Текущее время: Сб сен 19, 2026 07:50
 Заголовок сообщения: IPSEC туннель между DFL-860E и Centos
СообщениеДобавлено: Чт июл 07, 2011 12:41
Добрый день!
Пытаюсь поднять туннель DFL-860E и Centos, собственно не выходит :D
Вроде как первую стадию проходит, дальше не в какую.
На стороне CentOS следующие ошибки
Jul  7 12:22:38 gate racoon: INFO: 62.32.86.XXX[500] used as isakmp port (fd=19)
Jul  7 12:22:38 gate racoon: INFO: 62.32.86.XXX[500] used for NAT-T
Jul  7 12:22:44 gate racoon: INFO: respond new phase 1 negotiation: 62.32.86.138[500]<=>77.220.184.82[500]
Jul  7 12:22:44 gate racoon: INFO: begin Identity Protection mode.
Jul  7 12:22:44 gate racoon: WARNING: ignore INITIAL-CONTACT notification, because it is only accepted after phase1.
Jul  7 12:22:44 gate racoon: INFO: ISAKMP-SA established 62.32.86.XXX[500]-77.220.184.XXX[500] spi:66bcb6fb8381ee80:f6d1ecb54809dc4a
Jul  7 12:22:44 gate racoon: INFO: respond new phase 2 negotiation: 62.32.86.XXX[500]<=>77.220.184.XXX[500]
Jul  7 12:22:44 gate racoon: ERROR: not matched
Jul  7 12:22:44 gate racoon: ERROR: no suitable policy found.
Jul  7 12:22:44 gate racoon: ERROR: failed to pre-process packet.
Jul  7 12:22:45 gate racoon: ERROR: couldn't find configuration.
На стороне DFL-860E следующие
ike_sa_destroyed
ike_sa_killed
ike_sa=" Initiator SPI ESP=0x2e286aef, AH=0xd39c2271, IPComp=0x5222486"
psec_sa_statistics
done=625 success=0 failed=625
ike_quickmode_failed
local_ip=77.220.184.XXX remote_ip=62.32.86.XXX cookies=2e286aefd39c22715222486154c23818 reason="Aborted notification"
Warning    IPSEC
ipsec_sa_failed
no_ipsec_sa
statusmsg="Aborted notification"
ipsec_event
message=" Remote Proxy ID 192.168.1.0/24 any"
sec_event
message=" Local Proxy ID 192.168.10.0/24 any"
ike_sa_negotiation_completed
ike_sa_completed
local_peer="77.220.184.XXX ID 77.220.184.XXX" remote_peer="62.32.86.XXX ID 62.32.86.XXX" initiator_spi="2e286aef d39c2271" responder_spi="52224861 54c23818"
Настройки CentOS
cat /etc/racoon/racoon.conf
path include "/etc/racoon";
path pre_shared_key "/etc/racoon/psk.txt";
path certificate "/etc/racoon/certs";
log debug2;
listen
isakmp 62.32.86.XXX;
timer
        # These value can be changed per remote node.
        counter 5;              # maximum trying count to send.
        interval 20 sec;        # maximum interval to resend.
        persend 1;              # the number of packets per send.
        # maximum time to wait for completing each phase.
        phase1 30 sec;
        phase2 15 sec;
sainfo anonymous
        pfs_group 2;
        lifetime time 1 hour ;
        encryption_algorithm des ;
        authentication_algorithm hmac_md5 ;
        compression_algorithm deflate ;
include "/etc/racoon/77.220.184.XXX.conf";
 cat /etc/racoon/77.220.184.XXX.conf
remote 77.220.184.XXX
        exchange_mode main, aggressive;
        my_identifier address;
        proposal {
                encryption_algorithm des;
                hash_algorithm sha1;
                authentication_method pre_shared_key;
                dh_group 2;
Не как не могу понять в чем проблема
 Заголовок сообщения: Re: IPSEC туннель между DFL-860E и Centos
СообщениеДобавлено: Пт июл 08, 2011 05:49
Настройки DFL покажите, прошивка у вас на нем какая?
Хотите считать с него трафик?
СообщениеДобавлено: Пт июл 08, 2011 11:02
Добрый день!
Прошивка 2.27.02.14-14550 Sep 29 2010
Настройки
MagistratLan это 192.168.1.0/24
MagistratWan это внешний IP удаленной сети.
СообщениеДобавлено: Пт июл 08, 2011 13:54
Туннель поднялся после добавления в конфиг ракуна
данной строчки generate_policy on;
 cat /etc/racoon/77.220.184.ХХХ.conf
remote 77.220.184.82
        proposal {
                dh_group 2;
generate_policy on;
Только теперь в логах куча сообщений подобного вида (но, туннель работает):
Jul  8 13:48:11 gate racoon: ERROR: unknown Informational exchange received.
Jul  8 13:48:11 gate racoon: ERROR: couldn't find configuration.
СообщениеДобавлено: Пт июл 08, 2011 17:46
На первый взгляд - у вас pfs group 2 в конфиге, в DFL попробуйте выбрать его же
ID, если у вас белый адрес на DFL, выставьте в Auto
Keep alive = auto на практике пинует первый адрес в удаленной подсети, поэтому советую вам руками установить адреса
С другой стороны, попробуйте обновиться на 2.27.03.25 с http://tsd.dlink.com.tw/ и использовать нормальное шифрование, возможно есть проблема и с DES/MD5
СообщениеДобавлено: Пн июл 11, 2011 17:16
Добрый день!
Сегодня обновил прошивку до 2.30.01.06-15901 May 12 2011, перешел на шифрование 3DES, не помогло.
В лог ракуна так и сыпятся эти сообщения (каждую минуту), такое впечатление что это тупо баг.
Jul 11 17:18:00 gate racoon: ERROR: unknown Informational exchange received.
Jul 11 17:18:00 gate racoon: ERROR: couldn't find configuration.
СообщениеДобавлено: Пн июл 11, 2011 17:39
Сложно сказать, надо тестировать
На глаз не сходятся параметры
