Текущее время: Вс сен 20, 2026 23:46
 Заголовок сообщения: di-804 vs di-804 vpn
СообщениеДобавлено: Ср авг 31, 2011 21:16
Ребята, помогите! Две недели пытаюсь поднять туннель между идентичными устройствами и прошивками, делаю все по инструкции с длинка. Вечно пишет истеблишн. Привожу логи роутеров:
Wednesday April 28, 2010 03:37:54 IKED re-TX : QINIT to 81.201.249.38
Wednesday April 28, 2010 03:37:55 Disassociated: Blocked access attempt from 46.167.64.12:39419 to UDP port 41827
Wednesday April 28, 2010 03:37:58 Disassociated: Blocked access attempt from 93.95.143.67:53967 to UDP port 41827
Wednesday April 28, 2010 03:38:00 Disassociated: Blocked access attempt from 95.104.33.199:27519 to UDP port 20614
Wednesday April 28, 2010 03:38:00 Disassociated: Blocked access attempt from 95.27.74.37:20138 to UDP port 41827
Wednesday April 28, 2010 03:38:04 IKED re-TX : QINIT to 81.201.249.38
Wednesday April 28, 2010 03:38:05 Disassociated: Blocked access attempt from 109.225.21.142:18511 to UDP port 41827
Wednesday April 28, 2010 03:38:08 Disassociated: Blocked access attempt from 109.225.21.142:18511 to UDP port 41827
Wednesday April 28, 2010 03:38:14 IKED re-TX : QINIT to 81.201.249.38
Wednesday April 28, 2010 03:38:31 Disassociated: Blocked access attempt from 95.28.51.138:31757 to UDP port 41827
Wednesday April 28, 2010 03:38:34 IKED re-TX : QINIT to 81.201.249.38
Wednesday April 28, 2010 03:38:35 Send IKE (INFO) : delete [192.168.1.0|83.246.177.109]-->[81.201.249.38|192.168.0.0] phase 2
Wednesday April 28, 2010 03:38:35 IKE phase2 (IPSec SA) remove : 192.168.1.0 <-> 192.168.0.0
Wednesday April 28, 2010 03:38:35 inbound SPI = 0x4200f723, outbound SPI = 0x0
Wednesday April 28, 2010 03:38:38 Send IKE Q1(QINIT) : 192.168.1.0 --> 192.168.0.0
Wednesday April 28, 2010 03:38:40 Disassociated: Blocked access attempt from 77.108.101.210:57407 to TCP port 41827
Wednesday April 28, 2010 03:38:43 IKED re-TX : QINIT to 81.201.249.38
Wednesday April 28, 2010 03:38:43 Disassociated: Blocked access attempt from 77.108.101.210:57407 to TCP port 41827
Wednesday April 28, 2010 03:38:47 Disassociated: Blocked access attempt from 117.193.114.88:12511 to UDP port 41827
Wednesday April 28, 2010 03:38:48 IKED re-TX : QINIT to 81.201.249.38
еще иногда пишет:
receiving a re-Tx MM msg, response the last msg vpn
Короче, все настройки перепробовал - разного рода логи кажет. ТО в первой фазе, то во второй. Завтра выложу более подробный лог ;)
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 56
