Текущее время: Пн сен 21, 2026 00:04
 Заголовок сообщения: Заболел роутер
СообщениеДобавлено: Ср окт 05, 2011 20:38
Вот собственно скрины,по l2tp перестал подкоючаться,по PPTP рвет связь,прошивка последняя,работало все норм все 2 года,но вот 3 дня уже подобные вещи творятся.Шил,сбрасывал настройки - без толку
[INFO] Sat Jan 31 14:02:21 2004 PPP network down
[INFO] Sat Jan 31 14:02:21 2004 PPTP tunnel ID 0x151B has been closed
[INFO] Sat Jan 31 14:02:21 2004 Blocked incoming TCP connection request from 213.111.120.5:60046 to 46.47.13.100:51306
[INFO] Sat Jan 31 14:02:21 2004 Blocked incoming UDP packet from 114.40.30.211:26404 to 46.47.13.100:46935
[INFO] Sat Jan 31 14:02:21 2004 Blocked incoming UDP packet from 109.194.188.18:16257 to 46.47.13.100:46935
[INFO] Sat Jan 31 14:02:20 2004 Blocked incoming TCP connection request from 91.216.28.5:62310 to 46.47.13.100:46935
[INFO] Sat Jan 31 14:02:20 2004 Blocked incoming TCP connection request from 95.73.88.133:54606 to 46.47.13.100:51306
[INFO] Sat Jan 31 14:02:20 2004 Blocked incoming UDP packet from 178.120.19.143:24832 to 46.47.13.100:46935
[INFO] Sat Jan 31 14:02:20 2004 Blocked incoming UDP packet from 178.179.237.135:30227 to 46.47.13.100:46935
[INFO] Sat Jan 31 14:02:19 2004 Blocked incoming TCP packet from 93.186.224.240:80 to 46.47.13.100:42487 as FIN:ACK received but there is no active connection
[INFO] Sat Jan 31 14:01:42 2004 Blocked incoming TCP connection request from 94.141.69.170:9830 to 46.47.13.100:46935
[INFO] Sat Jan 31 14:01:42 2004 Blocked incoming TCP connection request from 94.141.69.170:9553 to 46.47.13.100:46935
[INFO] Sat Jan 31 14:01:41 2004 Blocked incoming TCP connection request from 31.162.213.167:54907 to 46.47.13.100:46935
[INFO] Sat Jan 31 14:01:41 2004 Blocked incoming TCP connection request from 86.110.163.20:55811 to 46.47.13.100:46935
[INFO] Sat Jan 31 14:01:41 2004 Blocked incoming UDP packet from 91.205.239.46:57250 to 46.47.13.100:46935
[INFO] Sat Jan 31 14:01:41 2004 Blocked incoming TCP connection request from 114.143.124.9:17376 to 46.47.13.100:46935
[INFO] Sat Jan 31 14:01:40 2004 Blocked incoming UDP packet from 83.142.210.28:41057 to 46.47.13.100:46935
[INFO] Sat Jan 31 14:01:40 2004 Blocked incoming UDP packet from 91.90.235.110:44411 to 46.47.13.100:46935
[INFO] Sat Jan 31 14:01:39 2004 Blocked incoming TCP connection request from 46.72.4.165:62212 to 46.47.13.100:46935
[INFO] Sat Jan 31 14:01:39 2004 Blocked incoming UDP packet from 195.168.61.210:43301 to 46.47.13.100:46935
[INFO] Sat Jan 31 14:01:39 2004 Blocked incoming TCP connection request from 77.50.109.5:2031 to 46.47.13.100:46935
[INFO] Sat Jan 31 14:01:38 2004 Blocked incoming TCP connection request from 31.162.213.167:54907 to 46.47.13.100:46935
[INFO] Sat Jan 31 14:01:38 2004 Blocked incoming UDP packet from 92.249.75.129:43327 to 46.47.13.100:46935
[INFO] Sat Jan 31 14:01:38 2004 Blocked incoming TCP connection request from 86.110.163.20:55811 to 46.47.13.100:46935
[INFO] Sat Jan 31 14:01:37 2004 Blocked incoming TCP connection request from 81.9.17.61:47216 to 46.47.13.100:51306
[INFO] Sat Jan 31 14:01:37 2004 Blocked incoming GRE packet from 10.0.0.133 to 10.0.37.148
[INFO] Sat Jan 31 14:01:37 2004 Above message repeated 1 times
[INFO] Sat Jan 31 14:01:37 2004 Blocked incoming TCP connection request from 79.111.203.59:3011 to 46.47.13.100:46935
[INFO] Sat Jan 31 14:01:37 2004 Blocked incoming TCP connection request from 93.123.141.25:39260 to 46.47.13.100:46935
[INFO] Sat Jan 31 14:01:37 2004 Blocked incoming UDP packet from 91.90.235.110:44411 to 46.47.13.100:46935
[INFO] Sat Jan 31 14:01:37 2004 Blocked incoming TCP connection request from 46.250.3.106:58853 to 46.47.13.100:51306
[INFO] Sat Jan 31 14:01:36 2004 Blocked incoming TCP connection request from 46.72.4.165:62212 to 46.47.13.100:46935
[INFO] Sat Jan 31 14:01:36 2004 Blocked incoming UDP packet from 94.141.69.170:9548 to 46.47.13.100:46935
[INFO] Sat Jan 31 14:01:36 2004 Blocked incoming TCP connection request from 94.141.69.170:9553 to 46.47.13.100:46935
[INFO] Sat Jan 31 14:01:36 2004 Blocked incoming TCP connection request from 188.163.19.74:62066 to 46.47.13.100:46935
[INFO] Sat Jan 31 14:01:35 2004 Blocked incoming UDP packet from 2.93.109.93:17575 to 46.47.13.100:46935
[INFO] Sat Jan 31 14:01:35 2004 Blocked incoming TCP connection request from 188.163.19.74:62059 to 46.47.13.100:46935
[INFO] Sat Jan 31 14:01:35 2004 Blocked incoming UDP packet from 92.249.75.129:43327 to 46.47.13.100:46935
[INFO] Sat Jan 31 14:01:35 2004 Blocked incoming UDP packet from 195.168.61.210:43301 to 46.47.13.100:46935
[INFO] Sat Jan 31 14:01:35 2004 Blocked incoming UDP packet from 91.205.239.46:57250 to 46.47.13.100:46935
[INFO] Sat Jan 31 14:01:34 2004 Blocked incoming TCP connection request from 193.169.63.23:55032 to 46.47.13.100:46935
[INFO] Sat Jan 31 14:01:34 2004 Blocked incoming TCP connection request from 109.195.219.127:60483 to 46.47.13.100:46935
[INFO] Sat Jan 31 14:01:34 2004 Blocked incoming UDP packet from 92.243.181.41:58223 to 46.47.13.100:46935
[INFO] Sat Jan 31 14:01:34 2004 Blocked incoming TCP connection request from 212.119.233.133:4724 to 46.47.13.100:46935
[INFO] Sat Jan 31 14:01:34 2004 Blocked incoming TCP connection request from 93.123.141.25:39260 to 46.47.13.100:46935
[INFO] Sat Jan 31 14:01:34 2004 Blocked incoming TCP connection request from 46.250.3.106:58853 to 46.47.13.100:51306
[INFO] Sat Jan 31 14:01:33 2004 Blocked incoming TCP connection request from 77.50.109.5:2031 to 46.47.13.100:46935
[INFO] Sat Jan 31 14:01:33 2004 Blocked incoming UDP packet from 94.141.69.170:9548 to 46.47.13.100:46935
[INFO] Sat Jan 31 14:01:33 2004 Blocked incoming TCP connection request from 94.141.69.170:9553 to 46.47.13.100:46935
[INFO] Sat Jan 31 14:01:33 2004 Blocked incoming TCP connection request from 91.144.147.165:51608 to 46.47.13.100:46935
[INFO] Sat Jan 31 14:01:32 2004 Blocked incoming UDP packet from 2.93.109.93:17575 to 46.47.13.100:46935
[INFO] Sat Jan 31 14:01:32 2004 Blocked incoming UDP packet from 91.205.239.46:57250 to 46.47.13.100:46935
[INFO] Sat Jan 31 14:01:32 2004 Blocked incoming UDP packet from 188.233.226.29:38869 to 46.47.13.100:46935
[INFO] Sat Jan 31 14:01:31 2004 Blocked incoming UDP packet from 92.243.181.41:58223 to 46.47.13.100:46935
[INFO] Sat Jan 31 14:01:31 2004 Blocked incoming TCP connection request from 81.9.17.61:47216 to 46.47.13.100:51306
[INFO] Sat Jan 31 14:01:31 2004 Blocked incoming TCP connection request from 79.111.203.59:3011 to 46.47.13.100:46935
[INFO] Sat Jan 31 14:01:30 2004 Blocked incoming UDP packet from 91.205.239.46:57250 to 46.47.13.100:46935
[INFO] Sat Jan 31 14:01:30 2004 Blocked incoming UDP packet from 46.73.240.227:28676 to 46.47.13.100:46935
[INFO] Sat Jan 31 14:01:30 2004 Blocked incoming TCP connection request from 77.50.109.5:2031 to 46.47.13.100:46935
[INFO] Sat Jan 31 14:01:30 2004 Blocked incoming UDP packet from 91.79.11.165:26865 to 46.47.13.100:46935
[INFO] Sat Jan 31 14:01:30 2004 Blocked incoming UDP packet from 121.169.143.180:12857 to 46.47.13.100:46935
[INFO] Sat Jan 31 14:01:29 2004 Blocked incoming UDP packet from 95.32.67.21:64005 to 46.47.13.100:46935
[INFO] Sat Jan 31 14:01:28 2004 Blocked incoming TCP connection request from 193.169.63.23:55032 to 46.47.13.100:46935
[INFO] Sat Jan 31 14:01:28 2004 Blocked incoming TCP connection request from 109.195.219.127:60483 to 46.47.13.100:46935
[INFO] Sat Jan 31 14:01:28 2004 Blocked incoming TCP connection request from 81.9.17.61:47216 to 46.47.13.100:51306
[INFO] Sat Jan 31 14:01:28 2004 Blocked incoming TCP connection request from 212.119.233.133:4724 to 46.47.13.100:46935
[INFO] Sat Jan 31 14:01:28 2004 Blocked incoming TCP connection request from 79.111.203.59:3011 to 46.47.13.100:46935
[INFO] Sat Jan 31 14:01:28 2004 Blocked incoming UDP packet from 79.111.203.59:1041 to 46.47.13.100:46935
[INFO] Sat Jan 31 14:01:27 2004 Blocked incoming UDP packet from 118.36.22.190:24138 to 46.47.13.100:46935
[INFO] Sat Jan 31 14:01:27 2004 Blocked incoming UDP packet from 88.88.180.21:18216 to 46.47.13.100:46935
[INFO] Sat Jan 31 14:01:27 2004 Blocked incoming TCP connection request from 46.211.228.167:63414 to 46.47.13.100:46935
[INFO] Sat Jan 31 14:01:27 2004 Blocked incoming TCP connection request from 91.144.147.165:51608 to 46.47.13.100:46935
[INFO] Sat Jan 31 14:01:27 2004 Blocked incoming UDP packet from 31.163.27.108:1025 to 46.47.13.100:46935
[INFO] Sat Jan 31 14:01:27 2004 Blocked incoming TCP connection request from 46.160.120.5:62368 to 46.47.13.100:46935
[INFO] Sat Jan 31 14:01:26 2004 Blocked incoming TCP connection request from 92.243.183.49:50387 to 46.47.13.100:51306
[INFO] Sat Jan 31 14:01:26 2004 Blocked incoming TCP connection request from 188.163.19.74:62019 to 46.47.13.100:46935
[INFO] Sat Jan 31 14:01:26 2004 Blocked incoming UDP packet from 195.14.118.152:33797 to 46.47.13.100:46935
[INFO] Sat Jan 31 14:01:26 2004 Blocked incoming UDP packet from 95.32.67.21:64005 to 46.47.13.100:46935
[INFO] Sat Jan 31 14:01:26 2004 Blocked incoming TCP connection request from 188.163.19.74:62015 to 46.47.13.100:46935
[INFO] Sat Jan 31 14:01:26 2004 Blocked incoming TCP connection request from 91.215.195.56:4124 to 46.47.13.100:46935
[INFO] Sat Jan 31 14:01:25 2004 Blocked incoming TCP connection request from 193.169.63.23:55032 to 46.47.13.100:46935
[INFO] Sat Jan 31 14:01:25 2004 Blocked incoming UDP packet from 109.205.250.28:52938 to 46.47.13.100:46935
[INFO] Sat Jan 31 14:01:25 2004 Blocked incoming TCP connection request from 109.195.219.127:60483 to 46.47.13.100:46935
[INFO] Sat Jan 31 14:01:25 2004 Blocked incoming UDP packet from 95.73.23.83:31819 to 46.47.13.100:46935
[INFO] Sat Jan 31 14:01:25 2004 Blocked incoming TCP connection request from 212.119.233.133:4724 to 46.47.13.100:46935
[INFO] Sat Jan 31 14:01:25 2004 Blocked incoming UDP packet from 79.111.203.59:1041 to 46.47.13.100:46935
[INFO] Sat Jan 31 14:01:24 2004 Blocked incoming TCP connection request from 178.44.139.94:2341 to 46.47.13.100:46935
[INFO] Sat Jan 31 14:01:24 2004 Blocked incoming UDP packet from 31.163.27.108:1025 to 46.47.13.100:46935
[INFO] Sat Jan 31 14:01:24 2004 Blocked incoming TCP connection request from 2.93.41.125:4477 to 46.47.13.100:46935
[INFO] Sat Jan 31 14:01:23 2004 Blocked incoming TCP connection request from 85.250.141.29:64363 to 46.47.13.100:46935
[INFO] Sat Jan 31 14:01:23 2004 Blocked incoming TCP connection request from 91.144.147.165:51608 to 46.47.13.100:46935
[INFO] Sat Jan 31 14:01:23 2004 Blocked incoming UDP packet from 217.15.145.206:40421 to 46.47.13.100:46935
[INFO] Sat Jan 31 14:01:22 2004 Blocked incoming UDP packet from 109.205.250.28:52938 to 46.47.13.100:46935
[INFO] Sat Jan 31 14:01:22 2004 Blocked incoming TCP connection request from 94.19.45.161:52426 to 46.47.13.100:46935
[INFO] Sat Jan 31 14:01:22 2004 Blocked incoming UDP packet from 95.73.23.83:31819 to 46.47.13.100:46935
[INFO] Sat Jan 31 14:01:21 2004 Blocked incoming TCP connection request from 46.73.242.227:63607 to 46.47.13.100:46935
[INFO] Sat Jan 31 14:01:21 2004 Blocked incoming UDP packet from 46.211.228.167:33938 to 46.47.13.100:46935
[INFO] Sat Jan 31 14:01:21 2004 Blocked incoming TCP connection request from 46.211.228.167:63414 to 46.47.13.100:46935
[INFO] Sat Jan 31 14:01:20 2004 Blocked incoming TCP connection request from 46.160.120.5:62368 to 46.47.13.100:46935
[INFO] Sat Jan 31 14:01:20 2004 Blocked incoming TCP connection request from 92.243.183.49:50387 to 46.47.13.100:51306
[INFO] Sat Jan 31 14:01:20 2004 Blocked incoming TCP connection request from 91.144.147.165:51608 to 46.47.13.100:46935
[INFO] Sat Jan 31 14:01:20 2004 Blocked incoming UDP packet from 212.119.246.18:16381 to 46.47.13.100:46935
[INFO] Sat Jan 31 14:01:20 2004 Blocked incoming TCP connection request from 91.215.195.56:4124 to 46.47.13.100:46935
[INFO] Sat Jan 31 14:01:19 2004 Blocked incoming TCP connection request from 77.30.123.190:52131 to 46.47.13.100:46935
[INFO] Sat Jan 31 14:01:19 2004 Blocked incoming TCP connection request from 178.159.112.33:55691 to 46.47.13.100:46935
[INFO] Sat Jan 31 14:01:18 2004 Blocked incoming TCP connection request from 94.232.49.46:60809 to 46.47.13.100:46935
[INFO] Sat Jan 31 14:01:18 2004 Blocked incoming UDP packet from 46.211.228.167:33938 to 46.47.13.100:46935
[INFO] Sat Jan 31 14:01:18 2004 Blocked incoming TCP connection request from 46.211.228.167:63414 to 46.47.13.100:46935
[INFO] Sat Jan 31 14:01:18 2004 Blocked incoming UDP packet from 95.19.25.10:20617 to 46.47.13.100:46935
[INFO] Sat Jan 31 14:01:18 2004 Blocked incoming TCP connection request from 178.44.139.94:2341 to 46.47.13.100:46935
[INFO] Sat Jan 31 14:01:18 2004 Blocked incoming TCP connection request from 2.93.41.125:4477 to 46.47.13.100:46935
[INFO] Sat Jan 31 14:01:18 2004 Blocked incoming UDP packet from 2.93.41.125:61623 to 46.47.13.100:46935
[INFO] Sat Jan 31 14:01:18 2004 Blocked incoming TCP connection request from 92.243.183.49:50387 to 46.47.13.100:51306
[INFO] Sat Jan 31 14:01:17 2004 Blocked incoming TCP connection request from 85.250.141.29:64363 to 46.47.13.100:46935
[INFO] Sat Jan 31 14:01:17 2004 Blocked incoming TCP connection request from 46.160.120.5:62368 to 46.47.13.100:46935
[INFO] Sat Jan 31 14:01:17 2004 Blocked incoming TCP connection request from 195.214.215.173:36309 to 46.47.13.100:46935
[INFO] Sat Jan 31 14:01:17 2004 Blocked incoming TCP connection request from 91.144.147.165:51608 to 46.47.13.100:46935
[INFO] Sat Jan 31 14:01:17 2004 Blocked incoming TCP connection request from 91.215.195.56:4124 to 46.47.13.100:46935
[INFO] Sat Jan 31 14:01:16 2004 Blocked incoming TCP connection request from 94.19.45.161:52426 to 46.47.13.100:46935
[INFO] Sat Jan 31 14:01:15 2004 Blocked incoming TCP connection request from 46.73.242.227:63607 to 46.47.13.100:46935
[INFO] Sat Jan 31 14:01:15 2004 Blocked incoming UDP packet from 188.16.242.46:32730 to 46.47.13.100:46935
[INFO] Sat Jan 31 14:01:15 2004 Blocked incoming TCP connection request from 94.232.49.46:60809 to 46.47.13.100:46935
[INFO] Sat Jan 31 14:01:15 2004 Blocked incoming UDP packet from 95.19.25.10:20617 to 46.47.13.100:46935
[INFO] Sat Jan 31 14:01:15 2004 Blocked incoming TCP connection request from 178.44.139.94:2341 to 46.47.13.100:46935
[INFO] Sat Jan 31 14:01:15 2004 Blocked incoming TCP connection request from 2.93.41.125:4477 to 46.47.13.100:46935
[INFO] Sat Jan 31 14:01:15 2004 Blocked incoming UDP packet from 2.93.41.125:61623 to 46.47.13.100:46935
[INFO] Sat Jan 31 14:01:14 2004 Blocked incoming TCP connection request from 85.250.141.29:64363 to 46.47.13.100:46935
[INFO] Sat Jan 31 14:01:14 2004 Blocked incoming UDP packet from 213.185.11.75:49021 to 46.47.13.100:46935
[INFO] Sat Jan 31 14:01:14 2004 Blocked incoming TCP connection request from 195.214.215.173:36309 to 46.47.13.100:46935
[INFO] Sat Jan 31 14:01:14 2004 Blocked incoming TCP connection request from 91.144.147.165:51608 to 46.47.13.100:46935
[INFO] Sat Jan 31 14:01:13 2004 Blocked incoming TCP connection request from 94.19.45.161:52426 to 46.47.13.100:46935
[INFO] Sat Jan 31 14:01:13 2004 Blocked incoming TCP connection request from 188.233.67.44:56273 to 46.47.13.100:46935
[INFO] Sat Jan 31 14:01:13 2004 Blocked incoming TCP connection request from 78.106.113.63:60452 to 46.47.13.100:46935
[INFO] Sat Jan 31 14:01:13 2004 Blocked incoming UDP packet from 178.159.112.33:30841 to 46.47.13.100:46935
[INFO] Sat Jan 31 14:01:13 2004 Blocked incoming TCP connection request from 178.159.112.33:55691 to 46.47.13.100:46935
[INFO] Sat Jan 31 14:01:12 2004 Blocked incoming TCP connection request from 46.73.242.227:63607 to 46.47.13.100:46935
[INFO] Sat Jan 31 14:01:12 2004 Blocked incoming UDP packet from 188.16.242.46:32730 to 46.47.13.100:46935
[INFO] Sat Jan 31 14:01:12 2004 Blocked incoming UDP packet from 188.24.58.128:15752 to 46.47.13.100:46935
[INFO] Sat Jan 31 14:01:11 2004 Blocked incoming TCP connection request from 82.81.230.5:57510 to 46.47.13.100:46935
[INFO] Sat Jan 31 14:01:11 2004 Blocked incoming UDP packet from 77.30.123.190:44151 to 46.47.13.100:46935
[INFO] Sat Jan 31 14:01:11 2004 Blocked incoming TCP connection request from 91.144.147.165:51608 to 46.47.13.100:46935
[INFO] Sat Jan 31 14:01:11 2004 Blocked incoming UDP packet from 188.134.38.211:42021 to 46.47.13.100:46935
[INFO] Sat Jan 31 14:01:10 2004 Blocked incoming TCP connection request from 77.47.166.199:54314 to 46.47.13.100:46935
[INFO] Sat Jan 31 14:01:10 2004 Blocked incoming UDP packet from 95.189.44.93:41170 to 46.47.13.100:46935
[INFO] Sat Jan 31 14:01:10 2004 Blocked incoming UDP packet from 178.159.112.33:30841 to 46.47.13.100:46935
[INFO] Sat Jan 31 14:01:10 2004 Blocked incoming TCP connection request from 178.159.112.33:55691 to 46.47.13.100:46935
[INFO] Sat Jan 31 14:01:09 2004 Blocked incoming UDP packet from 114.143.124.9:12223 to 46.47.13.100:46935
[INFO] Sat Jan 31 14:01:09 2004 Blocked incoming UDP packet from 195.214.215.173:6881 to 46.47.13.100:46935
[INFO] Sat Jan 31 14:01:09 2004 Blocked incoming UDP packet from 139.190.16.57:29124 to 46.47.13.100:46935
[INFO] Sat Jan 31 14:01:08 2004 Blocked incoming TCP connection request from 82.81.230.5:57510 to 46.47.13.100:46935
[INFO] Sat Jan 31 14:01:08 2004 Blocked incoming UDP packet from 178.150.74.237:35795 to 46.47.13.100:46935
[INFO] Sat Jan 31 14:01:07 2004 Blocked incoming TCP connection request from 77.47.166.199:54314 to 46.47.13.100:46935
[INFO] Sat Jan 31 14:01:07 2004 Blocked incoming UDP packet from 188.233.67.44:11657 to 46.47.13.100:46935
[INFO] Sat Jan 31 14:01:07 2004 Blocked incoming TCP connection request from 188.233.67.44:56273 to 46.47.13.100:46935
[INFO] Sat Jan 31 14:01:07 2004 Blocked incoming GRE packet from 10.0.0.133 to 10.0.37.148
[INFO] Sat Jan 31 14:01:07 2004 Blocked incoming TCP connection request from 78.106.113.63:60452 to 46.47.13.100:46935
[INFO] Sat Jan 31 14:01:07 2004 Blocked incoming UDP packet from 109.94.3.174:27136 to 46.47.13.100:46935
[INFO] Sat Jan 31 14:01:06 2004 Blocked incoming UDP packet from 114.143.124.9:12223 to 46.47.13.100:46935
[INFO] Sat Jan 31 14:01:05 2004 Blocked incoming UDP packet from 178.150.74.237:35795 to 46.47.13.100:46935
[INFO] Sat Jan 31 14:01:04 2004 Blocked incoming TCP connection request from 188.233.67.44:56273 to 46.47.13.100:46935
[INFO] Sat Jan 31 14:01:04 2004 Blocked incoming UDP packet from 188.233.67.44:11657 to 46.47.13.100:46935
[INFO] Sat Jan 31 14:01:04 2004 Blocked incoming TCP connection request from 78.106.113.63:60452 to 46.47.13.100:46935
[INFO] Sat Jan 31 14:01:03 2004 Blocked incoming TCP connection request from 94.232.49.46:62201 to 46.47.13.100:46935
[INFO] Sat Jan 31 14:01:03 2004 Blocked incoming UDP packet from 91.215.195.56:42133 to 46.47.13.100:46935
[INFO] Sat Jan 31 14:01:03 2004 Blocked incoming TCP connection request from 46.148.128.102:61138 to 46.47.13.100:46935
[INFO] Sat Jan 31 14:01:02 2004 Blocked incoming TCP connection request from 94.137.41.94:55490 to 46.47.13.100:46935
[INFO] Sat Jan 31 14:01:00 2004 PPP network up with IP Address 46.47.13.100
[INFO] Sat Jan 31 14:01:00 2004 MSCHAP authentication successful.
[INFO] Sat Jan 31 14:00:57 2004 MSCHAP authentication details were sent to authenticator.
[INFO] Sat Jan 31 14:00:57 2004 MSCHAP authentication challenge received from peer.
[INFO] Sat Jan 31 14:00:57 2004 LCP sets local options: ACCM: 00000000, ACFC: 0, PFC: 0, MRU: 1436
[INFO] Sat Jan 31 14:00:57 2004 LCP sets remote auth: C223
[INFO] Sat Jan 31 14:00:57 2004 LCP sets remote options: ACCM: FFFFFFFF, ACFC: 0, PFC: 0, MRU: 1436
[INFO] Sat Jan 31 14:00:56 2004 PPTP connected to server "local" with ID 0x151B
[INFO] Sat Jan 31 14:00:56 2004 The PPTP transmit window is 16000
[INFO] Sat Jan 31 14:00:56 2004 Attempting to establish a PPTP connection.
[INFO] Sat Jan 31 14:00:37 2004 Blocked incoming GRE packet from 10.0.0.133 to 10.0.37.148
D-link DIR-615 B2 || PPTP || Static IP
 Заголовок сообщения: Re: Заболел роутер
СообщениеДобавлено: Чт окт 06, 2011 15:48
Попробуйте советы вот отсюда
viewtopic.php?p=749542#p749542
Сейчас этот форум просматривают: Google [Bot] и гости: 39
