Текущее время: Вт ноя 03, 2026 07:01
СообщениеДобавлено: Чт ноя 13, 2008 16:22
имею DI-LB604, модем dsl-2540U(провайдер WPLUS).
модем периодически (1-2 раза в день) теряет соединение (это вопрос другой темы).
проблема в том, что DI-LB604 не видит этой потери и не переключается на второй канал. в настройках нашел вот такую страничку и help к нему
но настроить не смог, какую галочку не ставлю, что не прописываю, DI-LB604 сразу понимает это как потерю соединения и закрывает канал. какой метод выбрать и что прописать в Alive Indicator ?
Connection Health Check:
There are three methods, ICMP, HTTP and Traffic, provided for device to check if WAN interfaces are connected to internet or not.
The successful response of either method is considered that the connection is OK. And while all the choosen methods fail, the connection is considered to be failure.
Method:
ICMP:
The health checking is performing by sending an ICMP echo request packet to the specific destination.
The specific destination ("Alive Indicator") could be either :
1. if the input box is filled (NAME or IP address): the host is used.
2. if the input box is left blank: gateway of wan interface will be used.
Then if one ICMP echo reply packet from Alive Indicator or gateway is received, the connection is considered OK. If there are no response received after 4 tries, the connection is considered to be failure.
HTTP:
The device gets TCP connection with the Alive Indicator first. Then the device sends HTTP HEAD packet to the Alive Indicator. If any HTTP DATA from the Alive Indicator is received, the connection is considered OK. If there are no response received after 5 tries, the connection is considered to be failure.
Traffic:
If there is no traffic on the WAN port in the Interval time, the connection is considered to be failure.
Interval:
The period to check if the WAN port is alive or not.
Alive Indicator:
This is used for Method ICMP or HTTP to determine if your Internet connection is active or not.(You can either fill-out the IP address or host name)
СообщениеДобавлено: Пт ноя 14, 2008 11:55
Обновите прошивку до последней версии, и используйте ICMP мониторинг, допустим до вашего DNS сервера который получается по PPPoE подключение.
СообщениеДобавлено: Пн мар 29, 2010 14:48
имеется в виду адрес dns сервера?
Сейчас этот форум просматривают: Google [Bot] и гости: 97
