Текущее время: Пн ноя 09, 2026 07:00
 Заголовок сообщения: Разрыв соединения PPTP на D-Link DIR-816L
СообщениеДобавлено: Сб авг 13, 2016 21:01
Добрый день! Есть роутер D-Link DIR-816L, прошивка 2.03, ревизия B1, на нем создано PPTP подключение. Интернет работает, но иногда (всегда через разные промежутки времени) пропадает. Открыл логи, прежде чем пропадает доступ в интернет
PPP: No response to [14] LCP echo requests.
[Time]Fri Aug 12 11:19:29 2016
[Message:65]WAN connected [PPTP]
[Time]Fri Aug 12 11:19:33 2016
[Message:66]Time synchronized
[Time]Fri Aug 12 11:20:03 2016
[Message:67]Web login success from 127.0.0.1
[Time]Fri Aug 12 11:20:20 2016
[Message:68]DHCP: Server receive REQUEST from 24:a2:e1:47:c5:5f.
[Message:69]DHCP: Server sending NAK to 24:a2:e1:47:c5:5f.
[Message:70]DHCP: Server receive DISCOVER from 24:a2:e1:47:c5:5f.
[Message:71]DHCP: Server sending OFFER of 192.168.1.127.
[Message:72]Got new client [24:A2:E1:47:C5:5F] associated from BAND5G-1.1 (5 Ghz)
[Time]Fri Aug 12 11:20:21 2016
[Message:73]DHCP: Server receive REQUEST from 24:a2:e1:47:c5:5f.
[Message:74]DHCP: Server sending ACK to 192.168.1.127. (Lease time = 604800)
[Time]Fri Aug 12 11:20:26 2016
[Message:75]anon log[logecho:accel-pptp/pptp_ctrl_0_7_13.c:687]: Echo Reply received.
[Time]Fri Aug 12 11:21:26 2016
[Message:76]anon log[logecho:accel-pptp/pptp_ctrl_0_7_13.c:687]: Echo Reply received.
[Time]Fri Aug 12 11:22:26 2016
[Message:77]anon log[logecho:accel-pptp/pptp_ctrl_0_7_13.c:687]: Echo Reply received.
[Time]Fri Aug 12 11:23:26 2016
[Message:78]anon log[logecho:accel-pptp/pptp_ctrl_0_7_13.c:687]: Echo Reply received.
[Time]Fri Aug 12 11:24:26 2016
[Message:79]anon log[logecho:accel-pptp/pptp_ctrl_0_7_13.c:687]: Echo Reply received.
[Time]Fri Aug 12 11:25:26 2016
[Message:80]anon log[logecho:accel-pptp/pptp_ctrl_0_7_13.c:687]: Echo Reply received.
[Time]Fri Aug 12 11:26:26 2016
[Message:81]anon log[logecho:accel-pptp/pptp_ctrl_0_7_13.c:687]: Echo Reply received.
[Time]Fri Aug 12 11:27:26 2016
[Message:82]anon log[logecho:accel-pptp/pptp_ctrl_0_7_13.c:687]: Echo Reply received.
[Time]Fri Aug 12 11:28:26 2016
[Message:83]anon log[logecho:accel-pptp/pptp_ctrl_0_7_13.c:687]: Echo Reply received.
[Time]Fri Aug 12 11:29:26 2016
[Message:84]anon log[logecho:accel-pptp/pptp_ctrl_0_7_13.c:687]: Echo Reply received.
[Message:85]anon log[logecho:accel-pptp/pptp_ctrl_0_7_13.c:689]: no more Echo Reply/Request packets will be reported.
[Time]Fri Aug 12 11:32:07 2016
[Message:86]Web login success from 127.0.0.1
[Time]Fri Aug 12 11:32:58 2016
[Message:87]Web login success from 127.0.0.1
[Time]Fri Aug 12 11:33:40 2016
[Message:88]Web login success from 127.0.0.1
[Time]Fri Aug 12 11:53:12 2016
[Message:89]PPP: No response to [14] LCP echo requests.
[Message:90]WAN disconnected [PPTP]
[Time]Fri Aug 12 11:53:14 2016
[Message:91]warning: no upstream servers configured
[Time]Fri Aug 12 11:53:15 2016
[Message:92]anon log[ctrlp_disp:accel-pptp/pptp_ctrl_0_7_13.c:939]: Call disconnect notification received (call id 512)
[Message:93]anon log[ctrlp_disp:accel-pptp/pptp_ctrl_0_7_13.c:798]: Received Stop Control Connection Request.
[Message:94]anon log[ctrlp_rep:accel-pptp/pptp_ctrl_0_7_13.c:251]: Sent control packet type is 4 'Stop-Control-Connection-Reply'
[Message:95]anon log[callmgr_main:accel-pptp/pptp_callmgr.c:269]: Closing connection (shutdown)
[Message:96]anon log[ctrlp_rep:accel-pptp/pptp_ctrl_0_7_13.c:251]: Sent control packet type is 12 'Call-Clear-Request'
[Message:97]anon log[pptp_read_some:accel-pptp/pptp_ctrl_0_7_13.c:542]: read returned zero, peer has closed
[Time]Fri Aug 12 11:53:16 2016
[Message:98]anon log[call_callback:accel-pptp/pptp_callmgr.c:79]: Closing connection (call state)
[Time]Fri Aug 12 11:53:18 2016
[Message:99]PPP: Connection terminated.
[Time]Fri Aug 12 11:53:20 2016
[Message:100]DHCP: Client release IP 10.244.233.241 to server 62.106.124.5.
[Time]Fri Aug 12 11:53:22 2016
[Message:101]warning: no upstream servers configured
[Time]Fri Aug 12 11:53:25 2016
[Message:102]DHCP: Client send DISCOVER.
[Time]Fri Aug 12 11:53:26 2016
[Message:103]DHCP: Client receive OFFER from 62.106.124.5.
[Message:104]DHCP: Client send REQUEST, Request IP 10.244.233.241 from 62.106.124.5.
[Message:105]DHCP: Client receive ACK from 62.106.124.5, IP=10.244.233.241, Lease time=510896.
[Time]Fri Aug 12 11:53:28 2016
[Message:106]Got new client [24:A2:E1:47:C5:5F] associated from BAND5G-1.1 (5 Ghz)
[Message:107]warning: no upstream servers configured
[Time]Fri Aug 12 11:53:29 2016
[Message:108]pppd 2.4.2b3 started by root, uid 0
[Message:109]anon log[callmgr_main:accel-pptp/pptp_callmgr.c:132]: IP: 192.168.0.31
[Message:110]anon log[callmgr_main:accel-pptp/pptp_callmgr.c:136]: control connection
[Message:111]anon log[callmgr_main:accel-pptp/pptp_callmgr.c:140]: unix_sock
[Message:112]anon log[ctrlp_rep:accel-pptp/pptp_ctrl_0_7_13.c:251]: Sent control packet type is 1 'Start-Control-Connection-Request'
[Message:113]anon log[ctrlp_disp:accel-pptp/pptp_ctrl_0_7_13.c:749]: Received Start Control Connection Reply
[Message:114]anon log[ctrlp_disp:accel-pptp/pptp_ctrl_0_7_13.c:783]: Client connection established.
[Time]Fri Aug 12 11:53:30 2016
[Message:115]anon log[ctrlp_rep:accel-pptp/pptp_ctrl_0_7_13.c:251]: Sent control packet type is 7 'Outgoing-Call-Request'
[Message:116]anon log[ctrlp_disp:accel-pptp/pptp_ctrl_0_7_13.c:868]: Received Outgoing Call Reply. callid= 3
[Message:117]anon log[ctrlp_disp:accel-pptp/pptp_ctrl_0_7_13.c:907]: Outgoing call established (call ID 3, peer's call ID 19078).
[Time]Fri Aug 12 11:53:33 2016
[Message:118]CHAP authentication succeeded.
[Message:119]IPCP: local IP address (62.106.121.183)
[Message:120]IPCP: remote IP address (92.240.138.1)
[Message:121]IPCP: primary DNS address (62.106.124.1)
[Message:122]IPCP: secondary DNS address (62.106.124.111)
[Message:123]WAN connected [PPTP]
Есть прошивка 2.04 на сайте, я вот думаю может обновить, поможет? Я к этому роутеру имею доступ через сервис MyDlink (там смотрю новый адрес внешний и через него захожу на роутер), боюсь что начну обновлять и повиснет/настройки собьет....
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 53
