session1.
Aug 24 23:09:34    PPPoE: Received PADO for session1, from f4:ce:46:0f:1a:0b.
Aug 24 23:09:34    PPPoE: Sending PADI for session1.
Aug 24 23:09:33    PPPoE: Sending PADT for session1. (Session ID: 69)
и еще
Aug 27 00:03:23 DHCP: Client receive ACK from 10.168.139.2, IP=10.168.139.ххх, Lease time=3600.
Aug 26 23:33:22 DHCP: Client receive ACK from 10.168.139.2, IP=10.168.139.ххх, Lease time=3600.
Aug 26 23:03:20 DHCP: Client receive ACK from 10.168.139.2, IP=10.168.139.ххх, Lease time=3600.
Aug 26 22:03:18 DHCP: Client receive ACK from 10.168.139.2, IP=10.168.139.ххх, Lease time=3600.
Aug 26 21:33:17 DHCP: Client receive ACK from 10.168.139.2, IP=10.168.139.ххх, Lease time=3600.
Aug 26 21:03:16 DHCP: Client receive ACK from 10.168.139.2, IP=10.168.139.ххх, Lease time=3600.
Aug 26 20:33:14 DHCP: Client receive ACK from 10.168.139.2, IP=10.168.139.ххх, Lease time=3600.
странно то, что он каждые полчаса хочет получать локальный ip.
Инфа от провайдера по сессиям
Начало сесии Обновление сессии Окончание сессии Мак адрес ус-ва Внешний ИП Адрес концентратора
2010-09-05 10:38:55 2010-09-05 11:38:56 2010-09-05 11:42:54 ***********:E8:42:34 91.202.xxx.xxx 172.28.xxx.xxx
2010-09-04 23:18:13 2010-09-05 01:43:14 2010-09-05 01:47:31 ***********:E8:42:34 91.202.xxx.xxx 172.28.xxx.xxx
2010-09-04 23:14:29 2010-09-04 23:14:29 2010-09-04 23:16:59 ***********:2A:3F:C1 91.202.xxx.xxx 172.28.xxx.xxx
2010-09-04 23:13:41 2010-09-04 23:13:41 2010-09-04 23:14:30 ***********:2A:3F:C1 91.202.xxx.xxx 172.28.xxx.xxx
2010-09-04 23:13:40 2010-09-04 23:13:40 2010-09-04 23:14:12 ***********:2A:3F:C1 91.202.xxx.xxx 172.28.xxx.xxx
2010-09-04 23:13:22 2010-09-04 23:13:22 2010-09-04 23:13:32 ***********:2A:3F:C1 91.202.xxx.xxx 172.28.xxx.xxx
2010-09-04 23:13:06 2010-09-04 23:13:06 2010-09-04 23:13:24 ***********:2A:3F:C1 91.202.xxx.xxx 172.28.xxx.xxx
2010-09-04 23:13:04 2010-09-04 23:13:04 2010-09-04 23:13:24 ***********:2A:3F:C1 91.202.xxx.xxx 172.28.xxx.xxx
2010-09-04 23:12:17 2010-09-04 23:12:17 2010-09-04 23:13:06 ***********:2A:3F:C1 91.202.xxx.xxx 172.28.xxx.xxx
2010-09-04 23:12:17 2010-09-04 23:12:17 2010-09-04 23:12:50 ***********:2A:3F:C1 91.202.xxx.xxx 172.28.xxx.xxx
2010-09-04 23:12:16 2010-09-04 23:12:16 2010-09-04 23:12:50 ***********:2A:3F:C1 91.202.xxx.xxx 172.28.xxx.xxx
2010-09-04 22:46:05 2010-09-04 23:11:05 2010-09-04 23:12:19 ***********:2A:3F:C1 91.202.xxx.xxx 172.28.xxx.xxx
2010-09-04 11:35:02 2010-09-04 22:45:03 2010-09-04 22:45:56 ***********:2A:3F:C1 91.202.xxx.xxx 172.28.xxx.xxx
Мак сетевой карты
Мак роутера
Сейчас ради теста кабель воткнут напрямую в комп, роутер отключен. Падений связи пока нет.
Причем такое странное поведение отмечается восновном в вечернее время, что в свою очередь тоже странно.
Что можете подсказать на этот счет?
СообщениеДобавлено: Пн сен 06, 2010 01:52
Здравствуйте.
У меня появилась похожая проблема с недавнего времени.
Проработал более 1 года ( supportu огромное спасибо) проблем небыло.
Интернет Beeline pptp ,Wireless Router DIR-300, Firmware Version : 1.05 : происходит разрыв ( не открываются картинки на различных саитах - вообщем "ломает"), или же пишет :
This webpage is not available.
после нескольких попыток RELOAD страниса открывается но в основном "битая".
Если кабель подключен напрямую в комп. проблем нет.
P.S. возможно мне просто нужно обнавить прошивку?
Если да , подскажите это она ftp://ftp.dlink.ru/pub/Router/DIR-300_NRU/Firmware/
Спасибо.
СообщениеДобавлено: Ср сен 08, 2010 08:03
Товарищи инженеры, есть мысли на этот счет?
Мне как бы без роутера тяжеловато. На буке инета нет ((
СообщениеДобавлено: Ср сен 08, 2010 21:59
Господа, может кто-то ответит что путного? Какие варианты диагностики и решения данной проблемы? Вторые сутки без роутера обрывов инета нет.
СообщениеДобавлено: Вс сен 19, 2010 15:44
Караул. Такие все занятые. Надо месяц ждать совета видимо....
СообщениеДобавлено: Пн сен 20, 2010 17:02
Настройки подключения предоставить можете?
MTU пробовали понижать в настройках подключения роутера?
СообщениеДобавлено: Пн сен 20, 2010 20:26
Какие настройки вам нужно проверить? Могу выложить сохраненную конфигурацию в файл.
С mtu не баловался. Какое оптимальное значение можно выставить? Завтра попробую.
Может как то повлиять перепрошивка девайса (на туже версию, т.к. последняя версия) ?
p/s/ Я понимаю, что форум не подразумевает быстрый ответ, но всеже ответили вы через 15 дней. Обычно оперативнее реагировали.
СообщениеДобавлено: Вт сен 21, 2010 14:05
Можно конфиг, можно и скрин.
MTU нужно уменьшать с шагом 50 до 1000 подбирая оптимальное для вас значение.
Тем на форуме и в этом разделе очень много (самый популярный раздел), возможно затерялась, для быстрого ответа - пишите на почту.
СообщениеДобавлено: Вт сен 28, 2010 15:44
Залил прошивку 2.05beta.
Позавчера и вчера заметил такую вещь. Сессия не разрывается (судя по логу роутера) но буквально на 8-10 сек пропадала связь, ничего не пинговалось, потом все ок. Такое повторялось раза 2-3 за каждый вечер.
to Vitaliy
Отправил почтой последние данные, с конфигом и скрином. Ответа нет.
СообщениеДобавлено: Ср сен 29, 2010 12:45
Сейчас ведутся работы над новой версией прошивки с русскоязычным интерфейсом, в ближайшем будущем прошивка будет выложена на паблик, многие проблемы в ней решены, производительность PPTP и L2TP немного повысилась.
СообщениеДобавлено: Ср сен 29, 2010 13:49
А можно узнать хотя бы ориентировочную дату релиза?
Октябрь, ноябрь, декабрь... ?
Да шут с ним с русскоязычным интерфейсом, не в нем счастье, главное чтобы fw стабильна была.
Потому как конкретно в моей ситуации однозначно не скажешь, что проблема именно с роутером, т.к. похожее поведение отмечалось и когда кабель был напрямую вставлен в комп, НО гораздо реже, 1 раз в 2-3 дня и буквально 1 раз за вечер всего лишь.
Собственно техсаппорт провайдера настаивает на том, что проблемы именно у меня в аппаратно-программной части.
В понедельник переустановил ОС, со всеми самыми последними версиями драйверов. Изменений никаких.
СообщениеДобавлено: Ср сен 29, 2010 17:06
Точных сроков пока нет, но думаю этой осенью прошивка появится на паблике.
Сейчас этот форум просматривают: Google [Bot] и гости: 23
