Текущее время: Ср сен 09, 2026 23:42
 Заголовок сообщения: dir 400 b russian pptp
СообщениеДобавлено: Вс сен 27, 2009 14:14
Помогите настроить dir 400 прошивка 1.03. настроил все
в винде подключение навпрямую
если через роутер то появляется интернет шлюз но интернета нету!!!!!
маршруты прописал и стали доступны локальние ресурсы
логи
Time Message
Sep 22 22:04:01  Connect: ppp0 '--' pptp (80.249.234.68)
Sep 22 22:04:01  Using interface ppp0
Sep 22 22:04:01  anon log[ctrlp_disp:pptp_ctrl.c:895]: Outgoing call established (call ID 1062, peer's call ID 39643).
Sep 22 22:04:01  anon log[ctrlp_disp:pptp_ctrl.c:856]: Received Outgoing Call Reply.
Sep 22 22:04:01  anon log[ctrlp_rep:pptp_ctrl.c:251]: Sent control packet type is 7 'Outgoing-Call-Request'
Sep 22 22:04:00  anon log[ctrlp_disp:pptp_ctrl.c:771]: Client connection established.
Sep 22 22:04:00  anon log[ctrlp_disp:pptp_ctrl.c:737]: Received Start Control Connection Reply
Sep 22 22:04:00  anon log[ctrlp_rep:pptp_ctrl.c:251]: Sent control packet type is 1 'Start-Control-Connection-Request'
Sep 22 22:04:00  anon log[callmgr_main:pptp_callmgr.c:140]: unix_sock
Sep 22 22:04:00  anon log[callmgr_main:pptp_callmgr.c:136]: control connection
Time                   Message
Sep 22 22:03:19  anon log[callmgr_main:pptp_callmgr.c:132]: IP: 80.249.234.68
Sep 22 22:03:19  pppd 2.4.3 started by root, uid 0
Sep 22 22:03:19  PPTP plugin version 0.7.12 compiled for pppd-2.4.3, linux-2.6.15
Sep 22 22:03:19  Plugin /lib/pptp.so loaded.
Sep 22 22:03:04  Exit.
Sep 22 22:03:04  anon log[ctrlp_rep:pptp_ctrl.c:251]: Sent control packet type is 4 'Stop-Control-Connection-Reply'
Sep 22 22:03:04  anon log[ctrlp_disp:pptp_ctrl.c:786]: Received Stop Control Connection Request.
Sep 22 22:03:04  anon log[call_callback:pptp_callmgr.c:79]: Closing connection (call state)
Sep 22 22:03:04  anon log[ctrlp_error:pptp_ctrl.c:199]: Result code is 3 'Administrative Shutdown'. Error code is 0, Cause code is 0
Sep 22 22:03:04  anon log[ctrlp_disp:pptp_ctrl.c:927]: Call disconnect notification received (call id 1059)
Никогда не думал что можно сделать что-то настолько плохо!!!!!!
СообщениеДобавлено: Вс сен 27, 2009 15:39
мак-адрес с сетевой карты компа склонировал на wan роутера? та и показать не мешало бы настройки pptp на роутере, а не статус - из которого видно, что pptp-коннект на сервер не поднимается.....
ЗЫ кроме того, микрософт-шифрование (mppe) роутер НЕ УМЕЕТ ни в каком виде. Уточни у техподдержки провайдера - как работать тебе, если твоё устройство НЕ УМЕЕТ шифрования MPPE
ЗЗЫ "маршруты" надо прописывать на WAN Physical - а второй, третий, и последний маршруты - вообще полный бред. В роутере линукс вообще-то, а не винда (с который ты сдампил резалт от "route print" - непонимаячтоделаешь)
см. ниже
прежде чем орать "кАзлы" - прочтите, наконец, инструкцию.... (c)
СообщениеДобавлено: Вс сен 27, 2009 16:47
пока ещё время не ушло - срочно несите этот роутер обратно в магазин и берите вместо него DIR-300, DIR-320 или DIR-615
модель DIR-400 неудачная, избавляйтесь от неё как можно быстрее.
СообщениеДобавлено: Вс сен 27, 2009 17:03
Да, неудачна. Да, уже снята с производства.
Тем не менее, к вопросу топик-стартера данный "крик души" не имеет ровно никакого отношения. Ибо и настроить его можно, и работать он будет - да и прошивка, судя по дате - у топикстартера уже стоит 1.03b08beta03, которую вроде как вылизали - и я уже на форуме видел "восторженный отзыв" о ней.
(у меня, кстати - стоит 1.03b05, и вполне устраивает меня после всего предыдущего.... (как раз русский пптп пользую)).
А рекомендованные Вами "DIR-300, DIR-320 или DIR-615" топикстартер точно так же настроит неправильно.... (более того, DIR-300 так же, как и 400й, mppe не умеет)
СообщениеДобавлено: Вс сен 27, 2009 17:52
а какие роутеры умеют mppe?
СообщениеДобавлено: Вс сен 27, 2009 18:07
а Вот подождём рабочего дня, когда спецы техподдержки появятся тут - я думаю, они Вам перечислят "свои" модели с подержкой MPPE. Навскидку - DIR-330, но он избыточен для Ваших целей (да и не дёшев).
зы Как мне "нравятся" те сисадмины провайдеров, которые считают, что у их клиентов "ничего кроме виндовсов быть не может" и включают на своих pptp-серверах "доступа в интернет" требование микрософтовских вывихов (мсчапа, мппе) и т.п. - усложняя жизнь клиентам и самим себе.....:(
СообщениеДобавлено: Вс сен 27, 2009 18:27
дело в том что я живу в общежитии))))
раньше просто был прокси сервер у меня, а сейчас поменялся провайдер.....
СообщениеДобавлено: Вс сен 27, 2009 19:55
НЕ в этом дело, просто я сам - сисадмин isp, и у меня в сети на pptp работают нормально любые роутеры :)
да, и кстати, уберите с LAN публичную сеть 192.167.0/24 . данная сеть принадлежит итальянскому провайдеру
inetnum: 192.167.0.0 - 192.167.0.255
netname: INFN-CT
descr: INFN - Sezione di Catania
country: IT
-а то не сможете попадать на сайты, у этих итальянцев находящиеся.
используйте для своих "частных локалок" сети из диапазонов адресов, по стандартам выделенных для локалок:
192.168.0.0 - 192.168.255.255
172.16.0.0 - 172.31.255.255
10.0.0.0 - 10.255.255.255
(кстати, у Вас в маршрутах ошибка, для сети 172.16.0.0 должна быть маска 255.240.0.0, а у Вас 255.255.0.0)
СообщениеДобавлено: Вс сен 27, 2009 22:14
Только что прочитал про прошивку dd-wrt, но не понял поддерживает она mppe или нет?
СообщениеДобавлено: Пн сен 28, 2009 12:59
DIR-300, DIR-320
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 64
