Текущее время: Ср ноя 11, 2026 19:18
 Заголовок сообщения: Проблема с DSR-500N
СообщениеДобавлено: Пт апр 26, 2013 11:54
Firmware Version: 1.06B79_RU
Hardware Version: A1
На роутере самые простые настройки:
Т.е. прописан Static IP, поднят DHCP, залочена аська и проброшены порты для Asterisk.
Каждое утро люди приходя в офис звонят и говорят что сети нет. Хотя я спокойно залезаю на роутер через внешник с портом без проблем.
По рекомендации тех. поддержки перешил роутер на текущую прошивку, до этого была DSR-500N_A1_FW1.06B53_RU
Thu Apr 25 18:00:18 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Thu Apr 25 17:59:53 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Thu Apr 25 17:59:50 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Thu Apr 25 17:59:24 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Thu Apr 25 17:59:12 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Thu Apr 25 17:58:54 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Thu Apr 25 17:58:29 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Thu Apr 25 17:31:54 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Thu Apr 25 16:40:49 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Thu Apr 25 16:40:35 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Thu Apr 25 16:40:10 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Thu Apr 25 16:40:07 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 08:31:28 2013(GMT) [DSR-500N][System][LOGGING] Could not execute the smtpClient. adpCmdExec failed. Exiting.
Fri Apr 26 08:31:28 2013(GMT) [DSR-500N][System][PLATFORM] runSmtpClient failed
Fri Apr 26 08:31:28 2013(GMT) [DSR-500N][System][PLATFORM] getaddrinfo returned Unknown error
Fri Apr 26 08:31:13 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 08:30:46 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 08:30:43 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 08:30:18 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 08:30:11 2013(GMT) [DSR-500N][System][LOGGING] Could not execute the smtpClient. adpCmdExec failed. Exiting.
Fri Apr 26 08:30:11 2013(GMT) [DSR-500N][System][PLATFORM] runSmtpClient failed
Fri Apr 26 08:30:11 2013(GMT) [DSR-500N][System][PLATFORM] getaddrinfo returned Unknown error
Fri Apr 26 08:30:05 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 08:29:48 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 08:29:21 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 08:29:17 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 08:28:49 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 08:28:37 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 08:28:22 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 08:27:53 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 08:27:49 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 08:27:20 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 08:27:07 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 08:26:52 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 08:26:39 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 08:26:24 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 08:26:18 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 08:25:51 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 08:25:35 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 08:25:20 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 08:24:51 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 08:24:48 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 08:24:22 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 08:24:08 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 08:23:50 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 08:23:23 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 08:23:20 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 08:22:53 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 08:22:40 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 08:22:22 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 08:21:57 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 08:21:53 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 08:21:33 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 08:21:19 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 08:21:02 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 08:20:46 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 08:20:20 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 08:20:15 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 08:19:49 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 08:19:36 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 08:19:15 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 08:18:45 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 08:18:40 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 08:18:12 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 08:17:59 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 08:17:43 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 08:17:18 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 08:17:10 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 08:16:44 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 08:16:31 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 08:16:15 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 08:15:50 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 08:15:47 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 08:15:18 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 08:15:05 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 08:14:50 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 08:14:23 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 08:14:18 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 08:13:52 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 08:13:35 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 08:13:19 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 08:12:48 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 08:12:45 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 08:12:16 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 08:12:04 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 08:11:48 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 08:11:30 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 08:11:18 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 08:11:15 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 08:10:46 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 08:10:33 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 08:10:18 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 08:09:51 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 08:09:44 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 08:09:19 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 08:09:02 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 08:08:46 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 08:08:18 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 08:08:14 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 08:07:48 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 08:07:35 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 08:07:15 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 08:06:50 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 08:06:47 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 08:06:26 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 08:06:21 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 08:06:09 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 08:05:52 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 08:05:25 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 08:05:22 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 08:04:53 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 08:04:41 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 08:04:25 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 08:03:56 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 08:03:53 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 08:03:28 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 08:03:15 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 08:02:57 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 08:02:32 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 08:02:24 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 08:01:58 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 08:01:46 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 08:01:29 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 08:01:23 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 08:01:04 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 08:01:00 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 08:00:30 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 08:00:17 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:59:58 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:59:32 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:59:29 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:58:59 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:58:47 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:58:31 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:58:02 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:57:58 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:57:30 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:57:17 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:57:02 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:56:33 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:56:30 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:56:21 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:56:04 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:55:51 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:55:33 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:55:08 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:55:00 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:54:35 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:54:21 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:54:06 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:53:41 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:53:37 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:53:07 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:52:55 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:52:36 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:52:11 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:52:08 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:51:40 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:51:26 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:51:20 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:51:13 2013(GMT) [DSR-500N][System][VIPSECURE] Invalid exchange type 243 from 114.34.126.71[500].
Fri Apr 26 07:51:10 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:51:08 2013(GMT) [DSR-500N][System][VIPSECURE] Invalid exchange type 243 from 114.34.126.71[500].
Fri Apr 26 07:51:05 2013(GMT) [DSR-500N][System][VIPSECURE] Invalid exchange type 243 from 114.34.126.71[500].
Fri Apr 26 07:51:03 2013(GMT) [DSR-500N][System][VIPSECURE] Invalid exchange type 243 from 114.34.126.71[500].
Fri Apr 26 07:50:41 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:50:38 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:50:12 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:49:58 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:49:41 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:49:12 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:49:08 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:48:39 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:48:26 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:48:08 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:47:40 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:47:34 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:47:07 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:46:51 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:46:36 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:46:16 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:46:06 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:46:03 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:45:37 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:45:22 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:45:06 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:44:37 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:44:34 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:44:08 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:43:56 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:43:38 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:43:13 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:43:04 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:42:38 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:42:19 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:42:03 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:41:37 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:41:32 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:41:13 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:41:07 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:40:54 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:40:33 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:40:07 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:40:04 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:39:38 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:39:25 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:39:06 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:38:38 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:38:30 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:38:05 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:37:51 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:37:35 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:37:10 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:37:07 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:36:37 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:36:25 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:36:12 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:36:05 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:35:40 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:35:36 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:35:10 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:34:57 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:34:41 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:34:15 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:34:12 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:33:46 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:33:33 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:33:17 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:32:51 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:32:48 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:32:22 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:32:09 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:31:53 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:31:28 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:31:24 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:31:10 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:30:57 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:30:44 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:30:28 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:30:03 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:29:59 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:29:31 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:29:18 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:29:03 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:28:38 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:28:34 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:28:06 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:27:54 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:27:37 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:27:11 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:27:08 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:26:42 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:26:28 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:26:13 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:26:07 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:25:47 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:25:44 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:25:18 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:25:05 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:24:49 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:24:23 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:24:20 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:23:54 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:23:41 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:23:26 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:23:00 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:22:57 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:22:30 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:22:17 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:22:02 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:21:36 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:21:33 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:21:07 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:21:05 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:20:53 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:20:37 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:20:12 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:20:08 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:19:43 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:19:30 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:19:14 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:18:49 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:18:46 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:18:20 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:18:07 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:17:52 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:17:26 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:17:23 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:16:57 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:16:44 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:16:29 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:16:04 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:16:01 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:16:00 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:15:35 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:15:22 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:15:05 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:14:40 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:14:37 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:14:11 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:13:58 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:13:41 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:13:16 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:13:13 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:12:47 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:12:34 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:12:18 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:11:59 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:11:53 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:11:50 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:11:24 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:11:11 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:10:56 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:10:31 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:10:27 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:10:01 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:09:48 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:09:32 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:09:07 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:09:04 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:08:38 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:08:25 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:08:09 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:07:43 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:07:40 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:07:14 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:07:01 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:06:58 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:06:44 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:06:19 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:06:16 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:05:51 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:05:38 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:05:21 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:04:56 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:04:53 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:04:27 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:04:14 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:03:59 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:03:33 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:03:30 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:03:05 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:02:52 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:02:36 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:02:10 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:02:06 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:01:56 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:01:41 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:01:28 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:01:13 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:00:47 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:00:44 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:00:18 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 07:00:05 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 06:59:48 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 06:59:23 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 06:59:20 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 06:58:53 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 06:58:41 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 06:58:25 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 06:57:59 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 06:57:55 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 06:57:27 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 06:57:14 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 06:56:58 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 06:56:53 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 06:56:29 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 06:56:25 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 06:56:00 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 06:55:47 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 06:55:18 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 06:54:40 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 06:54:27 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 06:53:45 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 06:53:25 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 06:52:54 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 06:52:15 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 06:52:03 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 06:51:49 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 06:51:21 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 06:51:00 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 06:50:31 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 06:49:54 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 06:49:44 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 06:49:05 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 06:48:45 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 06:48:14 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 06:46:49 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 06:46:39 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 06:45:56 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 06:44:24 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 06:43:44 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 06:42:22 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 06:41:25 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 06:40:54 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 06:40:09 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 06:39:17 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 06:38:56 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 06:38:26 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 06:37:49 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 06:37:36 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 06:36:54 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 06:36:23 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 06:36:15 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 06:35:49 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 06:35:11 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 06:35:00 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 06:34:01 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 06:33:24 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 06:32:56 2013(GMT) [DSR-500N][System][NIMF] dbRecordValueGet failed for rowid column
Fri Apr 26 06:32:30 2013(GMT) [DSR-500N][System][PLATFORM] IPv6 not configured on the interface
Fri Apr 26 06:32:24 2013(GMT) [DSR-500N][System][USERDB] Error in executing DB update handler
Fri Apr 26 06:32:14 2013(GMT) [DSR-500N][System][PLATFORM] /pfrm2.0/bin/cdpConfig /tmp/system.db 18 ConfigPort 1 failed. status=-1
Fri Apr 26 06:32:13 2013(GMT) [DSR-500N][System][PLATFORM] /pfrm2.0/bin/iprouteConfig /tmp/system.db 18 route 20 failed. status=-1
Fri Apr 26 06:32:13 2013(GMT) [DSR-500N][System][PLATFORM] Route addition failed
Fri Apr 26 06:32:13 2013(GMT) [DSR-500N][System][PLATFORM] /pfrm2.0/bin/iprouteConfig /tmp/system.db 18 route 19 failed. status=-1
Fri Apr 26 06:32:12 2013(GMT) [DSR-500N][System][PLATFORM] /pfrm2.0/bin/iprouteConfig /tmp/system.db 18 route 18 failed. status=-1
Fri Apr 26 06:32:12 2013(GMT) [DSR-500N][System][PLATFORM] Route addition failed
Fri Apr 26 06:32:12 2013(GMT) [DSR-500N][System][PLATFORM] /pfrm2.0/bin/iprouteConfig /tmp/system.db 18 route 17 failed. status=-1
Fri Apr 26 06:32:11 2013(GMT) [DSR-500N][System][PLATFORM] Route addition failed
Fri Apr 26 06:32:11 2013(GMT) [DSR-500N][System][PLATFORM] /pfrm2.0/bin/iprouteConfig /tmp/system.db 18 route 16 failed. status=-1
Fri Apr 26 06:32:11 2013(GMT) [DSR-500N][System][PLATFORM] /pfrm2.0/bin/iprouteConfig /tmp/system.db 18 route 15 failed. status=-1
Fri Apr 26 06:32:10 2013(GMT) [DSR-500N][System][PLATFORM] Route addition failed
Fri Apr 26 06:32:10 2013(GMT) [DSR-500N][System][PLATFORM] /pfrm2.0/bin/iprouteConfig /tmp/system.db 18 route 14 failed. status=-1
Fri Apr 26 06:32:10 2013(GMT) [DSR-500N][System][PLATFORM] /pfrm2.0/bin/iprouteConfig /tmp/system.db 18 route 13 failed. status=-1
Fri Apr 26 06:32:09 2013(GMT) [DSR-500N][System][PLATFORM] Route addition failed
Fri Apr 26 06:32:09 2013(GMT) [DSR-500N][System][PLATFORM] /pfrm2.0/bin/iprouteConfig /tmp/system.db 18 route 12 failed. status=-1
Fri Apr 26 06:32:09 2013(GMT) [DSR-500N][System][PLATFORM] /pfrm2.0/bin/iprouteConfig /tmp/system.db 18 route 11 failed. status=-1
Fri Apr 26 06:32:08 2013(GMT) [DSR-500N][System][PLATFORM] Route addition failed
Fri Apr 26 06:32:08 2013(GMT) [DSR-500N][System][PLATFORM] /pfrm2.0/bin/iprouteConfig /tmp/system.db 18 route 10 failed. status=-1
Fri Apr 26 06:32:08 2013(GMT) [DSR-500N][System][PLATFORM] /pfrm2.0/bin/iprouteConfig /tmp/system.db 18 route 9 failed. status=-1
Fri Apr 26 06:32:07 2013(GMT) [DSR-500N][System][PLATFORM] Route addition failed
Fri Apr 26 06:32:07 2013(GMT) [DSR-500N][System][PLATFORM] /pfrm2.0/bin/iprouteConfig /tmp/system.db 18 route 8 failed. status=-1
Fri Apr 26 06:32:07 2013(GMT) [DSR-500N][System][PLATFORM] /pfrm2.0/bin/iprouteConfig /tmp/system.db 18 route 7 failed. status=-1
Fri Apr 26 06:32:06 2013(GMT) [DSR-500N][System][PLATFORM] Route addition failed
Fri Apr 26 06:32:06 2013(GMT) [DSR-500N][System][PLATFORM] /pfrm2.0/bin/iprouteConfig /tmp/system.db 18 route 6 failed. status=-1
Fri Apr 26 06:32:06 2013(GMT) [DSR-500N][System][PLATFORM] /pfrm2.0/bin/iprouteConfig /tmp/system.db 18 route 5 failed. status=-1
Fri Apr 26 06:32:05 2013(GMT) [DSR-500N][System][PLATFORM] Route addition failed
Fri Apr 26 06:32:05 2013(GMT) [DSR-500N][System][PLATFORM] /pfrm2.0/bin/iprouteConfig /tmp/system.db 18 route 4 failed. status=-1
Fri Apr 26 06:32:04 2013(GMT) [DSR-500N][System][PLATFORM] /pfrm2.0/bin/iprouteConfig /tmp/system.db 18 route 3 failed. status=-1
Fri Apr 26 06:32:04 2013(GMT) [DSR-500N][System][PLATFORM] Route addition failed
Fri Apr 26 06:32:03 2013(GMT) [DSR-500N][System][PLATFORM] /pfrm2.0/bin/iprouteConfig /tmp/system.db 18 route 2 failed. status=-1
Fri Apr 26 06:32:03 2013(GMT) [DSR-500N][System][PLATFORM] Route addition failed
Fri Apr 26 06:32:02 2013(GMT) [DSR-500N][System][PLATFORM] /pfrm2.0/bin/iprouteConfig /tmp/system.db 18 route 1 failed. status=-1
Fri Apr 26 06:32:02 2013(GMT) [DSR-500N][System][PLATFORM] Route addition failed
Fri Apr 26 06:31:35 2013(GMT) [DSR-500N][System][PLATFORM] dbRecordValueGet failed for column
 Заголовок сообщения: Re: Проблема с DSR-500N
СообщениеДобавлено: Пн апр 29, 2013 11:39
Up!
СообщениеДобавлено: Пн апр 29, 2013 12:30
Попробуйте более новую прошивку: ftp://ftp.dlink.ru/pub/Router/DSR-500N/ ... 1.06B93_RU
После прошивки сброс и настройка заново вручную.
СообщениеДобавлено: Пн апр 29, 2013 14:51
Я уже все попробовал, завтра он поедет в Ваш сервис.
Сейчас этот форум просматривают: Google [Bot] и гости: 28
cron
