Текущее время: Пн сен 14, 2026 06:34
 Заголовок сообщения: DIR-400 & PPPoE
СообщениеДобавлено: Сб май 08, 2010 18:53
примерно каждые 10-40 мин. отваливается PPP-сессия.
при подключении провода провайдера напрямую к компьютеру сессия держится сутками.
Time     Message
May 8 21:20:21    read /etc/hosts - 1 addresses
May 8 21:20:21    using nameserver 85.116.126.126#53
May 8 21:20:21    using nameserver 195.54.19.94#53
May 8 21:20:21    reading /etc/resolv.conf
May 8 21:20:21    compile time options: no-IPv6 GNU-getopt no-ISC-leasefile no-DBus no-I18N no-TFTP
May 8 21:20:21    started, version 2.41 cachesize 150
May 8 21:20:18    gpio create pidfile /var/run/gpio.pid
May 8 21:20:17    exiting on receipt of SIGTERM
May 8 21:20:15    using nameserver 85.116.126.126#May 8 21:20:15 DIR-400 daemon.info dnsmasq[1222]: using nameserver 195.54.19.94#53
May 8 21:20:15    reading /etc/resolv.conf
May 8 21:20:15     pppd sent restart signal to rc
May 8 21:20:15    pppd check for rc to be idle ?
May 8 21:20:15    secondary DNS address 195.54.19.94
May 8 21:20:15    primary DNS address 85.116.126.126
May 8 21:20:15    ipcp_up: remote PPP IP address 188.17.105.1
May 8 21:20:15    ipcp_up: local PPP IP address 90.151.230.45
May 8 21:20:15    ipcp_up: Open /var/tmp/pptp_server_ip.txt (l2tp_server_ip.txt) fail or Using PPPoE
May 8 21:20:15    dhcp_dns : nameserver 195.54.19.94
May 8 21:20:15    peerdns1 : 85.116.126.126
May 8 21:20:15    ppp create_resolv in ipcp
ay 8 21:20:15     rcvd [IPCP ConfAck id=0x2 'addr 90.151.230.45' 'ms-dns1 85.116.126.126' 'ms-dns3 195.54.19.94'] 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
May 8 21:20:15    sent [IPCP ConfReq id=0x2 'addr 90.151.230.45' 'ms-dns1 85.116.126.126' 'ms-dns3 195.54.19.94']
May 8 21:20:15    rcvd [IPCP ConfNak id=0x1 'addr 90.151.230.45' 'ms-dns1 85.116.126.126' 'ms-dns3 195.54.19.94'] 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
May 8 21:20:15    sent [IPCP ConfAck id=0x1 'addr 188.17.105.1']
May 8 21:20:15    rcvd [IPCP ConfReq id=0x1 'addr 188.17.105.1'] 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
May 8 21:20:15    sent [IPCP ConfReq id=0x1 'addr 0.0.0.0' 'ms-dns1 0.0.0.0' 'ms-dns3 0.0.0.0']
May 8 21:20:15    peer from calling number 00:21:A0:E5:65:78 authorized
May 8 21:20:15    PAP authentication succeeded
May 8 21:20:15    rcvd [PAP AuthAck id=0x1 ] 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ...
May 8 21:20:13    rcvd [LCP EchoRep id=0x0 magic=0x95866725] 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
May 8 21:20:13     sent [PAP AuthReq id=0x1 user= 77740171902 password='hidden']
May 8 21:20:13    sent [LCP EchoReq id=0x0 magic=0x71364e11]
May 8 21:20:13    rcvd [LCP ConfAck id=0x1 'mru 1492' 'magic 0x71364e11'] 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
May 8 21:20:13    sent [LCP ConfAck id=0x1 'mru 1492' 'auth pap' 'magic 0x95866725']
May 8 21:20:13    rcvd [LCP ConfReq id=0x1 'mru 1492' 'auth pap' 'magic 0x95866725'] 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
прошивка DIR400A1_FW103b09_beta02.bin
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 146
