Текущее время: Чт сен 10, 2026 03:27
СообщениеДобавлено: Пн окт 19, 2009 13:38
Добрый день! Пытаюсь настроить DI-524 (Firmware Version: V2.06RU, Tue, Jan 30 2007) согласно инструкции провайдера:
WAN Settings -> Others -> PPTP
PTP Client -> Dynamic IP
Server IP/Name -> ppp.lan
Account vpp_*******
Password ********
Retype Password ********
Connect Mode Manual
LAN Settings
IP Address 192.168.0.1
Subnet Mask 255.255.255.0
DHCP Server
DHCP Server -> Enabled
Starting IP Address -> 192.168.0.100
Ending IP Address -> 192.168.0.199
Lease Time 1 Week
Wireless Enabled
Network ID(SSID) home
Channel 6
Security WPA-PSK
Encryption TKIP
Preshare Key ********
На закладке status получаем:
LAN
MAC Address 00-13-46-4F-BE-43
DHCP Server Enabled
WAN
MAC Address 00-13-46-4F-BE-42
Connection PPTP Disconnected.
IP Address 10.30.56.237
Connection Time -
Subnet Mask 255.255.255.255
Gateway 10.30.56.1
Domain Name Server 212.1.224.34, 212.1.230.111
Wireless
ESSID home
Security WPA-PSK (TKIP)
Channel 6
В логах почему-то 2007 год...
Подскажите плз что не так
СообщениеДобавлено: Вт окт 20, 2009 11:30
При попытке подключения в логи записывается:
Wednesday January 31, 2007 00:19:57 DOD:triggered internally
Wednesday January 31, 2007 00:19:57 PPTP start to dial-up
Wednesday January 31, 2007 00:19:57 PPTP:PNS=10.10.9.12
Wednesday January 31, 2007 00:19:59 PPP1: Rx LCP Request
Wednesday January 31, 2007 00:19:59 PPP1: TX LCP ACK
Wednesday January 31, 2007 00:19:59 PPP1: TX LCP Request
Wednesday January 31, 2007 00:19:59 PPP1: Rx LCP ACK
Wednesday January 31, 2007 00:20:00 MSCHAP1: E=691 R=0
Wednesday January 31, 2007 00:20:00 LCP1: RX terminate request
Wednesday January 31, 2007 00:20:01 DOD is disabled
Wednesday January 31, 2007 00:20:01 PPP1: TX(0) LCP Request
Wednesday January 31, 2007 00:20:02 PPP1: TX(1) LCP Request
Wednesday January 31, 2007 00:20:04 PPP1: TX(2) LCP Request
Wednesday January 31, 2007 00:20:04 DOD is disabled
Wednesday January 31, 2007 00:20:05 PPP1: TX(3) LCP Request
Wednesday January 31, 2007 00:20:06 PPP1: TX(4) LCP Request
Wednesday January 31, 2007 00:20:07 PPP1: TX(5) LCP Request
Wednesday January 31, 2007 00:20:07 PPP1: closed
Wednesday January 31, 2007 00:20:08 DOD is disabled
Wednesday January 31, 2007 00:20:11 DOD is disabled
Wednesday January 31, 2007 00:20:13 PPTP:error=-200
Wednesday January 31, 2007 00:20:13 DHCP:release
Wednesday January 31, 2007 00:20:14 PPTP start to dial-up
Wednesday January 31, 2007 00:20:14 DHCP:discover()
Wednesday January 31, 2007 00:20:14 DHCP:offer(10.30.56.1)
Wednesday January 31, 2007 00:20:14 DHCP:request(10.30.56.237)
Wednesday January 31, 2007 00:20:14 DOD is disabled
Wednesday January 31, 2007 00:20:14 DHCP:ack(DOL=432000,T1=216000,T2=378000)
Подскажите плз где проблема, сама в них не могу разобраться!
СообщениеДобавлено: Ср окт 21, 2009 10:59
Попробуйте заменить ppp.lan на любой из адресов:
10.10.9.4, 10.10.9.8, 10.10.9.11, 10.10.9.12, 10.10.9.13, 10.10.9.14, 10.10.9.50, 10.10.9.51, 10.10.9.53, 10.10.9.56, 10.10.9.57, 10.10.9.59, 10.10.9.60, 10.10.9.62, 10.10.3.34, 10.10.3.36, 10.10.3.40, 10.10.3.44, 10.10.3.45, 10.10.3.47, 10.10.3.48, 10.10.3.50
СообщениеДобавлено: Ср окт 21, 2009 11:34
Попробовала несколько из них. Не коннектится. ошибка в логе другая:
Tuesday January 30, 2007 00:04:02 PPTP:error=-112
Tuesday January 30, 2007 00:04:02 PPTP start to dial-up
Tuesday January 30, 2007 00:04:02 DHCP:discover()
Tuesday January 30, 2007 00:04:02 DHCP:offer(10.30.56.1)
Tuesday January 30, 2007 00:04:02 DHCP:request(10.30.56.237)
Tuesday January 30, 2007 00:04:02 DHCP:ack(DOL=432000,T1=216000,T2=378000)
Tuesday January 30, 2007 00:04:02 PPTP:PNS=10.10.3.48
Tuesday January 30, 2007 00:04:09 DOD is disabled
Tuesday January 30, 2007 00:04:09 Restarted by 192.168.0.104
Tuesday January 30, 2007 00:04:10 PPTP start to dial-up
Tuesday January 30, 2007 00:04:10 DHCP:discover()
Tuesday January 30, 2007 00:04:10 DHCP:offer(10.30.56.1)
Tuesday January 30, 2007 00:04:10 DHCP:request(10.30.56.237)
Tuesday January 30, 2007 00:04:10 DHCP:ack(DOL=432000,T1=216000,T2=378000)
Tuesday January 30, 2007 00:04:10 PPTP:PNS=10.10.3.48
Tuesday January 30, 2007 00:04:10 Reassociated: 00-1A-73-EF-4E-C6 st=0
Tuesday January 30, 2007 00:04:40 DHCP:release
СообщениеДобавлено: Ср окт 21, 2009 12:28
Connect mode поставьте в Always. И уточните у техподдержки провайдера данные для подключения. Видят ли они маршрутизатор у себя? На какой стадии авторизации происходит ошибка?
СообщениеДобавлено: Ср окт 21, 2009 13:11
Подключилась:) Итого у чуваков в инструкции было 2 ошибки - неправильный формат имени пользователя (приставка) и соединение нужно прописывать не PPTP, а PPPOE...
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 93
