Текущее время: Чт сен 17, 2026 18:28
 Заголовок сообщения: Проблема подключение dir-412
СообщениеДобавлено: Пт июл 30, 2010 11:47
прошивка последняя (с вашего форума)
модем mf626 . разлочен , билайн
лог.
Fri Dec 31 19:04:25 1999 Connect script failed
Fri Dec 31 19:04:14 1999 speed 11520 not supported
Fri Dec 31 19:04:14 1999 pppd 2.4.2b3 started by (unknown), uid 0
Fri Dec 31 19:04:09 1999 NTC:001
Fri Dec 31 19:04:09 1999 Connection terminated.
Fri Dec 31 19:04:09 1999 Modem hangup
Fri Dec 31 19:04:08 1999 SYS:027
Fri Dec 31 19:04:08 1999 CHAP authentication succeeded
Fri Dec 31 19:04:06 1999 speed 11520 not supported
Fri Dec 31 19:04:06 1999 pppd 2.4.2b3 started by (unknown), uid 0
