Текущее время: Ср сен 30, 2026 19:09
Начать новую тему Эта тема закрыта, Вы не можете редактировать и оставлять сообщения в ней.  [ Сообщений: 2 ]
 Заголовок сообщения: DIR-300 и 802.1x
СообщениеДобавлено: Пт сен 25, 2009 14:29
Администрация скажите пожалуйста, что данный аппарат поддерживает 802.1х???
build 85mf (2008/05/21)
svn: 4684
NOTE:
1. The version number is v1.04.
Bug Fix:
1.Get wrong ssid in hidden page.
2.Check invalid IP address as like "11.255.255.255".
3.Add the 802.1x function in Russia PPPoE and PPTP mode.
4.Change the expire counter to count lease interval, not time point, to revise
the lease time dislay issue.
5.Comment the decrease ttl line to prevent ttl be descreased, as d-link
request.
6.NAT port redirect failed. LAN pc cannot access DMZ(LAN) by using WAN ip
address.
7.When MAC address filter enable, deny device MAC LAN to LAN access
OK, and if it same time have config DMZ or Port forwarding, still can use
access it from WAN ip address. Add FOR_MACFILTER on 'FORWARD' point in
'filter' table.
8.DUT crash when LAN access internet.Test procedure: Device add language
pack->Reboot ->WAN connect PPPoE success-->LAN access internet-->DUT crash.
9.DUT crashed after running BT for 14 hours
10.DI-300 random kill process in the 1.04 855n.Test environment:
1). DI-300 config DHCP mode ( DHCP Server release 5mins)
2). Ixload run Qhttp script for 180000 connections
11.This is one work around solution.Four crash issue:
issue1 : BT caused device panic
issue2 : kernel timer function panic
issue3 : Zyxel P-827H VDSL modem caused device break
issue4 : memory allocate error message and user cann't access device webUI
12.DIR-300 WEB VM: killing process issue when user push "connect" button of
PPPoE. Add a javascript code to block the multiple click event.
13.Netmeeting sometimes work, sometimes failed.
14.Revised the ping test script, replace the "ping -q -c" with simple
"ping".
СообщениеДобавлено: Ср сен 30, 2009 14:56
DIR-300 не поддерживает 802.1x, это была ошибка, мы её исправили. Спасибо что обратили на нее внимание.
Сейчас этот форум просматривают: Google [Bot] и гости: 173
