Текущее время: Чт сен 24, 2026 01:34
СообщениеДобавлено: Вт янв 15, 2013 09:49
Я подключаю устройство , нахожусь с ним в одной подсети (lan1) и не выходит на web конфигуратор.
Подключился через HyperTerminal там пытался сбросить все настройки по дефолту , но ничего не вышло ,вроде как.
После перезагрузки выдал следующий лог
Starting core in 0 seconds.
Press any key to abort and load boot menu
Loading fwcore.cfx
D-Link Firewall 2.27.02.14-14549
Copyright Clavister 1996-2010. All rights reserved
QuickSec SSHIPSECPM version 2.1 library 2.1
Copyright 1997-2003 SafeNet Inc
Build : Sep 29 2010
License file successfully loaded.
Configuration done
Interfaces:
wan IPAddr 0.0.0.0 HwAddr 5c-d9-98-49-c0-eb
Builtin r8169 - RealTek 8169SC/8110SC Single-chip Gigabit Ethernet 8169SC Bus
0 Slot 3 IRQ 0
dmz IPAddr 172.17.100.254 HwAddr 5c-d9-98-49-c0-ea
0 Slot 4 IRQ 0
lan IPAddr 192.168.10.1 HwAddr 5c-d9-98-49-c0-e9
Builtin IXP4NPE - Port 2 IRQ 0
Previous shutdown: Unknown reason
System running
DFL-260E:/> reset -unit
Sarting system...
Entry point: 0x00101028, address range: 0x00100000-0x002a2000
Resetting to factory defaults...Done
Loading fwcore.cfx
Build : Sep 29 2010
NOTE: Found configuration for a different core version: dfl.2.00.00.
Changed name of object "all_services" to "all_tcpudpicmp".
WARNING: In IKEAlgorithms Medium: Property "DES3Enabled" not found in object typ
e IKEAlgorithms.
WARNING: In IKEAlgorithms Medium: Property "AESEnabled" not found in object type
IKEAlgorithms.
WARNING: In IKEAlgorithms Medium: Property "BlowfishEnabled" not found in object
type IKEAlgorithms.
WARNING: In IKEAlgorithms Medium: Property "TwofishEnabled" not found in object
type IKEAlgorithms.
WARNING: In IKEAlgorithms Medium: Property "CAST128Enabled" not found in object
type IKEAlgorithms.
WARNING: In IPsecAlgorithms Medium: Property "DES3Enabled" not found in object t
ype IPsecAlgorithms.
WARNING: In IPsecAlgorithms Medium: Property "AESEnabled" not found in object ty
pe IPsecAlgorithms.
WARNING: In IPsecAlgorithms Medium: Property "BlowfishEnabled" not found in obje
ct type IPsecAlgorithms.
WARNING: In IPsecAlgorithms Medium: Property "TwofishEnabled" not found in objec
WARNING: In IPsecAlgorithms Medium: Property "CAST128Enabled" not found in objec
WARNING: IKEAlgorithms Medium was disabled because it contains errors: In proper
ty NULLEnabled: At least one encryption algorithm must be selected.
WARNING: IPsecAlgorithms Medium was disabled because it contains errors: In prop
erty NULLEnabled: At least one encryption algorithm must be selected.
Generating remote management HTTPS certificate, please wait...done.
NOTE: Successfully converted configuration (localcfgver=1).
Configuration done
Подскажите какие действия мне предпринять.
Заранее благодарю.
СообщениеДобавлено: Вт янв 15, 2013 09:54
https://192.168.10.1
Сейчас этот форум просматривают: Google [Bot] и гости: 52
