Текущее время: Вт ноя 10, 2026 12:35
СообщениеДобавлено: Пн ноя 04, 2013 10:04
Всем доброго дня, юзаю Dlink DIR 620 ревизии A1, нетак давно 3-5 недель назад, начал отваливаться регулярно интернет, пару секунд, и начинает снова работать, за час, до 3-4 разрыва, инет раздается на телефон по wi-fi и на ПК по проводу. Прошивка последняя, прошивался летом...
    Nov 4 14:42:40 conf_wan[5215]: CONFIG_ACTION_READ - start
    Nov 4 14:42:40 conf_arp: iPhone-4S-32-Gb
    Nov 4 14:42:40 conf_arp: SteflerVIP
    Nov 4 14:42:58 conf_wan[5228]: begin wan_conf
    Nov 4 14:42:58 conf_wan[5228]: CONFIG_ACTION_READ - start
    Nov 4 14:42:58 conf_arp: iPhone-4S-32-Gb
    Nov 4 14:42:58 conf_arp: SteflerVIP
    Nov 4 14:43:22 miniupnpd[849]: Can't find in which sub network the client is
    Nov 4 14:43:23 miniupnpd[849]: Can't find in which sub network the client is
    Nov 4 14:43:28 miniupnpd[849]: Can't find in which sub network the client is
    Nov 4 14:43:33 miniupnpd[849]: Can't find in which sub network the client is
    Nov 4 14:43:38 miniupnpd[849]: Can't find in which sub network the client is
    Nov 4 14:43:45 conf_wan[5266]: begin wan_conf
    Nov 4 14:43:45 conf_wan[5266]: CONFIG_ACTION_READ - start
    Nov 4 14:44:02 conf_wan[5281]: begin wan_conf
    Nov 4 14:44:02 conf_wan[5281]: CONFIG_ACTION_READ - start
    Nov 4 14:44:05 conf_wan[5288]: begin wan_conf
    Nov 4 14:44:05 conf_wan[5288]: CONFIG_ACTION_READ - start
    Nov 4 14:44:09 conf_wan[5296]: begin wan_conf
    Nov 4 14:44:09 conf_wan[5296]: CONFIG_ACTION_READ - start
    Nov 4 14:44:12 conf_wan[5303]: begin wan_conf
    Nov 4 14:44:12 conf_wan[5303]: CONFIG_ACTION_READ - start
    Nov 4 14:44:15 conf_wan[5312]: begin wan_conf
    Nov 4 14:44:15 conf_wan[5312]: CONFIG_ACTION_READ - start
    Nov 4 14:44:18 conf_wan[5319]: begin wan_conf
    Nov 4 14:44:18 conf_wan[5319]: CONFIG_ACTION_READ - start
    Nov 4 14:48:04 kernel: [19747.660000] Rcv Wcid(2) AddBAReq
    Nov 4 14:48:04 kernel: [19747.664000] Start Seq = 00000000
    Nov 4 14:48:04 kernel: [19747.696000] MIC Different in pairwise msg 2 of 4-way handshake!
    Nov 4 14:48:04 kernel: [19747.700000] Rcv Wcid(2) AddBAReq
    Nov 4 14:48:04 kernel: [19747.704000] Start Seq = 00000001
    Nov 4 14:48:05 kernel: [19748.692000] MIC Different in pairwise msg 2 of 4-way handshake!
    Nov 4 14:48:06 kernel: [19749.636000] MIC Different in pairwise msg 2 of 4-way handshake!
    Nov 4 14:48:07 kernel: [19750.632000] MIC Different in pairwise msg 2 of 4-way handshake!
    Nov 4 14:48:14 syslog: route 239.255.255.250: all (1 item(s)) down VIF(s) NOT reported. Delete expired route.
    Nov 4 14:48:50 dnsmasq-dhcp[843]: DHCPINFORM(br0) 192.168.0.34 50:e5:49:55:32:fa
    Nov 4 14:48:50 dnsmasq-dhcp[843]: DHCPACK(br0) 192.168.0.34 50:e5:49:55:32:fa SteflerVIP
    Nov 4 14:50:05 syslog: added membership for 239.255.255.250 on upstream #0 94.154.80.33
    Nov 4 14:50:05 syslog: added new route 239.255.255.250: 94.154.80.33 -> 192.168.0.1
    Nov 4 14:51:27 syslog: route 239.255.255.250 on upstream #0 activated with 94.154.85.2
    Nov 4 14:51:27 miniupnpd[849]: Can't find in which sub network the client is
    Nov 4 14:51:32 miniupnpd[849]: Can't find in which sub network the client is
    Nov 4 14:51:37 miniupnpd[849]: Can't find in which sub network the client is
    Nov 4 14:51:42 miniupnpd[849]: Can't find in which sub network the client is
    Nov 4 14:54:15 dnsmasq-dhcp[843]: DHCPINFORM(br0) 192.168.0.34 50:e5:49:55:32:fa
    Nov 4 14:54:15 dnsmasq-dhcp[843]: DHCPACK(br0) 192.168.0.34 50:e5:49:55:32:fa SteflerVIP
    Nov 4 14:54:25 syslog: route 239.255.255.250: all (1 item(s)) down VIF(s) NOT reported. Delete expired route.
    Nov 4 14:54:33 conf_wan[5613]: begin wan_conf
    Nov 4 14:54:33 conf_wan[5613]: CONFIG_ACTION_READ - start
СообщениеДобавлено: Пн ноя 04, 2013 10:39
DHCP попробуйте отключить на роутере и статикой прописать на всех девайсах адреса из подсети 192.168.0.0/24 со шлюзом/DNS: 192.168.0.1 и понаблюдать за поведением.
СообщениеДобавлено: Вт ноя 05, 2013 16:15
Другие решения, так как коннетится много других устройств, и прописывать каждый раз...Вообще почему данная ошибка могла появиться?..Если вариант перепрошится на zyxel??
СообщениеДобавлено: Вт ноя 05, 2013 16:41
Советую тогда уж перешиться на Wive-NG-RTNL оно свежее и ядреней для ревизии A1. Сам пользовался раньше, но мне USB не нужен был на этой железке, поэтому вливал версию просто RT3052-2T2R. Прошивку от Zyxel Keenetic, dd-wrt и openwrt так же попробывал - все достаточно интересные, но по всем параметрам выиграла вайв в конечном итоге. Вариант со статикой был предложен только для испытаний, чтобы посмотреть поможет или нет.
СообщениеДобавлено: Вс ноя 17, 2013 16:22
нету желания перепрошиваться по личным причинам, пробовал уже откатиться уже на более раннюю прошивку.....тоже самое...может ли быть проблема в провайдере?Так как они еще те парни...
СообщениеДобавлено: Вс ноя 17, 2013 17:31
Может быть всякое и без дампов трафика сделанных каким-нибудь tcpdump прямо на роутере сложно что-либо понять (тут надо своместно курить дампы с ТП провайдера + ТП D-Link, ну накладывая на них логи роутера в срезе по времени, с максимальной детализацией).
Сейчас этот форум просматривают: Google [Bot] и гости: 35
