Текущее время: Пт апр 26, 2024 21:34
 Заголовок сообщения: Ежедневный сбой сети DIR-842
СообщениеДобавлено: Сб май 14, 2022 07:43
Модель:
DIR-842
Аппаратная версия:
R1
Версия ПО:
3.0.3
сегодняшние логи
May 13 02:49:19 pppd[3899]: LCP terminated by peer
May 13 02:49:19 pppd[3899]: Connect time 1440.0 minutes.
May 13 02:49:19 pppd[3899]: Sent 1887647326 bytes, received 4085967019 bytes.
May 13 02:49:19 dms_reset_uptime[1330]: enter key eth1_3
May 13 02:49:20 pppd[3899]: Modem hangup
May 13 02:49:20 pppd[3899]: Connection terminated.
May 13 02:49:20 pppd[3899]: Sent PADT
May 13 02:49:20 pppd[3899]: Failed to disconnect PPPoE socket: 149 Operation already in progress
May 13 02:49:20 pppd[3899]: _send_event_to_daemon (from [3899]main.c:die[1258]) msg: [P044action:down;iface:ppp0;status:1;link:eth1_3;]
May 13 02:49:20 pppd[3899]: Exit, status: 1
May 13 02:49:24 pppd[1405]: Plugin /usr/lib/pppd/rp-pppoe.so loaded.
May 13 02:49:24 pppd[1405]: RP-PPPoE plugin version 3.3 compiled against pppd 2.4.4
May 13 02:49:24 pppd[1406]: entering dlock, dfd = -1
May 13 02:49:24 pppd[1406]: dlock: locked
May 13 02:49:24 pppd[1406]: pppd 2.4.4 started by admin, uid 0
May 13 02:49:32 pppd[1406]: PPP session is 14834
May 13 02:49:32 pppd[1406]: Using interface ppp0
May 13 02:49:32 pppd[1406]: Connect: ppp0 <--> eth1
May 13 02:49:33 pppd[1406]: PAP authentication succeeded
May 13 02:49:33 pppd[1406]: peer from calling number C4:64:13:23:69:C0 authorized
May 13 02:49:33 pppd[1406]: local IP address 100.71.18.4
May 13 02:49:33 pppd[1406]: remote IP address 10.45.255.253
May 13 02:49:33 pppd[1406]: primary DNS address 213.87.74.5
May 13 02:49:33 pppd[1406]: secondary DNS address 213.87.74.21
May 13 02:49:36 ppp_is_up[1418]: ppp0 speed: 1000M Full[spoiler]
подскажите как исправить?
вчерашние логи
May 13 02:47:40 igmpx[3379]: leave group 224.0.0.252 from 192.168.1.53
 Заголовок сообщения: Re: Ежедневный сбой сети DIR-842
СообщениеДобавлено: Сб июн 04, 2022 18:16
Можете помочь, уже почти месяц ответа жду!!!???
СообщениеДобавлено: Сб июн 04, 2022 21:37
Здравствуйте.
Вы прислали один и тот же кусок лога два раза. Из лога видно, что соединение прерывается и устанавливается заново через 12 секунд.
Опишите проблему более подробно в электронном письме и направьте его на электронный адрес router@dlink.ru
Сейчас этот форум просматривают: Google [Bot] и гости: 159
