Текущее время: Пт окт 02, 2026 11:04
 Заголовок сообщения: Dir-615 WAN interface is down
СообщениеДобавлено: Вт авг 03, 2010 20:31
В последние дни стал замечать, что у меня постоянно нет инета, что-то часто он отваливаться стал, залез в лог и увидел такую красоту:
[INFO] Tue Aug 03 19:06:33 2010 Above message repeated 4 times
[INFO] Tue Aug 03 19:05:52 2010 Stopping WAN Services
[INFO] Tue Aug 03 19:05:52 2010 WAN interface is down
[INFO] Tue Aug 03 18:57:05 2010 SMTP (Email) server ######### is at IP address #########
[INFO] Tue Aug 03 18:57:05 2010 Time server ntp1.dlink.com is at IP address #########
[INFO] Tue Aug 03 18:57:00 2010 Starting WAN Services
[INFO] Tue Aug 03 18:57:00 2010 WAN interface is up. Connection to Internet established with IP Address ######### and default gateway #########
[INFO] Tue Aug 03 18:57:00 2010 WAN interface is down
[INFO] Tue Aug 03 18:56:29 2010 Stopping WAN Services
[INFO] Tue Aug 03 18:56:29 2010 WAN interface is down
[INFO] Tue Aug 03 18:52:57 2010 SMTP (Email) server ######### is at IP address #########
[INFO] Tue Aug 03 18:52:57 2010 Time server ntp1.dlink.com is at IP address #########
[INFO] Tue Aug 03 18:52:52 2010 Starting WAN Services
[INFO] Tue Aug 03 18:52:52 2010 WAN interface is up. Connection to Internet established with IP Address ######### and default gateway #########
[INFO] Tue Aug 03 18:52:52 2010 WAN interface is down
[INFO] Tue Aug 03 18:52:22 2010 Stopping WAN Services
[INFO] Tue Aug 03 18:52:22 2010 WAN interface is down
[INFO] Tue Aug 03 18:49:42 2010 SMTP (Email) server ######### is at IP address #########
[INFO] Tue Aug 03 18:49:42 2010 Time server ntp1.dlink.com is at IP address 61.67.210.241
[INFO] Tue Aug 03 18:49:37 2010 Starting WAN Services
[INFO] Tue Aug 03 18:49:37 2010 WAN interface is up. Connection to Internet established with IP Address ######### and default gateway #########
[INFO] Tue Aug 03 18:49:37 2010 WAN interface is down
[INFO] Tue Aug 03 18:49:06 2010 Above message repeated 1 times
[INFO] Tue Aug 03 18:49:05 2010 Stopping WAN Services
[INFO] Tue Aug 03 18:49:05 2010 WAN interface is down
[INFO] Tue Aug 03 18:41:45 2010 Time server ntp1.dlink.com is at IP address #########
[INFO] Tue Aug 03 18:41:45 2010 SMTP (Email) server ######### is at IP address #########
[INFO] Tue Aug 03 18:41:40 2010 Starting WAN Services
[INFO] Tue Aug 03 18:41:40 2010 WAN interface is up. Connection to Internet established with IP Address ######### and default gateway #########
[INFO] Tue Aug 03 18:41:40 2010 WAN interface is down
[INFO] Tue Aug 03 18:41:09 2010 Stopping WAN Services
[INFO] Tue Aug 03 18:41:09 2010 WAN interface is down
[INFO] Tue Aug 03 18:39:45 2010 Time server ntp1.dlink.com is at IP address 61.67.210.241
[INFO] Tue Aug 03 18:39:45 2010 SMTP (Email) server ######### is at IP address #########
[INFO] Tue Aug 03 18:39:40 2010 Starting WAN Services
[INFO] Tue Aug 03 18:39:40 2010 WAN interface is up. Connection to Internet established with IP Address ######### and default gateway #########
[INFO] Tue Aug 03 18:39:40 2010 WAN interface is down
[INFO] Tue Aug 03 18:38:51 2010 Above message repeated 4 times
[INFO] Tue Aug 03 18:38:09 2010 Stopping WAN Services
[INFO] Tue Aug 03 18:38:09 2010 WAN interface is down
[INFO] Tue Aug 03 18:35:12 2010 Time server ntp1.dlink.com is at IP address 61.67.210.241
[INFO] Tue Aug 03 18:35:12 2010 SMTP (Email) server ######### is at IP address #########
[INFO] Tue Aug 03 18:35:07 2010 Starting WAN Services
[INFO] Tue Aug 03 18:35:07 2010 WAN interface is up. Connection to Internet established with IP Address ######### and default gateway #########
[INFO] Tue Aug 03 18:35:07 2010 WAN interface is down
[INFO] Tue Aug 03 18:33:17 2010 Above message repeated 8 times
[INFO] Tue Aug 03 18:32:37 2010 Stopping WAN Services
[INFO] Tue Aug 03 18:32:37 2010 WAN interface is down
[INFO] Tue Aug 03 18:23:41 2010 Time server ntp1.dlink.com is at IP address #########
[INFO] Tue Aug 03 18:23:41 2010 SMTP (Email) server ######### is at IP address #########
[INFO] Tue Aug 03 18:23:36 2010 Starting WAN Services
[INFO] Tue Aug 03 18:23:36 2010 WAN interface is up. Connection to Internet established with IP Address ######### and default gateway #########
[INFO] Tue Aug 03 18:23:36 2010 WAN interface is down
[INFO] Tue Aug 03 18:23:05 2010 Stopping WAN Services
[INFO] Tue Aug 03 18:23:05 2010 WAN interface is down
[INFO] Tue Aug 03 18:18:06 2010 Time server ntp1.dlink.com is at IP address 61.67.210.241
[INFO] Tue Aug 03 18:18:06 2010 SMTP (Email) server ######### is at IP address #########
[INFO] Tue Aug 03 18:18:01 2010 Starting WAN Services
[INFO] Tue Aug 03 18:18:01 2010 WAN interface is up. Connection to Internet established with IP Address ######### and default gateway #########
[INFO] Tue Aug 03 18:18:01 2010 WAN interface is down
[INFO] Tue Aug 03 18:17:21 2010 Stopping WAN Services
[INFO] Tue Aug 03 18:17:21 2010 WAN interface is down
[INFO] Tue Aug 03 18:07:12 2010 Time server ntp1.dlink.com is at IP address #########
[INFO] Tue Aug 03 18:07:12 2010 SMTP (Email) server ######### is at IP address #########
[INFO] Tue Aug 03 18:07:07 2010 Starting WAN Services
[INFO] Tue Aug 03 18:07:07 2010 WAN interface is up. Connection to Internet established with IP Address ######### and default gateway #########
[INFO] Tue Aug 03 18:07:07 2010 WAN interface is down
[INFO] Tue Aug 03 18:06:06 2010 Above message repeated 3 times
[INFO] Tue Aug 03 18:06:05 2010 Stopping WAN Services
[INFO] Tue Aug 03 18:06:05 2010 WAN interface is down
[INFO] Tue Aug 03 17:45:50 2010 SMTP (Email) server ######### is at IP address #########
[INFO] Tue Aug 03 17:45:50 2010 Time server ntp1.dlink.com is at IP address #########
[INFO] Tue Aug 03 17:45:45 2010 Starting WAN Services
[INFO] Tue Aug 03 17:45:45 2010 WAN interface is up. Connection to Internet established with IP Address ######### and default gateway #########
[INFO] Tue Aug 03 17:45:45 2010 WAN interface is down
[INFO] Tue Aug 03 17:45:14 2010 Stopping WAN Services
[INFO] Tue Aug 03 17:45:14 2010 WAN interface is down
Объясните мне пожалуйста, это мой роутер сам отваливается или провайдер виноват в постоянных отключениях? Где копать?
Заранее благодарен!
СообщениеДобавлено: Ср авг 04, 2010 06:31
В этой ветке обсуждаются коммутаторы
Перенесите ваш вопрос в раздел "Маршрутизаторы и Firewall" ( http://forum.dlink.ru/viewforum.php?f=3) - быстрее и грамотнее ответят.
не важно, из какого места растут золотые руки
СообщениеДобавлено: Ср авг 04, 2010 07:00
я бы с удовольствием перенёс, только прав нету.
товарищи модераторы перенесите тему пожалуйста!
СообщениеДобавлено: Чт авг 05, 2010 20:23
Ау господа из Dlink помогите советом :?: :!:
СообщениеДобавлено: Сб авг 07, 2010 15:46
viewtopic.php?t=110340
Сейчас этот форум просматривают: Google [Bot] и гости: 46
