Текущее время: Вс ноя 08, 2026 04:58
СообщениеДобавлено: Пн мар 19, 2018 21:28
Добрый день,
Поделитесь пожалуйста бинарником загрузчика.
Добрался до альтернативного загрузчика по инструкции -
1. Open the case and remove the jumper (there is only one jumper). This way
you will boot into failsafe bootloader.
2. Connect a RS232 cable to console port. Settings: 115200 8N1 parity none,
flow control none.
3. Power on the router
4. If you don't have the uboot binary please contact me and I will send it
to you.
5. Because the failsafe bootloader does not support networking, you have to
load the file using a serial connection. At dsr prompt enter: loadb
6. Now send the binary file to the router using any terminal which is
capable to send files with kermit (I use hyperterminal)
7. After the file is successfully loaded onto the router, type the
following command: run bootloader_flash_update
8. After the update is done, power off the router and put the jumper back.
Now your DSR should boot the normal way.
СообщениеДобавлено: Пн мар 19, 2018 22:25
UPD. - H/W Ver. A1
Сейчас этот форум просматривают: Baidu [Spider], Google [Bot] и гости: 26
