Текущее время: Вт сен 22, 2026 19:19
 Заголовок сообщения: dlink dwl6600ap console reset
СообщениеДобавлено: Пн июл 22, 2013 08:49
priviet,
kak sdelat factory-reset iz console (po COM1), kogda os perezagruzaetsia, mozno
ostonovit tolko na etom mieste (smotriet do konca teksta)
kak pravilno zpustit etu CLI comandu: factory-reset Reset the system to factory defaults
tak kak - Available commands: et, gpio, wdtest, nvram, mfg_reboot, reboot, set, loop, flas
h, memtest, f, e, d, u, autoboot, batch, go, boot, load, save, ping, arp, ifconf
ig, show, unsetenv, printenv, setenv, help
vidiemijie diski:
CFE> show devices
Device Name Description
uart0 NS16550 UART at 0x18000300
flash0.bootloader New CFI flash at 1C000000 offset 00000000 size 384KB
flash0.boot_env New CFI flash at 1C000000 offset 00060000 size 128KB
flash0.jffs2 New CFI flash at 1C000000 offset 00080000 size 1024KB
flash0.kernel1 New CFI flash at 1C000000 offset 00180000 size 2048KB
flash0.cramfs1 New CFI flash at 1C000000 offset 00380000 size 13312KB
flash0.kernel2 New CFI flash at 1C000000 offset 01080000 size 2048KB
flash0.cramfs2 New CFI flash at 1C000000 offset 01280000 size 13568KB
flash0.nvram New CFI flash at 1C000000 offset 01FC0000 size 128KB
flash0.log New CFI flash at 1C000000 offset 01FE0000 size 128KB
flash0 New CFI flash at 1C000000 size 32768KB
eth0 Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller
vid, kak perezagruzajietsia OS, i ostanovka c Ctrl+C:
Start os:
Decompressing............done
nvram found at bdfc0000
nvram_calc_crc check ok
CFE version 5.100.111 based on BBP 1.0.37 for BCM947XX (32bit,SP,LE)
Enterprise UAP Version 1.2.6
Build Date: Tue Jan 3 09:32:14 EST 2012 (hxshi@xl-rdub-04)
Copyright (C) 2000-2011 Broadcom Corporation.
Init Arena
Init Devs.
Boot partition size = 393216(0x60000)
et0: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 5.100.111
CPU type 0x19740: 453MHz
Tot mem: 131072 KBytes
CFE mem: 0x80700000 - 0x807C46D0 (804560)
Data: 0x80741410 - 0x807446B0 (12960)
BSS: 0x807446B0 - 0x807456D0 (4128)
Heap: 0x807456D0 - 0x807C26D0 (512000)
Stack: 0x807C26D0 - 0x807C46D0 (8192)
Text: 0x80700000 - 0x80741404 (267268)
Boot: 0x007C5000 - 0x00805000
Reloc: I:00000000 - D:00000000
GPIO-11 = 0
GPIO-11 enabled as an output
GPIO-08 = 0
GPIO-13 = 1
GPIO-13 enabled as an output
GPIO-13 disabled as an output
GPIO-08 = 1
GPIO-08 enabled as an output
Device eth0: hwaddr 90-94-E4-89-E0-00, ipaddr 192.168.1.1, mask 255.255.255.0
gateway not set, nameserver not set
Switching boot parameters...
boot_swap called to switch boot
bootcmd oldarg = run boot1
altbootcmd newarg = run boot1
boot_config oldarg = boot -z -elf flash0.kernel1:vmlinux.32.gz
boot_config2 newarg = boot -z -elf flash0.kernel2:vmlinux.32.gz
kernel_args oldarg = console=ttyS0,115200 root=/dev/mtdblock4 ro
kernel_args2 newarg = console=ttyS0,115200 root=/dev/mtdblock6 ro
bootver oldarg = 4.1.0.4
altbootver newarg = (null)
Committing nvram...
bootcmd: run boot1
boot_config: boot -z -elf flash0.kernel2:vmlinux.32.gz
kernel_args: console=ttyS0,115200 root=/dev/mtdblock6 ro
bootver: 4.1.0.4
boot_delay not set - defaulting to 2s
Press Ctrl+C for CFE boot loader menu.
Loader:elf Filesys:raw Dev:flash0.kernel2 File:vmlinux.32.gz Options:(null)
Loading: 0x80001000/3321990 0x8032c086/307466 Entry at 0x80308000
Closing network.
Starting program at 0x80308000
Linux version 2.6.21.5-lvl7-dev (lvl7build@lc-rdub-20) (gcc version 4.2.1) #1 Tu
e Feb 7 13:42:43 EST 2012
CPU revision is: 00019740
Determined physical RAM map:
memory: 07fff000 @ 00000000 (usable)
Initrd not found or empty - disabling initrd
Built 1 zonelists. Total pages: 32512
Kernel command line: console=ttyS0,115200 root=/dev/mtdblock6 ro
Primary instruction cache 32kB, physically tagged, 4-way, linesize 32 bytes.
Primary data cache 32kB, 4-way, linesize 32 bytes.
Synthesized TLB refill handler (20 instructions).
Synthesized TLB load handler fastpath (32 instructions).
Synthesized TLB store handler fastpath (32 instructions).
Synthesized TLB modify handler fastpath (31 instructions).
PID hash table entries: 512 (order: 9, 2048 bytes)
CPU: BCM4716 rev 1 at 453 MHz
Using 226.500 MHz high precision timer.
Console: colour dummy device 80x25
Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
Memory: 126236k/131068k available (2487k kernel code, 4684k reserved, 608k data,
148k init, 0k highmem)
Mount-cache hash table entries: 512
NET: Registered protocol family 16
PCI: Using membase 8000000
PCI: Initializing host
PCI: Reset RC
PCI: no core
PCI: Fixing up bus 0
PCI/PCIe coreunit 0 is set to bus 1.
PCI: Fixing up bridge
PCI: Enabling device 0000:01:00.1 (0004 -> 0006)
PCI: Fixing up bus 1
Time: MIPS clocksource has been installed.
NET: Registered protocol family 2
IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
TCP established hash table entries: 4096 (order: 3, 32768 bytes)
TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
TCP: Hash tables configured (established 4096 bind 4096)
TCP reno registered
Reset Button GPIO = 5
Leds Driver Version 1.0
JFFS2 version 2.2. (NAND) (C) 2001-2006 Red Hat, Inc.
Registering unionfs 2.1.4 (for 2.6.21.7)
io scheduler noop registered
io scheduler anticipatory registered (default)
io scheduler deadline registered
io scheduler cfq registered
Generic RTC Driver v1.07
Software Watchdog Timer: 0.07 initialized. soft_noboot=0 soft_margin=60 sec (now
ayout= 0)
Serial: 8250/16550 driver $Revision: 1.90 $ 4 ports, IRQ sharing enabled
serial8250: ttyS0 at MMIO 0x0 (irq = 8) is a 16550A
RAMDISK driver initialized: 16 RAM disks of 4096K size 1024 blocksize
loop: loaded (max 8 devices)
pflash: driver is cfi_probe
qry_present Q
Check if QRY present
QRY found
Physically mapped flash: Found 1 x16 devices at 0x0 in 8-bit bank
Return from chip probe
retcfi found
cfi is found
Amd/Fujitsu Extended Query Table at 0x0040
Physically mapped flash: CFI does not contain boot bank location. Assuming top.
number of CFI chips: 1
cfi_cmdset_0002: Disabling erase-suspend-program due to code brokenness.
return mtd
Flash device: 0x2000000 at 0x1c000000
Creating 9 MTD partitions on "Physically mapped flash":
0x00000000-0x00060000 : "bootloader"
0x00060000-0x00080000 : "boot_env"
0x00080000-0x00180000 : "jffs2"
0x00180000-0x00380000 : "kernel1"
0x00380000-0x01080000 : "cramfs1"
0x01080000-0x01280000 : "kernel2"
0x01280000-0x01fc0000 : "cramfs2"
0x01fc0000-0x01fe0000 : "nvram"
0x01fe0000-0x02000000 : "log"
IPv4 over IPv4 tunneling driver
TCP cubic registered
NET: Registered protocol family 10
lo: Disabled Privacy Extensions
tunl0: Disabled Privacy Extensions
Mobile IPv6
NET: Registered protocol family 17
802.1Q VLAN Support v1.8 Ben Greear <greearb@candelatech.com>
All bugs added by David S. Miller <davem@redhat.com>
The CRC of the Cramfs image matches crc = a18ef811
VFS: Mounted root (cramfs filesystem) readonly.
Freeing unused kernel memory: 148k freed
Mounting filesystems...
Inserting L2 tunnel code: wlext_l2tunnel.kowlext_l2tunnel: module license 'Propr
ietary' taints kernel.
L2 Tunneling module init
mkdir /proc/net/l2tunnel SUCCESSFUL
mkdir /proc/net/l2tunnel/tunnel SUCCESSFUL
l2tunnel arp task created with pid 727
l2tunnel frag task created with pid 728
Inserting AP Metering module code: wlext_apmeter.ko.
Inserting Captive Portal code: wlext_cp.kowlext_cp: no version for "apMeterCreat
e" found: kernel tainted.
ap cp data allocated
vap cp data allocated
Inserting managed WDS code: wlext_wds.koEntering wlext_wds_db_init
wlext_wds_socket_init Begin
wlext-wds socket created.
wlext_wds_socket_init End
wlext_wds thread created with pid 759
Inserting Centralized L2 tunnel code: wlext_cl2tunnel.koCentralized L2 tunneling
module init begin
mkdir /proc/net/cl2tunnel SUCCESSFUL
Centralized L2 tunneling module initialization SUCCESS
Inserting Dist L2 tunnel code: wlext_dl2tunnel.kodl2tunnel_init: begin
dl2tunnel_monitor_task_init: monitor task created with pid 775
dl2tunnel_stats_proc_init: mkdir /proc/net/dl2tunnel SUCCESSFUL
dl2tunnel_stats_proc_init: mkdir /proc/net/dl2tunnel/sta SUCCESSFUL
dl2tunnel_init: module initializion SUCCESS
Inserting IP tunnel code: wlext_iptunnel.koap tunnel allocated
vap tunnel allocated
Inserting RF Scan code: wlext_rfscan.koEntering wlext_rfscan_db_init
wlext_rfscan_socket_init Begin
wlext-rfscan socket created.
wlext_rfscan_socket_init End
wlext_rfscan_hostapd_socket_init Begin
wlext-rfscan hostapd socket created.
wlext_rfscan_hostapd_socket_init End
wlext_rfscan thread created with pid 790
Inserting wlext stats code: wlext_stats.komkdir /proc/net/ieee80211 SUCCESSFUL
wlext-stats is initialized
Starting tspec.
Inserting Broadcom CTF module: ctf.ko.
Inserting Broadcom et driver code: et.koeth0: Broadcom BCM47XX 10/100/1000 Mbps
Inserting wl driver: wl.kowl: wlc_dl2t_attach 87f2e000, intf 0
wlan1: Broadcom BCM4329 802.11 Wireless Controller 5.100.111
PCI: Enabling device 0000:01:01.0 (0000 -> 0002)
wl: wlc_dl2t_attach 87114000, intf 1
wlan0: Broadcom BCM4322 802.11 Wireless Controller 5.100.111
Radio = 2
Inserting AE Kernel module code: wlext_ae.kowlext_ae thread created with pid 863
Inserting AP QoS module code: wlext_apqos.ko.
Starting asengd.
Erasing 128 Kibyte @ 20000 -- 100 % complete.
Starting mapd and dmandman: Daemonizing...
dman: Daemonized.
dman: Property "config-restored" is not valid for class "cluster" - skipping.
dman: Restarting DHCP client
dman: Starting mapqosd ....
Fri Dec 31 12:00:00 EET 1999
do_page_fault() #2: sending SIGSEGV to dman for invalid read access from 0000000
0 (epc == 2ac9fb6c, ra == 2afb6a38)
Init Arena
Init Devs.
GPIO-11 = 0
GPIO-08 = 0
GPIO-13 = 1
GPIO-08 = 1
boot_config oldarg = boot -z -elf flash0.kernel2:vmlinux.32.gz
boot_config2 newarg = boot -z -elf flash0.kernel1:vmlinux.32.gz
kernel_args oldarg = console=ttyS0,115200 root=/dev/mtdblock6 ro
kernel_args2 newarg = console=ttyS0,115200 root=/dev/mtdblock4 ro
Committing nvram...
bootcmd: run boot1
boot_config: boot -z -elf flash0.kernel1:vmlinux.32.gz
kernel_args: console=ttyS0,115200 root=/dev/mtdblock4 ro
bootver: 4.1.0.4
Startup canceled
CFE>
rimas
 Заголовок сообщения: Re: dlink dwl6600ap console reset
СообщениеДобавлено: Пн июл 22, 2013 12:41
CFE>
ввести команду help посмотреть что выдает.
СообщениеДобавлено: Пн июл 22, 2013 13:28
CFE> help
Available commands:
et Broadcom Ethernet utility.
gpio Enable/Disable or Get/Set values of the GPIO
wdtest Test the external watchdog
nvram NVRAM utility.
mfg_reboot Mfg Reboot.
reboot Reboot.
set console Change the active console device
loop Loop a command
flash Update a flash memory device
memtest Test memory.
f Fill contents of memory.
e Modify contents of memory.
d Dump memory.
u Disassemble instructions.
autoboot Automatic system bootstrap.
batch Load a batch file into memory and execute it
go Verify and boot OS image.
boot Load an executable file into memory and execute it
load Load an executable file into memory without executing
save Save a region of memory to a remote file via TFTP
ping Ping a remote IP host.
arp Display or modify the ARP Table
ifconfig Configure the Ethernet interface
show bootstrap Show 4748 bootstrap options
show clocks Show current values of the clocks.
show heap Display information about CFE's heap
show memory Display the system physical memory map. show devices flasDisplay information about the installed devices.
unsetenv Delete an environment variable.
printenv Display the environment variables
setenv Set an environment variable.
help Obtain help for CFE commands
For more information about a command, enter 'help command-name'
СообщениеДобавлено: Пн июл 22, 2013 13:32
ili mozet est kakije nibud drugijie savieti, kak vostonavit sistemu kotoraja perezagruzajietsia. reset knopka nie rabotajiet, povidimu ona rabotajiet tolko kogda zagruzajietsia OS
СообщениеДобавлено: Пн июл 22, 2013 17:44
kitaip писал(а):
do_page_fault() #2: sending SIGSEGV to dman for invalid read access from 00000000 (epc == 2ac9fb6c, ra == 2afb6a38)
Несите-ка Вы железку в сервис... Похоже, что либо прошивка навернулась, либо что-то с RAM случилось :roll:
СообщениеДобавлено: Вт июл 23, 2013 14:57
Странно, судя по выводу на консоль, он должен входить в режим восстановления.
заходите по 192.168.1.1 на роутер? на компе IP статический в диапазоне 192.168.1.2-254?
если хотите по эксперементировать с новой прошивкой, то посмотрите мои итоги разбирательства с dir-615k2 viewtopic.php?f=3&t=156669&start=15
Учтите что вероятность загнать железку в полный кирпич этом режиме очень и очень большая, одна неверная команда и все :((. Все на свой страх и риск.
Перед прошивкой проверить что идет пинг с роутера на комп, и с компа на роутер. У вас IP 192.168.1.1
СообщениеДобавлено: Вт июл 23, 2013 16:23
pri ostanovke na CFE> po 192.168.1.1 mozmo podkliucitcia k broadcom web consloe, tam dlink firmware neproxodit, niepodxodit.
Tftp сервер na PC 192.168.1.15 zapustil,
resilsia poprobovat i tak:
flash -noerase 192.168.1.15:DWL-6600AP_FW_4_1_0_14.tar flash0 - neproxodit, no firmware fail citaet. Nieznaju tolko pravilno li ukazano flash0 ?
Diski po komandie:
CFE> show devices
nadoel uze on mnie, otpravliaju na dlink servis - oni sami tak sovietujut.
prosto xotel kak bistree...
cpasibo vsiem za sovieti, izviniajus...
СообщениеДобавлено: Вт июл 23, 2013 17:51
это же АРХИВ!!!
Его распаковать нужно и лить по частям.
Отправляй в сервис. пока не убил окончательно.
