Текущее время: Пн сен 28, 2026 07:25
 Заголовок сообщения: di808hv vpn поднялся но пакетов нету.
СообщениеДобавлено: Пн ноя 02, 2009 14:48
Поднимаю vpn между двумя одинаковыми di808hv, в статусе - туннель поднялся но пакеты не идут, в чем может быть проблема? (с аналогичными настройками у другого провайдера все работает)
Лог одного маршрутизатора:
Sunday November 26, 2006 22:25:05 Receive IKE M6(IDRESP) : 77.105.116.109 --> 80.252.150.200
Sunday November 26, 2006 22:25:05 IKE Phase1 (ISAKMP SA) established : 77.105.116.109 <-> 80.252.150.200
Sunday November 26, 2006 22:25:05 Send IKE Q1(QINIT) : 192.168.25.0 --> 192.168.1.0
Sunday November 26, 2006 22:25:05 Receive IKE Q2(QRESP) : [192.168.1.0|77.105.116.109]-->[80.252.150.200|192.168.25.0]
Sunday November 26, 2006 22:25:05 Try to match ESP with MODE:Tunnel PROTOCAL:ESP-3DES AUTH:MD5 HASH:Others PFS(Group):NONE
Sunday November 26, 2006 22:25:05 Send IKE Q3(QHASH) : 192.168.25.0 --> 192.168.1.0
Sunday November 26, 2006 22:25:05 IKE Phase2 (IPSEC SA) established : [192.168.1.0|77.105.116.109]<->[80.252.150.200|192.168.25.0]
Sunday November 26, 2006 22:25:05 inbound SPI = 0x2a010010, outbound SPI = 0x71360010
Sunday November 26, 2006 22:25:26 Send IKE (INFO) : delete [192.168.25.0|80.252.150.200]-->[77.105.116.109|192.168.1.0] phase 2
Sunday November 26, 2006 22:25:26 IKE phase2 (IPSec SA) remove : 192.168.25.0 <-> 192.168.1.0
Sunday November 26, 2006 22:25:26 inbound SPI = 0x2a010010, outbound SPI = 0x71360010
Sunday November 26, 2006 22:25:26 Send IKE (INFO) : delete 80.252.150.200 -> 77.105.116.109 phase 1
Sunday November 26, 2006 22:25:26 IKE phase1 (ISAKMP SA) remove : 80.252.150.200 <-> 77.105.116.109
Sunday November 26, 2006 22:29:26 Send IKE (INFO) : delete [192.168.25.0|80.252.150.200]-->[77.105.116.109|192.168.1.0] phase 2
Sunday November 26, 2006 22:29:26 IKE phase2 (IPSec SA) remove : 192.168.25.0 <-> 192.168.1.0
Sunday November 26, 2006 22:29:26 inbound SPI = 0x29010010, outbound SPI = 0x6f360010
Sunday November 26, 2006 22:29:26 Send IKE (INFO) : delete 80.252.150.200 -> 77.105.116.109 phase 1
Sunday November 26, 2006 22:29:26 IKE phase1 (ISAKMP SA) remove : 80.252.150.200 <-> 77.105.116.109
Sunday November 26, 2006 22:29:26 Send IKE M1(INIT) : 80.252.150.200 --> 77.105.116.109
Sunday November 26, 2006 22:29:26 Receive IKE M2(RESP) : 77.105.116.109 --> 80.252.150.200
Sunday November 26, 2006 22:29:26 Try to match with ENC:3DES AUTH:PSK HASH:SHA1 Group:Group2
Sunday November 26, 2006 22:29:26 Send IKE M3(KEYINIT) : 80.252.150.200 --> 77.105.116.109
Sunday November 26, 2006 22:29:26 Receive IKE M4(KEYRESP) : 77.105.116.109 --> 80.252.150.200
Sunday November 26, 2006 22:29:26 Send IKE M5(IDINIT) : 80.252.150.200 --> 77.105.116.109
Sunday November 26, 2006 22:29:26 Receive IKE M6(IDRESP) : 77.105.116.109 --> 80.252.150.200
Sunday November 26, 2006 22:29:26 IKE Phase1 (ISAKMP SA) established : 77.105.116.109 <-> 80.252.150.200
Sunday November 26, 2006 22:29:26 Send IKE Q1(QINIT) : 192.168.25.0 --> 192.168.1.0
Sunday November 26, 2006 22:29:26 Receive IKE Q2(QRESP) : [192.168.1.0|77.105.116.109]-->[80.252.150.200|192.168.25.0]
Sunday November 26, 2006 22:29:26 Try to match ESP with MODE:Tunnel PROTOCAL:ESP-3DES AUTH:MD5 HASH:Others PFS(Group):NONE
Sunday November 26, 2006 22:29:26 Send IKE Q3(QHASH) : 192.168.25.0 --> 192.168.1.0
Sunday November 26, 2006 22:29:26 IKE Phase2 (IPSEC SA) established : [192.168.1.0|77.105.116.109]<->[80.252.150.200|192.168.25.0]
Sunday November 26, 2006 22:29:26 inbound SPI = 0x2c010010, outbound SPI = 0x84360010
Sunday November 26, 2006 22:31:44 Blocked access attempt from 10.100.14.80:1113 to TCP port 445
Sunday November 26, 2006 22:31:47 Blocked access attempt from 10.100.14.80:1113 to TCP port 445
Sunday November 26, 2006 22:36:07 Blocked access attempt from 77.68.53.48:4986 to TCP port 5900
Sunday November 26, 2006 22:36:10 Blocked access attempt from 77.68.53.48:4986 to TCP port 5900
СообщениеДобавлено: Чт ноя 05, 2009 22:06
Какие прошивки используются на устройствах? Поднимаете IPSec? Возможно блокировка идет на уровне провайдера.
СообщениеДобавлено: Вт ноя 10, 2009 10:21
Прошивка на одном V1.43, Thu, Jan 26 2006, на другом V1.44, Fri, Nov 24 2006 Провайдер говорит что со своей стороны ничего не блокирует. Поднимаю IPSec тоннель.
СообщениеДобавлено: Вт ноя 10, 2009 15:39
Обновляйте прошивку до последней версии: http://ftp.dlink.ru/pub/Router/DI-804HV ... .51b13.BIN
инструкция по прошивке: http://dlink.ru/ru/faq/69/318.html
не забудьте сделать сброс устройства на заводские настройки после прошивки и настроить заново вручную.
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 49
